Draining the oil filter - tubing size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thundjet, Aug 1, 2012.
  1. Aug 8, 2012 at 8:49 AM
    #21
    jmhirshorn
    jmhirshorn Member
    Josh
    Evans, Ga
    '12 TRD Sport
    Debadged, Tonneau, URD TCAI, Flowmaster DBX Hushpower Cat Back, URD MAF Recalibrator
    You've got to keep lubrication on your pulley system somehow! :D
  2. Oct 27, 2022 at 1:49 PM
    #22
    idaho_flyfisher
    idaho_flyfisher Member
    Chad
    2008 Black Tacoma TRD
    I just changed my oil and thought I needed a new filter drain cap. The cap came on there, but I don't know if there is a part number or I just try to find a 5/16" cap at home depot. Any suggestions?
  3. Oct 27, 2022 at 2:16 PM
    #23
    vtdog
    vtdog Well-Known Member
    NH
    20 0z coke bottle works perfectly. I sits on a couple of hoses underneath and the drain nipple fits into the bottle. Its "secure" and you can drain out the cup while you do other stuff
  4. Oct 27, 2022 at 2:46 PM
    #24
    idaho_flyfisher
    Chad
    The cap on there is probably an inch long and closed on the end, preventing dirt and dust. I haven't any problems draining the cup.... but I wish I had a new cap like the one on there since this one looks like it about to crack. Am I getting the impression people are just leaving the 5/16" tube on instead of a cap?
  5. Oct 27, 2022 at 3:04 PM
    #25
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    Save a empty oil bottle from the last oil change to put under the drain. Replace the filter, spray some brake cleaner in and around the drain to wash the oil out, done. Don't even need a rubber cap
    Rick's 2012 likes this.
  6. Oct 27, 2022 at 3:18 PM
    #26
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    I believe the Toyota P/N you're looking for is 90339-07016. It's pricey at over $7 MSRP, although there are plenty of Toyota parts dealers/suppliers selling it discounted for around ~$5 (still way too much). It's up to you whether you want to buy a new OEM cap, cheap one from store, overcomplicate & clutter things up with a hose, or just go the @b_r_o method.
  7. Oct 27, 2022 at 3:36 PM
    #27
    idaho_flyfisher
    Chad
    Thanks for all the feedback. I found a huge kit of these vacuum caps for 8 bucks with nitrile rubber. I will probably try to spray it when my current cap falls off to see how it works. Thanks again.
  8. Oct 28, 2022 at 6:31 PM
    #28
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I never thought to put a hose on it. I will try it at my next oil change as I have extra tubing laying around.
    OffroadToy[QUOTED] likes this.
  9. Oct 28, 2022 at 8:14 PM
    #29
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Yeah. I just use an old plastic peanut butter container. Place it right underneath the oil filter housing drain hole. The pulleys etc keep it in place while I do the oil change.
  10. Oct 28, 2022 at 8:19 PM
    #30
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Taco Bell cup with fishing line. Three years and counting.4A00327F-0A21-456B-BBD1-5F642B301AA2.jpg
    reallifedog likes this.
