Slider Powder coat with Rustoleum bed coating question
View Poll Results: Powder Coating Sliders
Yes that'll work 2 66.67%
Zinc plate then paint 0 0%
Zinc plate then undercoat 0 0%
other... specify 1 33.33%
Voters: 3. You may not vote on this poll
Old 08-08-2012, 02:37 PM   #1
nut [OP] nut is online now
she'll ride
nut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shednut is one of the sharper tools in the shed
nut's Avatar
Navy: AC3 (Vet)
nut's Tacoma Gallery
Question Slider Powder coat with Rustoleum bed coating question
I just got my sliders from DWreck today, and want to have them powder coated tomorrow. I don't do any offroading around a lot of rocks, mostly just sand. They are going to be zinc plated (for the rust out here) then powder coated and I was thinking of laying them upside down and putting a thick layer of rustoleum truck bed coating so they would be more resistant to chips from gravel/road debris. Do you guys think it will hold up well enough to justify powder coating?
(I know some of you are asking why I got sliders if I'm not a trail warrior. I got them because I'd rather have them and not need them than need them and not have them, plus I want protection from door dings as well as a lifting point, and they look pretty effing sweet )
edit: posted here cause I didn't know where else to post it, and more people look under second gen
Old 08-08-2012, 03:10 PM   #2
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
Check into what actually sticks to zinc plated metals. Some paints aren't compatible and will actually bubble. I don't know which ones will do so for sure, I just know there are compatibility issues with some paints on galvy surfaces.
In all honesty though, I wouldn't waste the money on powder coat if you're just going to use bed liner. A regular metal primer will work just fine.
Old 08-08-2012, 03:12 PM   #3
Don't ask questions you don't want the answer to..
chadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shedchadderkdawg is one of the sharper tools in the shed
chadderkdawg's Avatar
chadderkdawg's Tacoma Gallery
Why would you zinc, then powdercoat, then paint? Seems triple redundant...
Old 08-08-2012, 03:20 PM   #4
she'll ride
nut's Avatar
Navy: AC3 (Vet)
The powder coat'er said he zinc plates everything like this for rust protection, which makes sense and is included with the cost of coating so why not. The powder coating will give a great durable finish/aid in rust protection but will likely chip/thin after a while from rocks/gravel just thrown up on the highway, this is where the layer of undercoating comes in. i am only going to spray it on the bottom of the rails. like how on the bottom of out door panels the paint is orange peeled for about 6 inches, i assume its for a similar purpose.
Old 08-08-2012, 03:22 PM   #5
Pugga's Avatar
I'd spray the whole thing in bedliner if you're going to do it.
Old 08-08-2012, 03:28 PM   #6
she'll ride
nut's Avatar
Navy: AC3 (Vet)
I want to zinc it regardless of what i do, for rust. are you saying I should skip the powder coat and just apply the bed liner? or triple up and do all three? I am more concerned with stuff rusting up here in NY than I have ever been in my whole life haha
Old 08-08-2012, 03:34 PM   #7
Pugga's Avatar
If everything is applied correctly, I think the powdercoat is a waste of money (personally, I think the zinc coating is also but that's just my opinion and if you live near salt water, added protection isn't a bad thing). A zinc coating, a compatable primer and a good coating of bedliner will be all you'll need. Just make sure you let the primer fully cure before applying the bedliner and ask the zinc plater what he would recommend for paint (to make sure Rustoleum will stick and how to prep the zinc plating).
Honestly, if the bedliner holds up, nothing below it should ever see the elements. If you scrape them over rocks, you will need to recoat regardless of what you do or they will rust.
Old 08-08-2012, 03:43 PM   #8
she'll ride
nut's Avatar
Navy: AC3 (Vet)
yeah the zinc is a must up in this salty sht hole . I might just prime/undercoat. You have a valid argument
Old 08-08-2012, 03:56 PM   #9
she'll ride
nut's Avatar
Navy: AC3 (Vet)
Originally Posted by wolfpack_5150 View Post
Powdercoating sliders is like tire gloss on the TREAD part of tires......
Ur gunna have chips from road debris even if u never offroad....as for the bottom and bedliner....I dunno.....I get chips on the middle section of the legs and the bars inside of the sliders. Ur gunna have to liner the entire legs, the entire bars that connect the outer slider bar to the inner piece.....may as well just line the whole thing for traction too...
I use textured spray on the sliders so girls, and others who use sliders as "steps" don't slip....which I never understood, my foot has to be raised just as much to use the slider, as it does to set my foot on the floorboard...well, within an inch or so.
good point, I thought about getting the powder coat and bedlining the whole thing top to bottom for the same reason. i know the powdercoat is a bit excessive in that application, but i just dont want to worry about rust. do you think just zinc/rustoleum liner are good enough as long as i watch the bottom for bare metal?
edit: and if i do just line the bottom, i would do everything on the bottom
Old 08-08-2012, 04:07 PM   #10
she'll ride
nut's Avatar
Navy: AC3 (Vet)
bare steel prepped with rustoleum primer, and rustoleum paint has worked well for me, but YMMV.......I guess theres 2 way to look at it
1. better safe than sorry
2. touchup is fast, cheap and simple.
is there a wrong way?
prolly not
a more expensive way........indeed
its your money, and if u can afford and justify bomb proofing ur sliders, then by all means go for it.....Its a great investment, and much cheaper than body work from flying doors even if u dont leave the pavement.
I spent $30K on the truck, so to spend $200 on powdercoating and another $30 on bedliner seems like a good investment for protection, to me at least all my mod money is from you taxpayers (GI Bill money) so thanks
Old 08-08-2012, 04:09 PM   #11
Adventurer
ffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shedffdawson is one of the sharper tools in the shed
ffdawson's Avatar
Firefighter:
ffdawson's Tacoma Gallery
3 solid coats of self etching primer, followed by 3 solid coats of Bedliner. Tough enough for mall crawling, rust-free and easy to touch up. Problem with PC is that if you ever DO use your sliders for their intended purpose, it'll scratch right off just like any paint/bedliner etc.
Here's mine before install. No problems yet. (minor trail use... no salty east coast roads...)
bare
primed
'Liner'ed
Old 08-08-2012, 06:13 PM   #12
AaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shedAaronArf is one of the sharper tools in the shed
AaronArf's Avatar
Navy:
AaronArf's Tacoma Gallery
Prime them and get them coated with Line-X premium.
Old 08-09-2012, 09:26 AM   #13
she'll ride
nut's Avatar
Navy: AC3 (Vet)
good point.
I pay myself ironically, as well as other taxpayers
and no SS
thank you for your service
haha thanks!
i was quoted $250 a piece for line x, that was my original plan until they told me that price
Powder coating an Ammo Can? Bed storage help... AlphaEcho2k5 Garage / Workshop 14 01-05-2012 07:01 AM
powder coating question ckeeton 2nd Gen. Tacomas 8 01-16-2011 07:40 PM
Rustoleum Truck Bed Coating Spray on Toyota OEM Tube Steps joe812 2nd Gen. Tacomas 13 11-17-2010 02:47 PM
Powder Coating Question braggman7 2nd Gen. Tacomas 1 12-15-2009 06:42 PM
Rustoleum Truck Bed Coating Spray tacomaatw 2nd Gen. Tacomas 2 09-29-2009 08:38 PM
