Irregular Tire Wear - Thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USAF Retired, Aug 14, 2012.
  1. Aug 14, 2012 at 6:06 AM
    USAF Retired
    USAF Retired [OP] Well-Known Member
    Alabama
    2009 Taco Sport 4X2
    TonnoPro Tri-Fold Tonneau Cover on order, 35% tint, Westin chrome nerf bars, Vent Visors
    The 09 Access Cab Sport I bought a few weeks ago was in pristine condition.
    Now, this is my fault - with only about 24,000 miles, I paid little attention to the tires. Not good planning there.
    Washing it carefully this weekend, I noticed irregular wear on the outer tread of the two front tires. I don't know what brand was originally on the Taco when sold new, but the tires on there now are Dunlops but the warranty booklet still inside the owner's manual is for Goodyear.
    I've contacted the guy who sold me the truck asking, basically WTF is wrong with the wear on the tires? Likely not the original tires, or they weren't rotated properly.
    My question (finally!) is if he agrees to replace the tires (which based on my being a long-term customer), he's likely to do (or at a significant discount), what do y'all think caused this wear? I'm not sure of the mechanical term(s)...camber...toe-in?
    Truck drives straight...doesn't appear to be out of alignment.
    Thoughts? Thanks.
  2. Aug 14, 2012 at 6:10 AM
    98tacoma27
    Ben
    Not Beech Creek
    Too much postive camber would be my guess.
  3. Aug 14, 2012 at 6:10 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you haven't rotated the tires, that's going to happen. The wear on the outside edge is from cornering which is why you should rotate your tires every 5k miles.
    Also, those tires don't have a lot of life left in them anyways. They're going to need to be replaced within the next 5k miles most likely (maybe 10k if you're lucky and don't have to go through winter with them).
  4. Aug 14, 2012 at 6:11 AM
    DigB
    DigB Go Jets GO!!!!!!
    Winnipeg
    DCLB TRD Sport
    Air Freshener mod
  5. Aug 14, 2012 at 6:12 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    Could be low tire pressure, not rotating, alignment.
    or a combination of all.
  6. Aug 14, 2012 at 6:13 AM
    Nick54
    Nick54 Well-Known Member
    Nick
    Mentor Ohio
    2010 Tacoma TRD Sport
    ARB Rear Locker & Compressor, Bakflip F1, Antennex 13" flexable antenna, WeatherTech Floor Liners, WeatherTech Side Window Visors, Tacoma Bed Mat, Demello Rock Crushers, Dynamax Ultraflow SS Muffler, TSB 4-Pak Leaf Springs, AFE Pro Dry Filter, Redline Hood Struts, Color Matched Angry Eyelids, Combo Lock Bed Compartments, Bed Mat, Pop-N-Lock, Wet Okoles, Goodyear Duratracs on ProComp 7033's, M101A2 Trailer, Grillcraft Mesh Grill, Light Racing UCA's, King OEM Performance Remote Reservoir Adjustable Front & Rear Shocks, JVC NT3HDT, Blue Sea Aux Fuse Panel, BAMF Behind Grill Light Bracket, Kragen 55W 7" HID's, CBI Front Receiver, Home Link Garage Door Opener, FlyEyez Light Unit, Bud Built Front to Back Skids...
    Its likely to much positive camber causing outside edge tire ware, conversely, negative camber will result in inside edge ware.
  7. Aug 14, 2012 at 6:24 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Go get it aligned. If the camber is off, you know the cause and can move on, if the camber is not off you know to keep looking.
  8. Aug 14, 2012 at 6:30 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The tires look old....and ready for replacement.
    I've seen 'odd' wear on old tires before.
    When you buy new tires - just make sure you get an allignment done.
    You could also inspect your balljoints on the a-arms.
  9. Aug 14, 2012 at 7:56 AM
    USAF Retired
    Alabama
    2009 Taco Sport 4X2
    As usual, great responses....told me exactly what I needed to know.
    Thanks!
