cb install location?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by apoteker, Aug 29, 2012.
  1. Aug 29, 2012 at 8:18 AM
    apoteker
    apoteker [OP] Well-Known Member
    2012 DCSB O/R debadged
    JBL/Entune Touchscreen Navigation with speed sensor override mod, JBL Speaker refit, debadged, chime removed, overhead led mod, switch LED mod, rear cupholder LED mod, ImMrYo Rear-View Mirror Lift Bracket #339, Custom Cobra CB install, Iggy Switch panel, OEM Katzkin leather seats, Seat heaters, Illuminated 4runner 4WD switch, 4runner side mirrors (heated, turnsignals, puddle lamps), husky x-act fit floor mats, climate control knob upgrade, air injection pump filter mod, underhood LED light mod, KB Voodoo bike bar
    hey all
    i want to install a cb radio and i wonder if there is room behind the
    INSTRUMENT LOWER COVER SUB-ASSEMBLY if i remove that and notch it for a cb to fit or is there a bunch of crap behind there
    anyone have pics or thoughts on this>?
  2. Aug 29, 2012 at 8:33 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    If you mean that spot just ahead of my stick shift in this picture :
    No, there really isn't a lot of room there. if you have a smaller CB, maybe, depending. The crash/airbag computer is located there and the center supports for the dashboard. It's pretty small.
    I ended up mounting my CB on the side of the center console.
  3. Aug 29, 2012 at 8:41 AM
    tacoman00
    tacoman00 Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    I mounted mine on the back of the center console facing upwards. Its in the backseat but still reachable and stays out of the way
  4. Aug 29, 2012 at 12:10 PM
    apoteker
    yes thats the spot
    sucks theres not more room there
    blech
    i'll have to figure out a different location
  5. Aug 29, 2012 at 12:36 PM
    BradyT88
    BradyT88 Well-Known Member
    I mounted mine inside the center console, but apparently I don't have a pic of it on the computer so I will have to show it to you later.
    Edit: Took a pic
  6. Aug 29, 2012 at 12:41 PM
    ssmith29440
    ssmith29440 Well-Known Member
    Steve
    2012 Tacoma TxPro Trd
    A friend of mine has a cb where the volume and channel adjuststment is on the mic.the main box is located behind his seat. The only thing is to find a place to mount the mic. Dont know if they are still made. Its worth looking into.
  7. Aug 29, 2012 at 12:45 PM
    trdNick
    trdNick Odie
    Texas
    2020 Ram 1500 4x4 5.7 Hemi BigHorn
    It will fit there with a ton of soldering work haha
  8. Aug 29, 2012 at 2:02 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    Another cool option might be to change your radio to an aftermarket single din, then use the open space on a double din adapter to hold the radio. Just thinking out loud since I was considering a radio swap too.
  9. Aug 29, 2012 at 2:03 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Specalt did that on here. It does fit if you have a smaller model CB.
  10. Aug 29, 2012 at 2:07 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
  11. Aug 29, 2012 at 3:25 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I put mine here....
    Super easy install and easy to reach.
  12. Aug 29, 2012 at 7:24 PM
    Mtyoda
    Mtyoda Member
    Brandon
    Montana
    07 Tacoma trd
    Bilstien 5100's in the front and 2" aal in the rear
    Dragons taco, that's a great place to put a CB. The only downfall is that u can't put a big radio in.
  13. Aug 29, 2012 at 7:39 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  14. Aug 29, 2012 at 7:42 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    Just get a cobra 75 wxstv and mount it anywhere!
  15. Aug 29, 2012 at 7:51 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    :eek: you going for the plane cockpit look?
    That truck would be broken into and stripped in my city in a NY second. I keep my electronics hidden for that reason. Of course most don't live in a crime ridden shit hole like me.
    My cb is in my center consul. When not in use no one has a clue. I also stuffed my SWR and aux speaker in there.
    OP just put it where it's best for you and think it out. I sat my ass in my seat and stared at my truck for 20 minutes before deciding. The main object is usability followed by a professional looking installation. I see way to many hack jobs when installing CB's. Please keep them away fro your legs or your passengers legs if you value their safety in an accident.
  16. Aug 30, 2012 at 10:13 AM
    Dragons Taco
    Derek
    Cary/Raleigh NC
    OMG, havent seen that many electronics facing a driver since I was in a Japanese taxi.
    And to think you can't "text message" cuz that would be a "distraction" but all of that's legal.
  17. Aug 30, 2012 at 10:16 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    This is the CB I have as well because it can be easily hooked up and put anywhere and easily removable and can be put away. I keep mine in the center console when not in use.
  18. Aug 30, 2012 at 4:31 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Just Installed mine last weekend. Uniden 520xl with a 20w external speaker under the seat facing up. Fits perfectoy and is nice and hidden.
  19. Aug 30, 2012 at 4:42 PM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Did you drill through the bottom to get the antenna cable to go out somewhere? Also, you'll need to run an external speaker or that thing will be muffled as all hell if you close the armrest.
  20. Aug 30, 2012 at 4:50 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yeah I drilled out the bottom and ran It under the carpet and through the rubber grommet under the drivers seat. And I do have an external speaker. It's under the seat facing up
