Fog Light kit for 2012 tacoma
Old 09-08-2012, 10:00 AM   #1
philvonville is on a distinguished road
philvonville's Tacoma Gallery
I need a fog light kit for my 2012 Tacoma prerunner dbl cab 4cyl. I ordered several times and something was always wrong with kit. From whom can i order the correct kit? I already ordered from Amazon twice and K2 Motors. I am not wanting to spend more than $150 dollars.
Does the 2012 Tacoma have a different sized fog light than the previous models?
Please, no guessing or assumptions, only facts !!
Old 09-08-2012, 10:17 AM   #2
Faryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shedFaryota is one of the sharper tools in the shed
Faryota's Avatar
Faryota's Tacoma Gallery
Check out "Dash Z Racing Products"...
Old 09-08-2012, 04:27 PM   #3
MBTacoma12 is on a distinguished road
MBTacoma12's Tacoma Gallery
I ordered one from eBay, it was for 2012 Camry fit good with slight modification........cutting tabs. Came with everything including the switch, switch that came fit fine in center stack under AC controls
Old 09-08-2012, 04:39 PM   #4
Spruce Juice is on a distinguished road
Spruce Juice's Avatar
Spruce Juice's Tacoma Gallery
Do a search on eBay for '11 12 Sienna JDM Fog Lamps'. I bought these upon returning the Camry ones. The Sienna Fogs went onto my Taco without any modification of tabs.
Old 09-09-2012, 06:56 PM   #6
Sienna Fog light switch
Thanks for feedback for the substitute fog light for my Tacoma. Did the Sienna 11', 12' dash on/off switch fit into the knock-out openings on dash with no modification?
Also, did you Tacoma come prewired for fogs?
Old 09-09-2012, 09:19 PM   #7
I have not wired them up yet. So far I only installed the lamps into the bumper tabs. No, my Regular cab is not pre-wired so I'm taking my dear time. As for the switch, the kit comes with a switch that will mount in the centre part of the lower dash where the AUX jack is. However, while I've read that some people on this Forum has successfully utilized that switch and space, I've also read that there is only limited space in behind that area and that the switch would not sit flush as the back of it will intrude on something inside the dash. I measured my switch and it looks like I will require 2.25" of clearance behind the hole in order for the switch to sit flush on the dash.
If I need to buy a switch, I will go for a 'switch kit' from Vandergriff Toyota @ $77. It consists of PT297-35070-AS & PT297-35070-SH which is the factory fog light switch from a FJ and the dogtail harness. Apparently, I will not be able to find a dogtail to go with the stock Tacoma fog light switch.
Is your truck pre-wired?
Old 09-09-2012, 10:48 PM   #8
Throbbing Member
B737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shedB737 is one of the sharper tools in the shed
B737's Avatar
B737's Tacoma Gallery
you can buy the 2012 switch at the dealer (2012 switch is back lit green), then you can buy the fog light harness and a pigtail on ebay. use the proper factory location on the upper left side of the dash, its very easy to get to. the switch schematics are on TW.
his truck might be pre-wired cause its a dbl cab
his truck might not be pre-wired cause its a 4cyl
Old 09-10-2012, 05:47 AM   #9
2012 Tacoma (Taco) Fog Lights update
Thanks all so far on your input. I ordered a 2011/12 Sienna fog light set form Ebay. It was the: 11 12 TOYOTA SIENNA LE JDM BUMPER CHROME FOG LIGHT LAMP+6000K HID+SWITCH+HARNESS
When I get the set, I will left you guys know my results. I will give you the details of how things fit like the fog lights them self, the wiring and the switch in the dash. I was tempted to get the 8000k lamps but I didn't know the affect of the brightness to on coming vehicles.
Old 09-10-2012, 08:44 AM   #10
swaggerton is on a distinguished road
swaggerton's Tacoma Gallery
Subbing for your follow-up. Thanks OP
Old 09-10-2012, 09:44 AM   #11
Throbbing Member
B737's Avatar
that switch will not fit the stock fog location.
regarding room and access to the stock location...
there is ample room behind the switch. access to the switch is best had by removing the instrument cluster. it can be done from under, but you'll have to pull lower panel as well, and it'll be tight. as shown in this photo of my truck, there is a plastic horizontal piece (under the vent) that protrudes under the stock fog switch location blocking easy access from below.
if you want to the switch to drop in, like from the factory, then buy the 2012 fog switch... part # 84160-04020 and the fog pigtail sold on ebay
Old 09-11-2012, 06:33 AM   #12
Alright, I think my search has finally ended for finding a fog light kits for my 2012 Tacoma. This is the most I have paid for the kit but the promise is that this is the OEM kit that fits. The Sienna fog light was a bust because I need to find the correct switch for the dash that cost more money. When I receive this kit below, you will here about my results. Here is the link for the Ebay page:
http://www.ebay.com/itm/110949107461...witem=&vxp=mtr
Fog Lights / Lamps Kit for Toyota Tacoma 2012
Fits in factory Location
Adjustment for light beam direction
The kit is a direct bolt OEM replacement Fit
Kit Includes Two Fog Lights with Bulbs, OEM like switch and wiring.
These Fog lamps will fit any Toyota Tacoma 2012. The kit is a direct bolt OEM replacement Fit. It includes adjustment for light beam direction and a replacement OEM LED switch that will fit in the FACTORY location it also includes a OEM plugs and Taps so no cutting is needed. This basically will fit, look and work just like the ones that come with the truck at a fraction of the cost.
SATISFACTION GUARANTEE.
Old 09-11-2012, 05:28 PM   #13
Fog lamps will fit any Toyota Tacoma 2012. The kit is a direct bolt OEM replacement Fit. It includes adjustment for light beam direction and a replacement OEM LED switch that will fit in the FACTORY location it also includes a OEM plugs and Taps so no cutting is needed. This basically will fit, look and work just like the ones that come with the truck at a fraction of the cost.[/SIZE]
[/SIZE][/FONT]
Yeah, I am super keen to know how this kit works out for you. The price isn't bad if it's more or less plug n play. I look at the switch which is described as 'OEM' and yet the corners of the switch look to be more angular than the stock switch. Click onto link. It's the only piece that I don't know about.
This is what I'll have to purchase to go along with the Sienna kit:
http://www.toyotatrdparts.com/script...?idProduct=-59
This, assuming I cannot utilize the switch from the kit which I think might mount beside the 12V power plug-ins.
Old 09-12-2012, 07:35 AM   #14
Faryota's Avatar
I bought the Dash Z kit...it was super easy to install...I did NOT have to remove the dash at all...just popped out switch cover...Dash Z switch looks pretty factory like...maybe not perfect but very close...my truck was not pre-wired and the kit had every thing I needed!! Plus lights can be on any time the power/key is on! I have since installed them on two other trucks and that went even faster!!!! They are not LED but you do have a choice of a couple size bulbs!!! I am very happy and all for $165.00!!!!!!!!!!!!!!!1
Old 09-12-2012, 07:57 AM   #15
Throbbing Member
B737's Avatar
that switch will not fit the factory dash location. it is different from the OE fog light switch. it MIGHT fit (as stated above) in the "dealer retrofit" location next to the 12volt outlet.
the factory dash location is 'keyed' to only accept the correct part number switch, the switch has protrusions on the side, that slide into cut outs in the opening. meaning you cant put the fog switch into the inverter spot, or vice versa. i installed an additional fog switch for my rear lights next to the OE one, and had to file down a few spots so it would plug in.
@ Faryota,
im curious how you got the blanks that were to the left of the drivers side, top row, to simply "pull out"? mine had locking tabs on them that both needed to be depressed at the same time, plus, the plastic support that blocks access to the top row below the left vent...
if your referring to the plugs located to the left of the 12 volt outlet, im curious to as well...
Old 09-13-2012, 06:31 AM   #16
I talked to the dealer yesterday about the most resent set of 2012 Tacoma fog lights I ordered. It turns out that he has been the same dealer on eBay but with different company names. He fully understands our delimma with the lights and the switch. He has an 06 tundra and just installed the lights with the relay and then used a T-shank to connect to the low beam lights in the fuse compartment under the hood. He didn't even bother with an on and off switch inside the cabin. In a way, this makes scents, I don't usually turn my fogs on and off. I leave mine on when my lights are on. I don't really need a on/off switch. The install is much simpler and the fog light come on when you need them. Bottom line, my 1st set I ordered of 5 so far would have worked perfectly with an install without an on/off switch and wired direct to low beam engine compartment fuse box. Is it factory; on the outside yes, under the hood, it just depends on how well you work the wiring.
Old 09-19-2012, 12:20 AM   #17
5150Bronco is on a distinguished road
5150Bronco's Tacoma Gallery
1) Has anybody succeeded with the ebay light OEM setup?
2) Does this same setup or another work for 2013 tacoma too?
Old 09-19-2012, 07:03 PM   #18
Yes, the Fog Lights / Lamps Kit for Toyota Tacoma 2012 fog light set on Ebay does indeed fit the 2012 and 2013 toyota Tacoma. The set I bought on ebay was $169. Maxliner was the dealer. He raised his price $20. Profit is not a dirty word. But at least this set fits with no modifications. Even the switch fits into the dash knockout to the left of the steering wheel.
Old 09-19-2012, 07:08 PM   #19
Throbbing Member
B737's Avatar
read the thread. i fit the the $59 Camry lights into my 2012 with no problem. work great. ditch the cheesy switch these guys are selling and use the factory OE switch in its proper location...
FS: FJ Fog light switch and fog light wiring kit Priddle 2nd Gen Tacoma Marketplace 7 05-20-2013 08:45 AM
2012 Tacoma Fog Light Plug Rotorheader 2nd Gen. Tacomas 18 09-18-2012 08:47 PM
2012 Tacoma Aftermarket OEM Fog Light Kit AABoucher Lighting 22 09-08-2012 10:07 AM
Tacoma fog light kit with OEM switch & harness pauldotcom Buy / Sell / Trade 10 01-12-2012 02:09 PM
2012 Fog light HID kit? knine00 Lighting 7 01-02-2012 04:46 PM
