TRD Cold Air Intake/Mass Air Flow Sensor/Check Engine Light Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FrijolPower, Sep 17, 2012.
  1. Sep 17, 2012 at 3:17 PM
    FrijolPower
    FrijolPower [OP] Member
    Manuel
    Colorado
    2013 Sport
    First of all, some background on my truck, I have a 2008 Double Cab with the TRD Off Road Package and the 4.0 V6. I have done a couple upgrades, the relevant ones are a TRD Catback (about 2 and a half years ago) and a TRD Cold Air Intake (about 2 years ago).
    About 4 months ago my "Check Engine" light turned on, I immediately took it to the dealer so they could run a diagnostic and tell me what was wrong with it.
    The code came back a problem with the Mass Air Flow Sensor. A new Mass Air Flow Sensor and $300 later I was on my way.
    About 2 months later my "Check Engine" light turned on again. Again that same day drove down to the dealer to have it checked out (and enjoy the warranty on their service), the diagnostic code was Mass Air Flow Sensor. Since they couldn't find anything else wrong with it they assumed it was defective, and swapped it out - for free this time.
    About a month and a half later, again, my "Check Engine" light turned on, so again, I reluctantly drive down to the same dealer, hopefully it was covered by their service warranty again. Again the diagnostic code came back as Mass Air Flow Sensor, but this time they say when I cleaned my TRD Cold Air Intake filter I must have used too much oil and it had blown on the sensor causing a short. In other words, they swapped out the Mass Air Flow Sensor for a quick $250 and instructed me to go home and reclean out the filter and use less oil this time. So I did.
    About 2 weeks later (can you guess what happens next?) my "Check Engine" light turns on... again, and again I drive down to the same dealer - I must be a glutton for misery. The diagnostic - Mass Air Flow Sensor. This time they keep my truck for 2 and a half days, ran every test and monitor they had available. They couldn't find anything wrong with the Mass Air Flow Sensor. They suspected something is wrong with my TRD Cold Air Intake, so for a test, they swapped it out with a stock and found that it "solved" the problem. So what they found was I was triggering a CODE P0101 - "MASS AIRFLOW CIRCUIT RANGE/PERFORMANCE PROBLEM." What they tell me, my TRD Cold Air Intake is messing with the air/fuel ratio. The normal Long Fuel Trim Percentages are 5.5 to 8.5, with my TRD Cold Air Intake I run at 19.5 to 22.5, which is still under the max allowed of 30, but there are instances when it spikes above 30, triggering the Code P101 and my "Check Engine" light.
    Their recommendation? Swap out my TRD Cold Air Intake for a stock, or buy a new TRD Cold Air Intake, or run it as is since they cleaned everything out really good and it might have "fixed" it.
    I am still not comfortable with what they are telling me. I have had my TRD Cold Air Intake for about 2 years and have never had a problem, so my question is has anybody else ran into similar issues, if so what did you do? Or if you haven't but have some insight on what is really going let me know.
    Thank you!
    M
    Hotrodroxie likes this.
  2. Jan 27, 2013 at 6:32 PM
    momsintruder
    momsintruder Member
    nc
    2001 4 door trd tacoma
    yeah I'm having the same problem with my 3.4 I have caused from know and it keeps a code po 0171 lean code and I put my stock back on and it clears up but the gas mileage is so much better with the a cai I want to keep it but no answers for me either. if u find out let me know.
  3. Jan 27, 2013 at 8:15 PM
    BamaToy1997
    Bill
    Navarre, FL
    First thing I will say, is that a long term fuel trim of +5.5 to +8.5 is STILL too high. You are showing to be running lean, even WITH their test. A MAF code can also be set because of unmetered air. Basically a vacuum leak. With a small LTFT of 5-8 it will be a small leak. That is what I am suggesting to look for first. After you get THAT part solved, I would look to see if the code returns, and go from there. Many CAI systems flow much better than factory air intakes, and this can cause the computer a bit of confusion because at "X" RPM, and "Y" engine load and "Z" air temperature, the computer expects to see a specific, preprogrammed airflow. IF the restriction in the air intake is lower than expected, it can set a MAF code.
    All of that aside, even a free-flowing intake system should not be running LTFT numbers in the 20s or 30s. I have run PLENTY of vehicles in my shop during diagnosis with unrestricted airflow, and none of them have EVER seen LTFT numbers like that. I think they are just looking at the code itself, and not looking at all the different problems that can set that code. A performance code is not a solid indicator that the sensor itself is bad. Personally I would never use a wet-CAI system. They are right that a wet-CAI system CAN cause premature failure of a MAF, as well as erroneous data, which CAN (Not always will) throw off FT numbers.
  4. Jan 27, 2013 at 8:19 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  5. Mar 14, 2013 at 7:49 PM
    FrijolPower
    Manuel
    Colorado
    2013 Sport
    Thanks for the help!
  6. Mar 21, 2013 at 6:36 PM
    toytaco1
    toytaco1 Well-Known Member
    jed
    moreno valley
    05 supercharged trd off road
    trd supercharger, TRD intake, magna flow exhaust, JBA headers, walker evans front, fox rear, leaf pack, drilled slotted rotors, All Pro Front Bumper, Warn 8000 Winch
    I had to drill holes on mine but def a fail on TRD's part
  7. Jul 30, 2014 at 12:53 AM
    TRDh4vok
    TRDh4vok Well-Known Member
    Gil
    Palm Beach County
    '09 TRD PreRunner Sport
    -4" MaxTrac Spindle lift -5100 RCD Bilstein's -1/2" Strut Spacer driver's side (Taco Lean fix) -1/4" Strut Spacer passenger side (Taco Lean fix) -4" Tapered Blocks -Extended length U bolts -Front Skid Plate -Exhaust Tip -Tube Steps - Silver -Bed Extender -LEER Tonneau Cover -Rampage Roof Cab Lights -Rampage Tailgate Light Bar Six Function SUPERBRITE with Reverse Lights, Running Lights, Brake lights, Emergency Hazard and L & R turn signals -exLED Toyota Tacoma Custom interior LED Light Kit -PIAA Xtreme White Plus head lights and fog lights -NITTO Terra Grapplers 285-70-17 -30" Avec CR-Series Led Light Bar in bumper grill -Two 6.5" Led light bar's attached to the A pillars -Hood hinge bracket mounts from Famous Fabrications -Exhaust muffler Aero Turbine AT2525XL -OEM Roof Racks -OTTRAW Rocker switch -Stant locking gas cap -Large T emblem and mid mount bracket from Diaz Fabrications
    Sub'ed
  8. Jul 30, 2014 at 5:05 AM
    D4D Hilux Dude
    D4D Hilux Dude Well-Known Member
    Darren
    Arvada, CO
    2011 4x4 Double Cab TRD Offroad
    TRD Supercharger TRD Catback Exhaust Ziebart Rust Proofing Additional Bed Ties 2012 Indicator side mirrors
    I had the same problem, however I have the TRD supercharger installed.
    Toyota told me to keep the stock air filter as the CAI is not compatible with the S/C.
    I did not try cutting the intake as shown in the video though... not keen on cutting stuff up if its not guarenteed to work.
  9. Dec 6, 2014 at 6:06 PM
    Mevadus
    Mevadus Active Member
    2018 Toyota Tacoma SR DCSB 4x4 MGM
    Has anyone confirmed that removing this portion of tubing will indeed prevent a check engine light? I installed my CAI today on my 2011 Tacoma, and already have a check engine light. I put a small scribe in each hole with the hose installed correctly, and nothing seemed to be blocking the holes internally. I thought that was the issue which would be resolved by cutting out that section of hose. Should I cut the hose anyways?
  10. Jul 8, 2016 at 10:38 AM
    nolajefe
    nolajefe New Member
    Jeff
    New Orleans
    2006 PreRunner
    Mid Travel Total Chaos kit upper arm and Fox Coil-overs. Deavers in the rear with Fox shocks 456's for gearing 33x12.50R20ET open country toyo mt with BMF 20' Rims and a K&N intake.
    I am having the same problem with the TRD intake. I have ran the intake for about a year and never had a problem with a light coming on. I did have the head gasket come out of the truck last month. I am having the problems with light and running lean now. I am over it I am looking for a stock air box.
  11. Jul 8, 2016 at 10:52 AM
    eon_blue
    eon_blue Most Improved Member
    Check for vacuum leaks. The same code that gets set off for your MAF sensor can also be due to a leak somewhere or disconnected hose. Also possibly a bad air /fuel sensor or exhaust leak, though usually less likely
