Help!!! How to adjust H1 mini's Retrofit
Old 09-23-2012, 09:40 PM   #1
Cruise
TheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shedTheSmash133 is one of the sharper tools in the shed
TheSmash133's Avatar
TheSmash133's Tacoma Gallery
I just got my H1 Mini's installed today and they are pointed a little to high for my taste. How to I level both of them and make them point down??
Old 09-23-2012, 09:47 PM   #4
TACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shedTACOMABOSS is one of the sharper tools in the shed
Firefighter:
TACOMABOSS's Tacoma Gallery
Originally Posted by Konaborne View Post
The same way you adjust your headlights normally, the adjustment tabs/screws on the back of the headlight assembly
X2
Old 09-23-2012, 11:48 PM   #5
Cruise
The knobs are really hard to turn.... I'll get the hang out of it but, I think I need to adjust the actual projectors/bulbs. The light output just looks off.... I'll post some pics soon
Old 09-23-2012, 11:49 PM   #6
Firefighter:
I dont think its even possible to adjust just the projector. only the headlight housing
Old 09-23-2012, 11:50 PM   #7
Vivid Illumination
memario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shed
memario1214's Avatar
memario1214's Tacoma Gallery
Post some pics and I'll let you know what to do. You could have either installed them wrong or else you just need some dial adjustment. Sometimes you need to pretty much back them all the way out and then screw them back in to get the right adjustment. They get all bound up
Old 09-23-2012, 11:57 PM   #9
Cruise
This is standing right next to the front left tire, sorry for the poor picture. Again though, bottom left portion
Old 09-24-2012, 12:02 AM   #11
Cruise
Originally Posted by TACOMABOSS View Post
That sort of circular dark spot?
yessir
Old 09-24-2012, 12:02 AM   #12
Firefighter:
yessir
Thats really weird. Its almost like something is on the projector or something good luck OP
Old 09-24-2012, 12:03 AM   #13
Vivid Illumination
Haha a pic against a wall would make things a whole lot easier... But that circle instinctively tells me that the bulb is seated in the projector incorrectly
Old 09-24-2012, 12:06 AM   #14
Cruise
Ughhhhhhhh yea it looks like you guys are right.....
Old 09-24-2012, 12:08 AM   #15
Cruise
So I would have to play with the bulb correct?
Old 09-24-2012, 12:12 AM   #16
Vivid Illumination
So... Since they are all put together now I assume I recommend that you do this. Remove the headlight and the bulb. Take a very bright flashlight to the back of the projector and shine it towards a light colored wall. This will tell us whether or not there is something wrong with the projector or if the bulb is seated incorrectly (maybe both). Or you could just try and adjust the bulb by unscrewing the twisty things that hold it in place and moving it around trying to get it seated correctly. Your beam should look like this:
Old 09-24-2012, 12:28 AM   #17
Cruise
I tried messing with the bulb but had no luck. I just took off the rubber boot and tried twisting it but no luck.... I'm gonna go try again
Old 09-24-2012, 12:39 AM   #18
Cruise
I tried to disconnect the bulb from the wiring but I just couldn't get. I need smaller hands...
1st Gen Retrofit Walkthrough: Morimoto Mini H1 Konaborne 1st Gen. Tacomas 218 01-14-2015 07:32 PM
Mini H1 retrofit REDTRD Lighting 68 02-24-2014 08:05 PM
How to adjust H1 mini's Retrofit TheSmash133 Lighting 3 09-24-2012 08:08 AM
Mini H1's from TRS snowgod06 Lighting 3 01-20-2012 11:37 AM
Feeler: 01-04 Headlights w/ Morimoto Mini H1 Projector Retrofit orieo Buy / Sell / Trade 17 02-24-2011 08:34 AM
