Replace my DRL's bulbs with LED's ones
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Oct 4, 2012.
  1. Oct 4, 2012 at 1:55 AM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
  2. Oct 4, 2012 at 12:56 PM
    bra
    Badges off
    Or maybe you got another website I can purchase some good leds? :confused:
  3. Oct 4, 2012 at 1:01 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '12 DCSB 4x4 SR5
  4. Oct 4, 2012 at 1:46 PM
    bra
    Badges off
    Oh thanks so much
  5. Oct 4, 2012 at 2:37 PM
    nschmittsd
    nschmittsd Well-Known Member
    Nick
    Chula Vista
    07 prerunner tacoma double cab
    procomp helldorado rims bilstein 5100 goodyear ats hid/led whole truck
    i have switchback leds in mine AEF90848-32C6-410C-BDED-294B25218CF0-164_b3e851407367d51b14c956a46345b6336721ef54.jpg
  6. Oct 4, 2012 at 3:16 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
  7. Jan 12, 2013 at 7:02 AM
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    So I'm looking to do the same thing now , do they have to be switch back or can I put regular LEDs ?
    Reason I ask is I have some that are the same buld type from a previous project . Can I throw them in or will they not las since they aren't switch backs .
  8. Jan 12, 2013 at 7:09 AM
    wacked
    wacked Well-Known Member
    Katy, Tx
    2013 Tacoma Prerunner
    There is also the new option from V-LED, the V3 Triton, they even have a switchback option. They are kind of pricey but they are new so pricing may trend down after they are on the market a while.
  9. Oct 25, 2014 at 12:17 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    adding my experience to this thread...
    i purchased a popular exterior LED kit for all the lamps on my truck. i was happy with them all except for the DTRL. the LEDs filled the bowl with amber but that was about it. they were about half the brightness of our stock incandescent DTRL / flashers. The resistors were also super hot all of the time, which bugged me a little.
    I ordered the "Amber / Amber V3 Triton" kit. i called them to verify the right socket adapter and it needs to the "CK" one. The guys were super knowledgeable of their product, it gave me a good feeling.
    the kit is really well put together. the control box is sealed up nice. all the connections are weather resistant and feel like good quality.
    One of the things i learned speaking with them was that unlike running regular LEDs where the resistors are on 100% of time, with these kits the resistors are only 'on' when the signal function is active. which means the control unit isnt baking and there's no super hot resistors on all the time under your hood.
    if you want to run your own resistors you can do that too, but it makes sense to use the ones built into the control unit. another nice option, is you can tie the control box into the low beam w a dedicated plug and the LEDs will dim when headlamps are on, just like stock function.
    Most importantly, with these rated at 430 Lumen, they are definitely as bright if not brighter than the stock DTRL. im super happy with them. they work fantastic, feel like great quality, hopefully the control units will last.
    its not a cheap kit, but given the alternatives... to me, it was well worth it.
    Photo with the regular LEDs that i wasnt too happy with...
    V3's on passenger side installed
    Both V3s installed
    SilverJack likes this.
  10. Oct 25, 2014 at 12:36 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
  11. Oct 25, 2014 at 12:43 PM
    B737
    Kevin
    Jersey Shore
    stock
    he posted that 2 years ago, i just wanted to add my experience into the thread without starting a new one....
  12. Oct 25, 2014 at 12:45 PM
    DR007
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    Oh oops. Didn't even look at the date stamp.
  13. Oct 25, 2014 at 12:47 PM
    B737
    Kevin
    Jersey Shore
    stock
    gotchya :)
  14. Nov 24, 2014 at 9:09 PM
    FastFebur
    FastFebur Well-Known Member
    Sacramento
    '08 Tacoma 4X4
    3" Rough Country lift 18" Fuel Wheels 33" Toyo
    is there any reason not to buy the cheaper 3157 LED bulbs off ebay?
  15. Nov 24, 2014 at 10:49 PM
    B737
    Kevin
    Jersey Shore
    stock
    The LED version? They super dim. Plus unless it's just the right bulb it'll short out either the signal or parking lamp circuit
    Every 3157ck I tried blew the fuse in one way or another. Except for csjumpers which worked well but are roughly half stock brightness and require full time load resistors.
  16. Nov 25, 2014 at 7:56 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    VLEDS Triton Switchback FTW.
  17. Nov 27, 2014 at 3:49 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    I have the 3157 CK from VLEDS, Amber replacement (didn't want switchbacks) , and they're the same brightness as the 4157nak oem bulb, at least by my comparison. Their claim is 170 lumens which is almost double superbright claim.
    No problem with blowing fuses; have to reverse them if they don't light first time.
    I only installed front leds dtrl; put the resistors in the harness on each REAR amber turn light socket. That way the load resistor is off during drl mode. 2 x 6 ohm load resistors if you want leds in the rear too, or change to one 3 ohm on each side.
    Did the front corner lights too and a couple for the high mount stop lamp.
    Works great!!
  18. Nov 27, 2014 at 3:57 PM
    1993t100
    1993t100 I’m good looking and I drive a Jeep.
    Big Sexy
    Nebraska
    Jeep Wrangler Rubicon
    I have 3157ck in the front and regular 3157 in the back of my 2012 Tacoma. I didn't blow any fuses :notsure:
    I have hyper flash but only because I REALLY don't want to install the resistors. I was so hoping someone would make a replacement 12-pin relay. You 2005-2011 guys have it easy haha
  19. Nov 27, 2014 at 4:22 PM
    B737
    Kevin
    Jersey Shore
    stock
    I think you guys misunderstood. The dude had asked what was wrong w the run of the mill eBay 3157s, I said they are dim. Vleds are a much brighter albeit more expensive system.
  20. Nov 27, 2014 at 4:50 PM
    Edgeplay
    Edgeplay Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    are vleds just plug and play?
