Fog Light Mod 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by m.reed.1, Oct 10, 2012.
  1. Jan 16, 2013 at 9:31 AM
    #81
    douglasmc
    douglasmc Active Member
    Ga
    2013 tacoma sport 4x4 V6
    Fog light mod, 12 volt power full time, inverter 400w full time, Added 115v outlets in cab, Trimmed off 4in from front mud flaps, more to come ;)
    Yea it will throw a code since the pump is an emissions part.. But it should clear itself out after you put it back in
  2. Jan 16, 2013 at 11:24 AM
    #82
    azchris
    azchris Well-Known Member
    Gilbert, AZ
    2013 Magnetic Grey Dbl Cab 4x4 TRD OffRoad
    Click sig for build thread
    That's too bad, I hate that air pump. My truck sounds like my old Chevy when I turn it on.
  3. Mar 19, 2013 at 5:17 PM
    #83
    13Tacoma
    13Tacoma Well-Known Member
    Colorado
    2013 TRD Off-Road Silver Streak DC
    Fog Light Mod, Debadged Tailgate, Blacked out Front Grill, Removed Front Mud Flaps, 3" Lift, 4" Quantum LED's mounted behind Lower Valence-Courtesy of Kmd Garage Group Buy.
    Hey Chris thanks! This mod worked great and only took a few minutes. Have always had a 4X4 but this is my first TACO. Previously owned 05 Cummins and 00 F250 7.3L.
  4. Mar 19, 2013 at 6:56 PM
    #84
    13Tacoma
    Colorado
    Pictures with the Fog Light Mod!
  5. Apr 15, 2013 at 5:42 PM
    #85
    Sargechris
    Sargechris Well-Known Member
    Oceanside, CA
    13 DCLB 4x4 TRD Sport/Tow Pyrite Mica
    BFG AT KO 265/70R17 Tires, SnugTop Sport Hi Liner, Yakima Racks / Load Warrior, WeatherTech Floor Liners, BedRug/BedMat
    I tried & tried.. but couldn't get the connector on the bent relay to fit between the plastic housing and the relay?? :confused: I tried the "inside" tab also--but that made the fog lamps stay on with the key...
    How in the world did you get the connector fit? (I have studied the pics, but must be very dense... :eek: )
  6. Apr 15, 2013 at 5:45 PM
    #86
    azchris
    Gilbert, AZ
    I put the crimp terminal on the relay tab with the relay outside of the box, and very slowly bent both the relay tab and the crimp terminal at the same time until the terminal went nearly straight up the side (like you see in the pic). Then I re-installed the relay and connected the other end of the wire to the AC SKT relay.
  7. Apr 15, 2013 at 6:22 PM
    #87
    Sargechris
    Oceanside, CA
    Thanks ! I was afraid to bend the tab more than 90*... I'll give it another go..
    :cheers:
  8. Apr 15, 2013 at 6:22 PM
    #88
    azchris
    Gilbert, AZ
    It'll go a bit further with a little persuasion... Just be slow & careful :p
  9. Apr 18, 2013 at 9:18 PM
    #89
    azchris
    Gilbert, AZ
  10. Jun 29, 2013 at 5:38 PM
    #90
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    I just did this and it works great, however:
    I have to make sure I manually click the foglights to go off or they dont go off when I take the key out.
    I can roll the windows up/down without the key in the ignition at all
    Lastly, The AC Inverter can work without the keys in the ignition at all.
    I have no problem clicking them off just making sure I am not draining my battery without knowing it, Is this occuring to you guys who did this wiring mod too?
  11. Jun 29, 2013 at 6:21 PM
    #91
    azchris
    Gilbert, AZ
    Nope, I leave the switch clicked in all the time without any of those effects. This should only give power to the fogs relay when the truck is running. Does this only occur with the wire mod? In other words, if you remove the mod, can you still use the AC inverter and windows with the key out?
  12. Jun 29, 2013 at 7:26 PM
    #92
    PnoyBOS5
    kevin
    CA
    2013 PRERUNNER
    Yeah it only occurs with the wire mod, I know because I put it back to stock.
    I just now redid it and its working fine and back to normal .. lol weird? Maybe user error... Thanks for the easy, clean, reversible mod!
  13. Jun 29, 2013 at 7:27 PM
    #93
    azchris
    Gilbert, AZ
    Probably just had a little strand of wire crossed onto one of the other terminals, I've done that before and had some pretty strange behavior.
    Yeah, I like this vs. running it under the fuse box because this can be taken out in two seconds for warranty work or whatever.
  14. Aug 14, 2013 at 3:18 PM
    #94
    Naholo808
    Naholo808 Well-Known Member
    Jordan
    9th Island (Las Vegas)
    2020 4Runner Off-Road
    2020 Toyota 4Runner Off-Road 3inch lift 33s Ko2s Matte black SCS SR8 2013 Tacoma TRD Sport 2wd - Traded In.
    Thanks for the tip!
  15. Sep 3, 2013 at 7:28 PM
    #95
    Naholo808
    Jordan
    Thanks 2006KJ!!
    8D8E046A-4723-4831-8F29-4F63533211B6-587_d56032e9cdce1d0884e8df44286ecd2d6436483f.jpg
    27A89151-E6D2-43CD-8F7C-4129644FE746-587_ba1b02f587cf5fe79109043b077b38e4803f22bd.jpg
  16. Sep 8, 2013 at 7:41 AM
    #96
    dand
    dand You can't see me
    Dan
    SE VA
    2021 DCSB TRD Sport Army Green
    Just checked mine. It has the wire clips that are in above pic,on the lower right. I guess that means this should be an easy mod :)
  17. Sep 11, 2013 at 2:06 AM
    #97
    Naholo808
    Jordan
    Did u install the mod?
  18. Sep 11, 2013 at 5:20 AM
    #98
    dand
    Dan
    SE VA
    Not yet, don't have the materials or time atm.Hopefully this weekend.
  19. Oct 13, 2013 at 3:48 PM
    #99
    Pan704
    Pan704 Active Member
    Rich
    Charlotte, NC
    PreRunner SR5
    Love this mod. My only problem is other drivers flashing their lights at me like I have my brights on
  20. Oct 14, 2013 at 1:51 PM
    #100
    cowman71
    cowman71 Member
    Central Texas
    '13 AC 4x4 base, Convenience and Tow Pkg.
    Has anyone tried removing the bottom of the auxiliary relay box and replacing the wire that goes to the relay tab that some of you are bending up? Then you could reroute a wire through the bottom of the box to the green wire in the main relay box. I haven't tried it to replace the relay plug wire but I know the relay box pops off easily and so does the bottom portion that the wiring harness goes into. I am wary of bending that relay leg.
