Fog Light Mod 2013
Discussion in '2nd Gen. Tacomas (2005-2015)' started by m.reed.1, Oct 10, 2012.
  1. Oct 10, 2012 at 12:12 PM
    m.reed.1
    m.reed.1 [OP] Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    has anyone tried the foglight anytime mod for the 2013, i cant exactly figure it out. thanks!
  2. Oct 10, 2012 at 12:14 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    It's the same as the 2012 model fog light mod
    Stryker420 likes this.
  3. Oct 10, 2012 at 12:16 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    do any of yall have the link for that? the video i seen was talking about bending one of the legs on a relay and just attaching a wire to that and carrying it over to another fuse, tried it and the fog lights wouldnt even come on.
  4. Oct 10, 2012 at 12:27 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    do any of yall know which tab is the #1 tab on the fog relay, the vid i watched showed the top tab, but the pics ive seen shows its the bottom left
  5. Oct 10, 2012 at 2:47 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    used the bottom right hole in the empty relay... i just used some 16 gauge wire i had laying around and soldered it to a 10amp fuse.. added some heat shrink.. and plugged it in. fog's shut off when the key shuts off.. i can use them all the time or none of the time. they come on with parks, DRL, low beam, or high beam.
  6. Oct 10, 2012 at 3:42 PM
    m.reed.1
    Adam
    Sacramento, CA
    A few
    sweet, thanks!
  7. Oct 10, 2012 at 6:22 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    So all I need is this one "jumper" wire? to from point A to point B like in these pics.
    Also, I aint got narren of them there electric wires and stuff. You willing to make me one like yours and mail it to me? Im payin ofcourse.
  8. Oct 10, 2012 at 8:08 PM
    2006KJ
    Front Royal VA
    i'll make ya one. PM me your mailing address.
  9. Oct 10, 2012 at 10:14 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    you can probably make a bunch and sell them for a few bucks. i'll take one for $5 if it's worth your while.
  10. Oct 11, 2012 at 6:13 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    the OP needs to check and make sure the relay location to the right of the fog location is populated with contacts before this will work....
  11. Oct 12, 2012 at 7:36 AM
    Sargechris
    Sargechris Well-Known Member
    Oceanside, CA
    13 DCLB 4x4 TRD Sport/Tow Pyrite Mica
    BFG AT KO 265/70R17 Tires, SnugTop Sport Hi Liner, Yakima Racks / Load Warrior, WeatherTech Floor Liners, BedRug/BedMat
    I would like to buy one also.. PM Sent
    One of the first things I noticed on my '13 was the fact I could not have the Fogs on with the Parking lights only... UGH! :confused:
    :cheers:
  12. Oct 12, 2012 at 7:52 AM
    Glocker23
    Glocker23 Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    Pm sent
  13. Oct 12, 2012 at 3:38 PM
    BlownFuse
    BlownFuse New Member
    New England
    '13 TRD Offroad Shortbed
    Raptor Nerf Bars Weather Tech Floor Mats :P
    I take it the 10amp is just to protect the main from going in the event of a surge of some kind? The pin just need a contact point on the harness to complete the circuit type thing? Will the dealer freak if they see this? This Taco is our first new car and we have no experience with scheduled Toyota care services. Glad to be here. Hi. :D
  14. Oct 12, 2012 at 3:44 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
  15. Oct 15, 2012 at 6:53 AM
    BlownFuse
    New England
    Thanks Shauncho
  16. Oct 16, 2012 at 3:10 PM
    MudFlap
    Tim
    2012 TRD Off Road
    I just completed this mod and I was unable to use the method above. I had to use the other method listed in the link the other posted linked. I did have my fog relay in the same place, I just didnt have the seat heater option where the plug next to the fog relay would be wired. So I had to run the jumper over to the other fuse box to the "towing tail" relay what ever that means. I just did like the other link said and it worked. LOL Thanks to all for all the info here!
  17. Oct 16, 2012 at 6:04 PM
    12TRDTacoma
    12TRDTacoma Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    12 TRD Sport DCLB 4x4 Supercharged
    Boosted
    If you and me were both smart we should had just hooked up two spade style female connectors to the fuse connector point of our little setup. I just did mine a little while ago and similar to a job I did like this a couple days ago we would had been way better off like that. Since the fuse should at some point be removable if it pops we will need to make a totally new setup or solder the old one off.
  18. Oct 16, 2012 at 8:42 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I will overhaul my jumper design using females eventually here (of course with some shrink wrap on the exposed metal to prevent shortage) but for now I am very pleased with the little bits of parts I had and how I was still able to make it work exactly how it was supposed to.
  19. Oct 16, 2012 at 8:47 PM
    lawless
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    2006KJ thank you! this is awesome. crappy night photos but you get the idea:
  20. Oct 17, 2012 at 8:09 AM
    2006KJ
    Front Royal VA
    no problem.. looks good! put that jumper together during/after a few beers... good thing i didnt solder the fuse in backwards :eek::D
