Sloppy 6spd shifter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeff, Oct 14, 2012.
  1. Oct 14, 2012 at 7:53 AM
    Jeff
    Jeff [OP] Well-Known Member
    Hopkinton,MA
    Nice 6spd,V6, very solid truck
    None currently, but I would like a better sounding exhaust and perhaps a cold air pack and some color coded step bars
    Got a 2006, 6spd , 60K, the shifter is quite loose and sloppy, no trouble getting into gears etc., but it feels real loose. Is it the bushings or linkage. Has anyone had this problem?
    Wonder if a trans shop could fix this or just go to a dealer? MJEFF
  2. Oct 14, 2012 at 8:04 AM
    badger
    badger Well-Known Member
    07 SR5
    There is a nylon ball on the end of the shifter that could be worn, but most likely what you are feeling is normal. Mine has 82K and the ball is fine. These transmissions have a ton of throw and are very vague, so most would call them "sloppy". Many people, including me, have swapped out the factory shifter for a short throw shifter. That helps some. If you are new to the whole 6 spd experience you should search the subject and get up to speed. It's been discussed a lot.
  3. Oct 14, 2012 at 8:09 AM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I installed a short throw shifter and it made a big difference. Gives it a tighter, less sloppy, more "crisp" feel.
  4. Oct 14, 2012 at 8:28 AM
    fixer5000
    fixer5000 the logical one
    Steve
    massachusetts
    2018 4runner limited in nautical blue
    wouldnt that be covered by the powertrain warranty?? id call the dealer and ask at least
  5. Oct 14, 2012 at 8:31 AM
    Super Black Taco
    Super Black Taco Well-Known Member
    Grayson
    Redwood valley, CA
    09 TRD SPORT 4x4
    OME 885 1/4 spacers,Dakars, 3* shims,Light Racing UCA BHLM,Wicked Flow Muffler, JL sub, Alpine amp, URD Short Throw Kit, U-Bolt Flip kit, 285/70/17 hankook mt
    X2
  6. Oct 14, 2012 at 8:38 AM
    Jeff
    Hopkinton,MA
    Thanks for the suggestions, I am guessing that its a TRD setup? I would have to say my shifter has gotten a bit looser recently....definately will look into it. Thanks again for the comments. MJEFF
  7. Oct 14, 2012 at 8:41 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Shark18 likes this.
  8. Oct 14, 2012 at 2:16 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    The problem you are having is the non serviceable rubber bushings inside of the shifter are worn out. In general, they can not be replaced and the shifter has to be replaced.
    If your warranty will cover it, I would go for it.
    I can rebuild your shifter and cut it down in length, if you want to go another direction.
    trapper04 and Shark18 like this.
  9. Oct 14, 2012 at 5:03 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    wrong...just the nylon ball on end of shifter..not whole shifter
  10. Oct 14, 2012 at 7:44 PM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    Well, if it is just the nylon bushing at the tip, you got lucky.
    I have seen many of these shifters fail, due to the internal shifter bushings.
    It will be obvious when the shifter is removed.
  11. Oct 14, 2012 at 7:48 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    Had the trd quick shifter in the FJ... Helped the feel quite a bit
    BassAckwards likes this.
  12. Oct 14, 2012 at 7:51 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    ^this
    if anyone knows anything about these shifters it's Coupe
    I replaced mine at 70k because the rubber isolator split
    Shark18 likes this.
  13. Aug 22, 2014 at 5:55 AM
    ayesijuan
    ayesijuan Active Member
    Cedar Park, Tx
    06 X-runner w/custom ratfink shifter
    Has customized ratfink shifter knob with flames and matches blue paint
    How hard is it to get to the nylon bushing or isolator and how can hard to switch to short shifter on a 06 x-runner
  14. Aug 22, 2014 at 6:02 AM
    ayesijuan
    Cedar Park, Tx
    Hey Tinker, I am from Everett (Ever Wet), on in Tx
  15. Aug 22, 2014 at 6:10 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    The tip bushing requires removal of the shifter and is any easy task.
    Doing a sort shifter swap is maybe an hour job.
  16. Aug 22, 2014 at 7:33 AM
    ayesijuan
    Cedar Park, Tx
    Kewl, thanks. Do you just pop off the shifter boot or do you have to take the whole console out?
    BTW: nice coupe, I have a '49 hotrod chevy truck w/350 crate motor and corvette 350 tranny
  17. Aug 22, 2014 at 7:36 AM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Shifter swap is easy.
    Took about 2 hours to swap shifter for TRD unit and change out gear oil for Redline.
    Both made a huge difference in my X-Runner.
    Tip: You do not need to notch the floor to get at the 4th bolt (in TRD instructions). If you shove the trans over to one side ever so slightly you can squeak that bolt in without issue. Also, allow for break in time. I was disappointed in mine at first, as it breaks in it gets much, much smoother.
  18. Aug 22, 2014 at 7:37 AM
    Coupe
    Houston, Texas
    08 X-Runner
    Lots baby!
    You can do it with just pulling the boot off, but I find it easier to pull the console off.
    Console goes off in about 5 minutes.
    Sounds like a nice ride.
  19. Aug 22, 2014 at 7:38 AM
    Richie Rich
    760 (San Diego)
    I pulled the console for mine. I don't think it is necessary but seemed to make the job easier. Plus, I took the opportunity to clean the console and hard to get to parts of the carpet while it was out.
  20. Aug 22, 2014 at 7:51 AM
    ayesijuan
    Cedar Park, Tx
    Okay, I think I will pull boot to inspect what exactly may be wrong: bushing, guide, etc so I can get right part and then maybe go with URD quick shift kit too. It has been grinding in 3rd for a while and have been meaning to take to dealer I got it from because they offered a life time engine/tranny warranty so I may do that first and see what they say.
    Richie, what part of SD are you in? I lived in Santee, La Mesa and Lakeside plus stationed at 32nd St. and the Miramar Reserve Station
