HID Lights...Don't get it at all
Old 10-17-2012, 09:40 AM   #1
holyroller [OP] holyroller is offline
holyroller is on a distinguished road
holyroller's Tacoma Gallery
Can someone talk to me like I'm a 4th grader in regards to HID lights. I can buy them at cost but I have NO idea.
Are they just bulbs? Whole assembly? Fog lights? Help!
I want cool looking HID's...that is my end goal...fairly simple.
Old 10-17-2012, 09:45 AM   #2
Mechanically Goofy
neonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shedneonlazer is one of the sharper tools in the shed
neonlazer's Avatar
neonlazer's Tacoma Gallery
HID is just a different type of bulb.
HID's mainly just need a ballast to regulate the voltage going into them.
PM CSjumper2003 He should be able to help ya..I got my HID headlights and fogs from him.
Old 10-17-2012, 10:11 AM   #3
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
As neonlazer said, HID is just a different bulb and they require the addition of a ballast as well. If you want HID lighting, do yourself, and everyone else on the road, a favor and pick up a set of projectors to put them into. Just throwing an HID kit into a housing meant for halogens results in a lot of glare. HIDs and halogens produce light much differently. Halogens only produce light at the filament and the stock housings are made to reflect that light out in front of you. HIDs produce light down the entire length of the bulb and the stock housings reflect the extra light in weird directions.
Check out this thread for some good info on HID lighting:
http://www.tacomaworld.com/forum/lig...0-hid-faq.html
Old 10-17-2012, 07:10 PM   #4
Wishin' I was Fishin'
landphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shedlandphil is one of the sharper tools in the shed
landphil's Avatar
landphil's Tacoma Gallery
^^^ This. HIDs without projectors are not street legal for good reason. Though not all aftermarket projectors are steet legal either.
Old 10-17-2012, 07:18 PM   #5
Pineapples on pizza Hawaiian does not it make.
Konaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shedKonaborne is one of the sharper tools in the shed
Konaborne's Avatar
Konaborne's Tacoma Gallery
all HID's are technically illegal unless stock ....but that's not enforced.
get projectors with your HID's OP, from experience, theyre a shit ton better than running them in reflector housings.
Old 10-17-2012, 07:20 PM   #6
"Pick up some speed.. You'll make it."
BuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shedBuzzardsGottaEat is one of the sharper tools in the shed
BuzzardsGottaEat's Avatar
Marines: 3rd Battalion, 1st Marines
BuzzardsGottaEat's Tacoma Gallery
call theretrofitsource.com guys and order, the best IMO
Old 10-18-2012, 03:43 AM   #7
Hid
Well understood. So projectors plus hid's will cost me about $1000?
Old 10-18-2012, 05:00 AM   #8
Pugga's Avatar
If you do it yourself and use your stock housings, it'll cost you under $300. Visit TheRetrofitSource.com and look at their complete kits. The easiest to install would be the Morimoto Mini H1 or the Mini D2S kits. There are frequently group buys in which TRS offers 25% off complete kits so if you wait until one of those, you get a lot closer to $200. Depending on your comfort level with doing the modification, there are several members on here that would do the retrofit for you for a fee. Check out member Asianant, he has an open thread and pricing for his retrofitting services.
Old 10-18-2012, 09:36 AM   #9
Reeves is on a distinguished road
Reeves's Avatar
Army: 2/16
Reeves's Tacoma Gallery
What are the best housings to use? I dont wont moisture in my lenses either
Old 10-18-2012, 09:53 AM   #10
Pugga's Avatar
OEM would be best in my opinion. You can use aftermarket, just make sure you do a good job with the sealant when you close them back up.
Old 10-18-2012, 09:56 AM   #11
Banned
ruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shedruler is one of the sharper tools in the shed
ruler's Tacoma Gallery
yeah while your at it about 80% of the "mods" on our trucks would be classified as "illegal"... J walking is illegal, so what who gives a f#cK
Old 10-18-2012, 10:05 AM   #12
Pugga's Avatar
Because running HID's in a stock reflector housing is just a jackass thing to do so the people who give a fuck would be every else on the road with you... I don't see the purpose of your argument, just trying to be difficult?
Old 10-18-2012, 10:21 AM   #13
STRIKER TRD
akaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shedakaryanreynolds is one of the sharper tools in the shed
akaryanreynolds's Avatar
akaryanreynolds's Tacoma Gallery
^^^toooo true I got pulled over a few weeks back for tail light tint and no front licenses plate.......seriously.......the cop also looked at my FX-R retos and asked me what they were. I told him projection head lights (not HIDs), ain't gonna trick me copper
Old 10-18-2012, 10:28 AM   #14
You guys are ridiculous haha there are laws on tint and lighting for a reason. The cop isn't the idiot, you are. Lights serve a purpose/have a function and that is not so you can look cool for your boyfriends. Quit being inconsiderate of others
Old 10-18-2012, 06:30 PM   #15
landphil's Avatar
I cant speak for your laws there, but there are DOT/ SAE approved HID retofit kits available for commercial trucks, helped install a set myself. They are fully approved and legal, and need to be for trucks that are insected every six months plus random roadside checks. The DOT is a US approval, so to me that means they are legal in all states, no?
For the record, my vehicles don't get illegal mods, I know a bit better than that. But you're right Ruler, there are idiots everywhere.
Exactly!
Old 10-21-2012, 06:14 AM   #16
azroaddust is on a distinguished road
Coast Guard: MM2
azroaddust's Tacoma Gallery
HID 101 for 4th graders (And some 68 year old guys too)
http://encyclopedia.thefreedictionar...sity+Discharge
Tail lights out.Don't know why TrdPETE 2nd Gen. Tacomas 26 08-30-2013 12:43 PM
***LED INTERIOR LIGHTS, HID Headlights/Fog lights kungfupanda 2nd Gen. Tacomas 18 07-26-2011 12:49 AM
FS NV: 05+ HID 8K head lights and fog lights r.i.p.taco Buy / Sell / Trade 7 11-18-2010 06:18 PM
OEM Lights just don't seem to fit Drogers Lighting 1 10-27-2010 09:00 AM
From parking lights don't turn on libagui 2nd Gen. Tacomas 4 02-18-2009 06:22 PM
