2.7 tranny cooler return line
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gkp, Oct 20, 2012.
  1. Oct 20, 2012 at 8:24 AM
    gkp
    gkp [OP] New Member
    Greg
    Georgia
    2007 Pre-runner single-cab
    First off, this is my first post, I'm a newbie so forgive my ig-nunce. I have scoured this site for an answer to this question and I am more confused than when I started. Question: Where is the transmission return line on the radiator for a 2007 2.7 w/auto transmission? I am installing a transmission cooler. There are two lines on the driver's side, one on top and one on bottom next to the radiator line.
    Thanks in advance
  2. Oct 20, 2012 at 8:56 AM
    BTO
    BTO Well-Known Member
    California
    '07 Silver PR DC AT SR5 TP LSD
    Bilstein 5100s front, Adjustable Ranchos rear.
    When installing a cooler it usually does not matter which is the return line but if you must know here is a way to find out for sure. Unhook both lines and start the motor. The one that spits out fluid is the output and the other is the return.
  3. Oct 20, 2012 at 10:13 AM
    gkp
    gkp [OP] New Member
    Greg
    Georgia
    Anybody know for sure without having to take the lines off? I'd rather have the ATF run though the radiator first then the cooler instead of the other way round.
  4. Oct 20, 2012 at 11:03 AM
    damnfingers
    damnfingers Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    Good question and one I'd like the answer to also. I'd really be interested in which cooler you bought for your Tacoma and, if not considered out of line, why you need one? Are you going to start hauling a heavier trailer? I am and that's why I'm interested. Thanks.
  5. Oct 22, 2012 at 11:34 AM
    BTO
    California
    I'm curious. What's the difference?
