Battery Help Please - 24F vs 27F
Discussion in '2nd Gen. Tacomas (2005-2015)' started by t-frax, Oct 24, 2012.
  1. Jul 20, 2014 at 5:08 AM
    #41
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    Silver 17dcsb trd sport
    i got a 24f 6months ago. it is fine. the numbers are better than the stock, while its size maybe a tad smaller. no need to go cray cray and email the dealership 8 times. i live in florida, i have a 2010 dcsb with tow pkg
  2. Jul 21, 2014 at 5:21 AM
    #42
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    IMHO, it appears that the major battery manufacturers are dropping the BCI Group 27F because the 24Fs have been repackaged with more (and thinner) plates for more Cold Cranking Amps (CCA) to reduce their cost. The downside is a loss of Reserve Capacity (RC) and possibly a shorter service life due to few total cycles, especially in a high vibration environment (like off-roading) or high parasitic loads. It is like replacing 24F with a smaller 34 battery.
    Climate has the largest effect on the amount of CCA required, driving habits determines the amount of RC, and application and charging system compatibility influences the battery type.
    Rick111 likes this.
  3. Jan 15, 2016 at 6:05 PM
    #43
    nova423
    nova423 Well-Known Member
    Virginia
    2012 DCLB TRD Sport
    Nerf bars, LED lights, truxport tonneau
    Very informative thread
  4. Jan 16, 2016 at 12:08 PM
    #44
    Stroonzo
    Stroonzo Well-Known Member
    I just replaced my 2013 TRD's battery last week with a Duralast Gold 27F.
  5. Feb 1, 2016 at 5:35 AM
    #45
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    The 34R is approximately one inch shorter in height than a 24F, so you might have to use a spacer or a piece of wood for your OEM hold down clamps to tighten. 775 CCA is plenty of amps to crank your V-6 in SoCal. Tip: depending on your driving habits, periodically "top off" the AGM with a smart charger with an AGM setting for longer battery life.
    270wsm likes this.
  6. Mar 22, 2016 at 5:05 PM
    #46
    Round II
    Round II Member #12005
    Ditch the OEM and go with an Optima. Now a lot of people say they had issues with the Redtop's and I run a yellow, my truck sits on the regular for 3 weeks to a month and never an issue.
  7. Mar 22, 2016 at 8:01 PM
    #47
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Fugin octopus. ^^^ :)
    shakerhood likes this.
  8. Feb 7, 2017 at 11:19 AM
    #48
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
  9. Feb 7, 2017 at 11:20 AM
    #49
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Calion likes this.
  10. Feb 7, 2017 at 11:20 AM
    #50
    ramonortiz55
    Ramon
    Texas
    stock
    dude. where did you get those battery terminals?
    Norton likes this.
  11. Mar 21, 2017 at 10:08 AM
    #51
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    My factory 27F just died at 1.5 years so I now have a 34R but it did not come with a spacer. I currently have two pieces of wood (1X4) underneath. Think all i need to get is a shorter set of hold down bolts like these to make it fit properly unless anyone has come up with a better solution??
    http://www.canadiantire.ca/en/pdp/motomaster-battery-hold-down-bolts-8-in-0112505p.html#srp
    asuchemist likes this.
  12. Apr 1, 2017 at 6:01 PM
    #52
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Doing some research today trying to find a 27F Marine/RV Deep Cycle battery that would fit in the stock plastic Toyota battery tray I got an education.
    Basically there's three types of batteries:
    - Starting batteries. Engineered for starting amps, not for continual discharge/charge cycles.
    - Deep Cycle batteries. Engineered for continual discharge/charge cycles, but less starting amps.
    - Dual Purpose batteries. Engineered to be a Starting battery also a Deep Cycle battery.
    - CA=Cranking amps=MCA (Marine Cranking Amps)=amps for 30 seconds at 32 degrees F.
    - CCA=Cold Cranking amps=amps for 30 seconds at 0 degrees F.
    - RC=Reserve Capacity=minutes on a 20 amp load before the battery drops to 10.5 volts.
    - AH=amp hours=don't bother with it, Reserve Capacity tells you all you need to know.
    westmarine.com has a great selection of BCI Group 27 Marine/RV batteries (they have the dual stud, standard round battery terminal plus a threaded stud). They have the designation '27' or '27M'.
    Unfortunately, they are not 27F designation, the F means the positive terminal is on the opposite side from a 27. Stock Toyota battery setup has to have a 27F, the stock battery cables won't reach a 27's terminals.
    24F is fine (3rd Gen Tacoma w/tow package has a 24F), but a 27F no matter the brand will have more Reserve Capacity. Neither are Deep Cycle batteries, more in the Starting Battery category.
    I think a direct replacement Duralast Gold or whatever 27F is fine for all applications.
    Optima Yellow 27F is too pricey, although it is designed to be a Dual Purpose battery.
    And, finally, don't trust that 10.5 volts (see Reserve Capacity above) will start your engine. 10.5v won't start mine, I think 11.2 is the threshold and carry a jump pack.
    Biscuits, DayStars and asuchemist like this.
  13. Apr 1, 2017 at 6:43 PM
    #53
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    24F from Sam's club wouldn't strap down for me. To tall and didn't want to bend bracket. Also 24F not what my book calls for my truck. Stuck with 27F FTW.
    monkeyface[QUOTED] likes this.
  14. Apr 1, 2017 at 6:51 PM
    #54
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Toyota's standard battery for Tacoma is a 24F. Their optional battery that is standard with some other options is a 27F. The difference is the length of the battery. The height and width are generally the same with the same terminal placement and polarity. Another difference is due to the 27F's larger physical length, more plates can be added for increased CCA performance or Reserve Capacity. Amp Hours is a capacity measurement that is very useful if you have a drain (aftermarket winch, audio system, lighting, etc.) other that at 25 amps due to the Peukert Effect.
  15. Apr 1, 2017 at 6:55 PM
    #55
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    You can shim it with a piece of wood or plastic under the battery so you tighten down the holddown bracket. A loose battery will vibrate excessively causing a premature plate failure.
  16. Apr 1, 2017 at 7:06 PM
    #56
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Northstar AGM for the easy win!
    Rick111, Norton and OZ-T like this.
  17. Apr 1, 2017 at 7:37 PM
    #57
    Pigpen
    Pigpen My truck is never clean
    Northwest Montana
    2012 AC Manual 4.0 4x4 Base Model
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Backcountrry MT 3 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 24F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, OME 90021 front shocks with 885 coils, SPC LR UCAs, Up2NoGood 2wd low range mod, 4 Wheel Campers Grandby slide in camper
    i want those terminals!
    This is the best answer.
  18. Apr 1, 2017 at 7:41 PM
    #58
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This
  19. Apr 1, 2017 at 8:04 PM
    #59
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    If you application is extreme off road, a spiral wound AGM, like the Yellow Top Optima will handle heavy vibration better. If your application is more street use with heavy electrical loads, the flat plate AGM, like the Northstar will should handle the deep cycling better. Both examples are very good batteries and should give a long service life if properly charged and maintained.
  20. Apr 2, 2017 at 10:20 AM
    #60
    babylon5
    David
    With just a little bit of work the 34R is in there and secure and no wood.
    Used the previously mentioned replacement 8 inch J bolts you can buy anywhere (Amazon, canadian tire etc)
    Drilled out the spot weld or whatever it is that holds the rear factory J hook to the hold down bracket.
    Picked up 2 nylock nuts and two washers.
    Used my dremel tool and cutoff disk to shorten rear 8 inch j hook since on the factory setup the rear one is like 2 inches shorter.
    Installed everything and its not going anywhere now :)
    Total cost less than $10
