Alternative Location for D-Rings in Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ziggynagy, Nov 2, 2012.
  1. Nov 2, 2012 at 2:23 PM
    ziggynagy
    ziggynagy [OP] All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    I like Neubs' write-up on adding D-Rings to the truck bed but had my own reasons for not installing the D-Ring thru the bed bolt (my bed bolts are rust magnets, need rings to swivel, preferred not to dremel). Also wasn't a fan of the OEM location inside the wheelwell/sidewall as I wanted the D-Rings (PT278-35054) on the floor and a position where the backplate couldn't freely spin.
    Found a spot next to the bed bolt where the backplate fits with no wiggle-room, allowing for easy tightening.
    Tools:
    7/16" masonry bit
    T40 bit
    Torque wrench (set @32N-m)
  2. Nov 2, 2012 at 2:33 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    That's good, I wish I'd thought of that before I installed mine. I put them in the sides according to the directions included but your way seems like it would have been easier.
  3. Jan 17, 2018 at 10:41 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    How did this mounting location hold up for you? Is there a similar tight spot like this on the driver's side?
  4. Jan 17, 2018 at 11:07 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Curious why a masonary bit
    ChadsPride likes this.
  5. Jan 19, 2018 at 7:56 AM
    ziggynagy
    Stoughton, MA
    5+ years and running strong. Have used multiple times and no issues/loosening this far
    Cause I didn't want to chew up my wood bits
    NMTrailRider[QUOTED] likes this.
