Stuck in Miami Sand + tow hook question. (with pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAC1, Nov 11, 2012.
  1. Nov 11, 2012 at 4:25 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello Forum,
    My friend Manny, who has an '89 F-150 4WD invited me to go check out some sand dunes located at nw 199 st & 27 ave in Miami (accross from SunLife stadium). I went in my '08 Prerunner DCSB 4.0 and I did good in the open areas:
    but when I tried to go through a dirt bike trail my truck it just dug into the soft sand:
    Being an open diff & going in there with 35psi in the tires did not help the situation. Luckily, Manny pulled me out. I have the wheelers tow strap but he had one also so I didn't use mine. Now I realize that I need a tow hook for the front. This is how the front looks now:
    Drivers side
    Passenger side
    I assume that the hook will be installed on the passenger side since I have that loop thing on the drivers side. Where can I buy this & what do they go for? I read somewhere that someone bought a hook at Harbor Freight for like $9. Any suggestions?
    Also, I see that 4WheelParts sells this for the 8.4 diff in my truck.
    Toyota Tacoma 8in.TrueTrac - EAT913A541
    Can I have them install it too or does anyone recommend someone else to the the install. I have heard mixed reviews regarding them but I don't know anyone else. I want it to be a reputable shop.
    Thanks :D
    P.S. I posted this in the Florida thread also.
  2. Nov 11, 2012 at 4:28 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    Get a D-link and pass it through the drivers side tow point and then the strap.
  3. Nov 11, 2012 at 4:34 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Excuse my noobness but what is a D-Link & where can I buy one?
  4. Nov 11, 2012 at 4:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    stay as far away from 4wheelparts as humanly possible.
    also a lunchbox locker will lock up on you on pavement and takes some getting used to. I would do lots of research on them being used on pavement before committing.
  5. Nov 11, 2012 at 4:38 PM
    Burgman
    Stephen
    Ric VA
  6. Nov 11, 2012 at 4:46 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    Why stay away from 4wheelparts??
  7. Nov 11, 2012 at 4:52 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    I think I posted the wrong part #.
    This is the one:
    Toyota 8.4in. TrueTrac - EAT913A612
    It is a limited slip diff.
  8. Nov 11, 2012 at 5:01 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Are you referring to the 4WheelParts location in Miami? I know that if I do it with them I get a warranty but the posts that I have read have me concerned. I just want to know if its that location. I don't want to demonize the whole company if it's only a cetain location.
    I am not defending them. I don't even know them. I am just curious to know "why not them".
  9. Nov 11, 2012 at 5:04 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you Burgmann,
    Now that I know what it looks like & the price is right, where do I bolt it up to?
  10. Nov 11, 2012 at 5:05 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Driver's side loop is for Towing Only.
    The weld is adequate for constant pressure, but may fail when "tugged or jerked"
    The Passenger's side "Tie down" (used for shipping) should be replaced with a hook or eye and longer bolts
    Toyota "Off Road" Recovery Hook"
    I'll be back with a part # and some links
    CC
  11. Nov 11, 2012 at 5:05 PM
    Burgman
    Stephen
    Ric VA
    The drivers side hook
  12. Nov 11, 2012 at 5:08 PM
    Burgman
    Stephen
    Ric VA
    I been pulled jerked tugged and never had a problem with the drivers side loop... once i was buried to the axle in sand, took about 5 jerks with a standard tow strap:cool:
  13. Nov 11, 2012 at 5:09 PM
    mutilatedjak
    mutilatedjak n00b waffle
    WA
    11 DC SB TRD Sport 6spd
    BP-51s, Dakar leafs, ARB bumper, 4xinnovations rear HC, 3x trail camera, pure android, lightforce 170s, Dick Cepek 255 85s extreme terrain.
    Only small shackles fit in that passenger side recovery point, my 3/4 in ones don't fit. I bought a cheepo recovery hook from 4wheel parts until the oem TRD OR one I bought from a tw member comes in.
    The driver side loop is only a tie down location.
    http://www.4wheelparts.com/Winches-...-Hook.aspx?t_c=18&t_s=190&t_pt=4007&t_pl=9354
    This or any other hook should work. Or buy the trd or one from a member who doesn't need theirs any more
  14. Nov 11, 2012 at 5:09 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thanks Burgman!
    Thanks mutilatedjack!
  15. Nov 11, 2012 at 5:11 PM
    Burgman
    Stephen
    Ric VA
    Oops, this is correct need a 1/2" shackle to fit... didnt pay attention to the link, just typed shackle in Amazon posted the first link
  16. Nov 11, 2012 at 5:14 PM
    Cape Codder
    Jack
    Toyota Recovery Hook Part #51961-35080 ($75 +)
    2nd gen recovery loop. (Made by Member mustangwilly)
    Can't confirm it'll work with TRD Skid Plate
    Also some good readin' here:
    Let's talk recovery
    Good Luck
    CC
  17. Nov 11, 2012 at 5:15 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i have never had 4wp install anything for me but i would consider having a diff shop do the install. even if you have to pull your third and mail it somewhere. it may be cheaper and may have better warranty. if not then use 4wp. they didn't get huge by doing bad installs right?
    also, dont let anyone tell you horror stories about a tru-trac locking up on pavement. if that happens i think Eaton owes you some money lol. I have heard great things about that little device except that they at one time had problems with some bolts backing out and really reaking havoc. talk to your installer and see if they know anything about that and if Eaton has resolved the problem. If they've never heard of such an issue, dont sweat it.
    hope it goes well for you and be sure and tell us how it performs!!!!! i havent read of anybody installing one on their taco yet, and am considering one for myself
  18. Nov 11, 2012 at 5:16 PM
    Cape Codder
    Jack
    Just passin' on what I've learned on TW. Driver's Side is for Towing.
    TRD "Off Road" Tacoma comes with Recovery Hook on passenger's side for a reason
    CC
  19. Nov 11, 2012 at 5:29 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    He also needs two bolts P/N: 90119-A0193
    Stock parts on the left, bolt and hook on the right.
  20. Nov 11, 2012 at 5:37 PM
    Cape Codder
    Jack
    Good Call, My Bad
    Mentioned the longer bolts, and failed to post Part #
    CC
