Planning on getting a TACO soon which one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by uhmmmar15, Dec 2, 2012.
  1. Dec 2, 2012 at 4:16 PM
    uhmmmar15
    uhmmmar15 [OP] Active Member
    Uhmmm
    Texas
    If my money is right and a good deal comes along I am thinking about buying one next year anywhere from a 2005-2009. My question is which year should I go with? I prefer a 4x4 ,but if a pre runner comes my way at the right price then I might just buy a 2wd.
    My other question was what all mods do you have to do in order to get a 6inch lift and a 3inch body lift.Is it also true the higher you lift your truck the more wear and tear it has on it someone was telling me they had to constantly replace ball joints and put a new driveshaft because of the horrible vibration etc. It is going to be my Daily Driver so it might just see the mud maybe once a year just want more for the looks not performance. I was looking at pro comp ,but seems pretty pricey is there a cheaper route for a lift kit and body lift without having to spend so much?
  2. Dec 2, 2012 at 4:17 PM
    12TRDTacoma
    12TRDTacoma Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    12 TRD Sport DCLB 4x4 Supercharged
    Boosted
    4X4 TRD sport. It comes with the Skewp :D
  3. Dec 2, 2012 at 4:24 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    Welcome! 6” lift will require a drop bracket if it’s 4x4.(drops the front diff down so the CV angles are not to sharp) also a 3” body lift is VERY VERY unsafe! in a crash the cab can separate from the frame. or damage the body mounts really badly.
    also if you get a 6” get good upper control arms and you should not have much if any ball joint problem.(you get what you pay for, on upper control arms) also may need to get lower control arms.
    also some guys have drive shaft problems and some don’t. but with any lift kit or mod parts will wear faster and not last as long. but the more you pay for a lift kit usually means the parts are a lot better.
  4. Dec 2, 2012 at 4:25 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    it’s a fake scoop. Off road comes with a rear locking diff. :D
  5. Dec 2, 2012 at 4:28 PM
    Large
    Large Red
    4wd, access cab trd o/r.
  6. Dec 2, 2012 at 4:36 PM
    uhmmmar15
    Uhmmm
    Texas
    So I should just go with a 6inch suspension lift w/supporting mods? I want to be sitting high. Is there such thing as a 9inch lift kit?
  7. Dec 2, 2012 at 4:37 PM
    uhmmmar15
    Uhmmm
    Texas
    What is a o/r? Also I am going with a double cab short bed still not sure which year I should get...
  8. Dec 2, 2012 at 4:38 PM
    Large
    Large Red
    Don't need UCAs or LCAs with a 6" DB. If you want 9" go with a 6" DB, 885 coils and top plate spacers.
  9. Dec 2, 2012 at 4:40 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    o/r = Off Road
    Yes there are 9" lifts, and also 12"
  10. Dec 2, 2012 at 4:41 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    don’t need them, but ball joints and everything will wear a lot faster. and the ride would most likely be a little bit better.
  11. Dec 2, 2012 at 4:45 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    DCSB TRD OR
  12. Dec 2, 2012 at 4:57 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Who cares if it is fake, it looks good :D
    True, however, I've went plenty of places with open/open diff 4WD on my sport and have had no issues whatsoever, even in the worst conditions.
  13. Dec 2, 2012 at 7:25 PM
    DWreck
    Derek
    Las Vegas, NV
    You can go through anything with an open diff, until you articulate and a wheel leaves the ground. OP, if you plan on running any trails where you may articulate enough to lift a rear tire, get an OR, if not you'll be fine with a sport.
  14. Dec 2, 2012 at 8:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah, that's the only issue. I saw the off road had a locker when I bought it and I thought the sport came with it too, but I guess it didn't. Oh well, I don't plan to do EXTREME rock crawling where a wheel is going to be leaving the ground anyways.
  15. Dec 2, 2012 at 8:25 PM
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    Op.. This is what I have as well and I haven't had to replace anything
  16. Dec 2, 2012 at 9:00 PM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA/WA
    2nd gen
    I feel if you are only possibly going offroad once a year and it is mudding you might need 4x4 for that one time, but seriously if 99% of your driving is on the road and you want a Tacoma with a massive lift for show just get the sport and save what, maybe $500?
    And you will gain the colormatched front/rear bumpers and grille surround, and mirrors. Of course the scoop too.
    Seems like if its for looks just supe a prerunner up to your specs and use the difference saved from buying a 4x4 and buy a $4000 trail rig to mud with and beat up.
  17. Dec 2, 2012 at 9:18 PM
    Larry
    Larry CARL
    CARL
    buy the newest...lowest mileage truck you can find and afford.
  18. Dec 2, 2012 at 9:30 PM
    uhmmmar15
    Uhmmm
    Texas
    Im pretty new to the whole off road scene what is all these acronyms?
    UCAs or LCAs DB
  19. Dec 2, 2012 at 9:32 PM
    uhmmmar15
    Uhmmm
    Texas
    What is a locker? So you guys are telling me if I want something that is gonna be on 4wheels at all times I should just go with a toyota tacoma double cab short bed sport? And if im gonna be crawling I should go with a toyota tacoma double cab off road edition? And there is also such thing called a TRD version? I seen a Texas edition Tacoma what is difference between that one?
  20. Dec 2, 2012 at 10:46 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The texas edition tacoma is pretty nice!
    A locker basically locks both rear wheels and spins them at the same speed instead of the one which has the least resistance like an open diff operates. It helps for things like rock crawling or other lower traction situations.
