2013 Dual Battery install
Old 12-09-2012, 01:55 PM   #1
kai38` [OP] kai38` is offline
kai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shedkai38` is one of the sharper tools in the shed
kai38`'s Avatar
kai38`'s Tacoma Gallery
I went back to a Tacoma from a FJ, before selling it I removed parts I would reuse in the tacoma one was the dual battery system and the marine Optima battery. Before getting the Tacoma I assumed the Optima would just drop in to the passenger side wheel well like on the FJ. I've seen other dual battery set ups with both batteries in the OEM spot, I didn't want all that weight in one spot
The '13 has some stuff in the way that made the install a little harder.
There is some DENSO electrical box and a air pump for the emissions in the way that needed to be relocated (anyone know what it is?)
After moving them out of the way I needed to cut 3 bolts that were in a tri-pod shape on the inner fender, maybe a mount for a non-USA Tacoma jack? Then I was able to sit the battery box in place to figure which direction to mount it.
I was able to drill three holes to mount the battery box, the one closest to the fire wall needed spacers to hold it up level, (you can see the white plastic spacers underneath)
I got the air pump bolted back in but it was moved over about 1 inch and was only able to reuse 2 of 3 bolts.
Next I ran the wires for the dual battery kit http://www.dfna.info/dual-battery-kit.html# a very simple install.
And made a mounting bracket for the isolator, in the FJ I mounted it on top of the fuse box but it was a PIA to open fuse box. I bought a small plastic cutting board and cut it to size and a piece of angle iron.
I ran the wire from the main battery to the isolator, another wire from there to the hot side on the aux battery and ground isolator + aux battery.
Old 12-09-2012, 02:13 PM   #2
Thin Blue Line
ProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shedProForce is one of the sharper tools in the shed
ProForce's Avatar
ProForce's Tacoma Gallery
Nice!
Old 12-09-2012, 02:17 PM   #3
Monster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shedMonster Coma is one of the sharper tools in the shed
Monster Coma's Avatar
Monster Coma's Tacoma Gallery
Looks good man, I'll be referring to this when do mine
Old 12-09-2012, 02:30 PM   #4
Captain
Juggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shedJuggernaut is one of the sharper tools in the shed
Juggernaut's Avatar
Juggernaut's Tacoma Gallery
Excuse my ignorance, but what does one use two batteries for?
Old 12-09-2012, 02:43 PM   #5
2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed2006KJ is one of the sharper tools in the shed
2006KJ's Avatar
2006KJ's Tacoma Gallery
x2?
maybe for expedition if your going to run a refrigerator, water pump/heater for shower, lights, onboard electric air compressor...
but for a stock street truck im not sure why 2 batteries are necessary.
edit: after doing some not extremely.. but kinda creepy research through the OP's pictures... i'd say he has plans to make the taco into an overland/expedition vehicle.
Old 12-09-2012, 02:45 PM   #6
na8rboy has a spectacular aura aboutna8rboy has a spectacular aura aboutna8rboy has a spectacular aura about
Firefighter:
na8rboy's Tacoma Gallery
Just an FYI... You should use the same two style batteries (Brand/cca) The charge rate and draw is different on the two you have in your truck. They won't last as long, as if you were to use both the same.
By the way great job. I will be doing this to mine, and you sure helped with what I want to do...
Old 12-09-2012, 03:03 PM   #7
kai38`'s Avatar
I use the 2nd battery to power everything not factory I install in the Tacoma,
12v fridge,12v blanket for the roof top tent in the winter,12v fan in the tent in summer lights in the tent, all lights I'll be adding, HAM & CB radios,inverter to recharge laptop cameras etc.
No worries when sitting in camp a couple of days that I might run my battery down.
Old 12-09-2012, 03:18 PM   #8
SitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to allSitkaSpruceMica is a name known to all
SitkaSpruceMica's Tacoma Gallery
Super nice install. AWESOME!
TC
Old 01-05-2013, 11:14 AM   #9
instagram: ATC510
sytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shedsytfu510 is one of the sharper tools in the shed
sytfu510's Avatar
Army: Infantry
sytfu510's Tacoma Gallery
nice going to have to go this route myself.
Old 08-11-2013, 04:06 AM   #10
4th MAW
ETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shedETAV8R is one of the sharper tools in the shed
ETAV8R's Avatar
Marines: MASS 6 El Toro
ETAV8R's Tacoma Gallery
Ok you may have just solved one of my problems with that plastic cutting board idea. How has it held up under off road use?
I want to do a marine deep cycle in the same spot as you have your optima but I'm finding it may be too large. How tricky was it to get that optima tray in there? It looks like it may be at an angle.
p.s.
Heated blanket-NICE. How much does it draw from your 2nd battery? This might be a great thing to have in the winter instead of installing a heater inside my camper. I'm sure it draws a lot of amps though.
Old 08-11-2013, 04:24 AM   #11
ndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shedndsgr is one of the sharper tools in the shed
ndsgr's Avatar
ndsgr's Tacoma Gallery
I could just be inexperienced, but I can't think of why it matters for lead acid batteries. The "bus" line will get ~13v to charge and each battery will draw the current it can draw; similar for discharge. Maybe I'm missing something?
Old 08-11-2013, 06:17 AM   #12
shawnd2 is a glorious beacon of lightshawnd2 is a glorious beacon of lightshawnd2 is a glorious beacon of lightshawnd2 is a glorious beacon of lightshawnd2 is a glorious beacon of lightshawnd2 is a glorious beacon of light
shawnd2's Tacoma Gallery
Hi,
Thanks OP for taking the time to do the writeup.
I realize that this is an old thread that was resurrected a couple of posts up, but I have a question for those that have this setup.
From the battery isolator's vendors page it states:
"The Battery Sensitive Relay (BSR) allows two batteries to be charged at the same time. When the engine is started and the start battery reaches 13.3 volts, the BSR dual battery isolator engages, allowing two battery banks (start and house) to be charged simultaneously. When the voltage drops below 12.8 volts (eg the engine is stopped), the BSR disengages, separating the batteries. This system eliminates the possibility of draining the start battery and protects sensitive electronic equipment powered from the house battery from harmful engine start up spikes."
So if I understand correctly, both batteries are online until voltage drops below 12.8v. Once they are below they seperate and the Aux battery is online.
When you go to start the truck, what tells the relay to switch to the starting battery? Is it a manual switch?
Shawn.
Old 08-12-2013, 01:17 AM   #13
4th MAW
ETAV8R's Avatar
Anyone know what size bolts these are holding the angle iron to the inside of the fender?
Old 08-12-2013, 02:07 AM   #14
dont tread on me!
Kolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shedKolunatic is one of the sharper tools in the shed
Kolunatic's Avatar
Kolunatic's Tacoma Gallery
Nice job.
Old 08-12-2013, 02:29 AM   #15
TacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shedTacomaBuilder67 is one of the sharper tools in the shed
TacomaBuilder67's Avatar
Air Force: Fire Protection Specialist 1987-1995
TacomaBuilder67's Tacoma Gallery
Those three studs are not for a jack. They are mounting points for the ABS Brake Actuator. Your truck has VSC. All Tacomas have these three studs regardless of braking system.
Old 08-12-2013, 07:02 AM   #16
kai38`'s Avatar
They were either a 10 mm or 12mm standard Toyota bolt.
Old 08-12-2013, 07:03 AM   #17
kai38`'s Avatar
Originally Posted by shawnd2 View Post
Hi,
Shawn.
No manual switching between batteries, truck starts off of OEM battery
Old 08-12-2013, 07:09 AM   #18
kai38`'s Avatar
p.s.
The cutting board has held up great,its such a short piece it dosen't extend out very far.
The tray took so wiggling to get it in there. I also had to relocate something,not sure what it does or what its for to the fire wall for it to fit.If the tray fits the battery will.
Not sure what the blanket draws, I'll have to dig it out and see what the package says.
Old 08-12-2013, 09:41 AM   #19
4th MAW
ETAV8R's Avatar
Thanks for the reply!
Someone could make some money building trays like this which fit with the factory bolts:
http://www.expeditionportal.com/foru...up-2006-Tacoma
2nd gen dual battery install badtoytrd 2nd Gen. Tacomas 21 03-03-2014 09:53 PM
Looking to install dual battery's in my taco, need help MDtaco 1st Gen. Tacomas 35 09-22-2012 03:13 PM
Dual Battery Install overlandtaco Product Reviews 39 08-23-2012 02:02 PM
HO alternator/Dual Battery/Battery Separator/"Big 3 Upgrade chazjb 1st Gen. Tacomas 13 04-09-2012 05:13 AM
Dual Battery WhyteRaevin 1st Gen. Tacomas 3 12-15-2009 08:32 PM
