Alternative trail armor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by speeddemon2588, Dec 13, 2012.
Would you consider composite skid plates?
Poll closed Jan 12, 2013.
  1. Yes, if they were proven and cost justifiable
    47 vote(s)
    78.3%
  2. No, never
    4 vote(s)
    6.7%
  3. Maybe/Not sure.
    9 vote(s)
    15.0%
  1. Dec 13, 2012 at 4:13 PM
    #21
    speeddemon2588
    speeddemon2588 [OP] Well-Known Member
    Andres
    Columbus, IN
    08 TRD Rugged Trail
    5100's
    I would assume it would depend on the material, some materials crack others bend. Nylon is really good about having a high tensile strength while retaining high ductility. I would be more concerned about repairs as stated earlier. Then again using the right resin/epoxy might do the trick. However if these rigs are using alternate materials there must be something to it.
  2. Dec 13, 2012 at 4:50 PM
    #22
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    Typically when people talk about composites, they mean carbon fiber or aramid fiber (kevlar). The latter is very tough and resistant against puncture, typically used for bulletproof cockpit doors on modern airliners. Cost is quite high. However, in airplanes, it is often justifiable to double the cost to save 10% weight.
    HDPE, delrin, bakelite, G10, etc. are just "ordinary" plastics. They are all pretty weak compared to steel. In both pictures above, the panel is well supported by a tubular frame. With that frame in place, you can use a 2mm-thick steel sheet in lieu of the plastic and get equal protection.
  3. Dec 13, 2012 at 5:15 PM
    #23
    BradyT88
    BradyT88 Well-Known Member
    I don't know... 2mm is a pretty thin sheet of steel... The orange HDPE is 3/4" thick. They said a rig about 2000lbs less than them has beat the crap out of a 1/2" sheet that has held up just fine.
  4. Dec 13, 2012 at 6:10 PM
    #24
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    cool pic. and i have thought about this stuff for skids. most side by sides and new ATV’s come with this stuff for skids and it works very well. tomorrow i can tack some pic of the stock skids on our rhino. i have hit sooo many things sooo hard with them and you can’t hardly tell.(than agin the rhino is only 1250 pounds plus 2 people, +cooler,+5 extra gallons of gas, plus a box with odd stuff in it tow rope, maybe some food. so maybe close to 1800 or 1900 pounds when on the trail.
  5. Dec 13, 2012 at 6:16 PM
    #25
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    One very important thing to notice about this rig and the other one is that the HDPE is backed with tube steel. The HDPE is just being used as a sliding surface only, probably because it is slippery. I don't think that stuff is strong enough to be used as a weight bearing skid plate.
  6. Dec 13, 2012 at 6:24 PM
    #26
    KenLyns
    Belly of the Beast
    ^This.
  7. Dec 13, 2012 at 6:59 PM
    #27
    BradyT88
    True. It's too flexible. Would just flex into whatever you are trying to protect.
  8. Dec 13, 2012 at 7:12 PM
    #28
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Plus it sounds better when you land on steel. You know what your landing on it protected.
    Pretty gross example. Would you wanna wear a condom or grocery bag. Haha a teacher asked us this in auto. NOT MY MIND
  9. Dec 13, 2012 at 7:21 PM
    #29
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    the thicker this stuff is the less it’s going to flex. i really don’t think this stuff will flex enough to hurt what part is on the other side of it.
    will try and get a pic maybe video of the skids on our rhino tomorrow.
  10. Dec 13, 2012 at 7:38 PM
    #30
    KenLyns
    Belly of the Beast
    Kinda surprised he has a muffler skid. A punctured muffler won't leave you stranded on the trail.
  11. Dec 13, 2012 at 7:52 PM
    #31
    BradyT88
    Yeah would just depend on how spread out the bracing is behind it.
    He did it just to balance things out and cuz they had some extra laying around still. haha
  12. Dec 13, 2012 at 8:55 PM
    #32
    KenLyns
    Belly of the Beast
  13. Dec 14, 2012 at 2:21 PM
    #33
    KenLyns
    Belly of the Beast
    All those $5 cans of Red Bull paid for something all right... Apparently we've been doing it wrong all this time and should be running slick tires off road.
  14. Dec 14, 2012 at 3:09 PM
    #34
    KenLyns
    Belly of the Beast
    Perhaps this is more palatable for you?
    http://www.youtube.com/watch?v=I-pzol0sxro
  15. Dec 21, 2012 at 9:46 AM
    #35
    speeddemon2588
    Andres
    Columbus, IN
    08 TRD Rugged Trail
    5100's
    This^^ :mad: Didn't the discovery channel pick it up though?
