Rough Idle When at a Stop
Old 12-22-2012, 05:27 PM   #21
Shaowei [OP] Shaowei is offline
Shaowei is on a distinguished road
Shaowei's Tacoma Gallery
Mine dies it all year long, hot or cold. Hence, it gets old really quick.
Old 12-22-2012, 07:54 PM   #22
tinker2 is on a distinguished road
tinker2's Avatar
tinker2's Tacoma Gallery
Originally Posted by Shaowei View Post
I have a 2005 double cab with a V6-Auto with K&N AF that has approximately 90k miles. Generally, I love this truck. My biggest complaint is a rough idle (sound and a slight vibration) when I am at a stop, which is frequent in rush hour.
This is the situation. When the truck is in Park, the engine idles perfectly. No sound or vibration. When the truck is in Drive and I'm stopped, the engine idles roughly which includes sound and a slight vibration. The engine RPM is slightly lower than in Park (which I would expect). If I just barely press on the gas (while the other foot is on the brake) the rough idle disappears. When I begin moving the sound and vibration is usually present until about 15-20 mph. The rough idle occurs nearly 95% of the time, the other 5% is beautiful silence!
I know without seeing/hearing the idle in real life this is a stretch but would appreciate any ideas to start trouble shooting. Thanks!
My advice is change the plugs, clean the MAF Sensor and throttle body and replace the air filter with an OEM type filer for now. Then you'll know what has been done and if it persists it'll tell you what is not causing the problem. IMO
Old 01-05-2013, 10:20 PM   #23
I finally was able to do some of these recommendations. I changed the plugs (actually still had the original Denso and NGK plugs), the PCV, and cleaned the MAF, air filter, and throttle body. I don't have the original air filter assy.
The PCV looked pretty well used...
The plugs looked alright...
So far the engine seems to idle better but time will tell. I'll keep this post updated as I know more.
Old 01-06-2013, 07:30 AM   #24
Toyo_Jet is on a distinguished road
Toyo_Jet's Avatar
Toyo_Jet's Tacoma Gallery
The surge when stopped is the AC compressor kicking in. Toyota seems to be a little over zealous on the idle speed compensation. If you have defrost selected, even when you are on heat, The compressor can cycle.
As far as the rough idle, I'm noticing my 2010 getting a little rougher, not real bad, and not a random shake. Almost like you can feel every cylinder fire. I'll be keeping an eye on it.
Old 01-07-2013, 01:24 PM   #25
tinker2's Avatar
Glad to hear what you did helped. As for the plugs, they needed changed. When the electrode burns away leaving it round, it's time for a change. I painted a red line pointing at the electrode, you can see it if you blow up the picture..
Rough Idle? BOLLINGERTACO Technical Chat 9 03-02-2012 10:59 AM
Rough Idle?? brfd01 Technical Chat 2 01-08-2011 08:15 PM
Rough Idle, Help!! 95toyotaco 1st Gen. Tacomas 13 01-24-2010 05:58 AM
help with rough idle apex9r 1st Gen. Tacomas 13 11-15-2009 02:21 PM
Rough idle? ETaco23 Performance and Tuning 4 04-20-2008 11:30 AM
