Which lift blocks should I use?
Old 01-03-2013, 03:06 PM   #1
mirraman [OP] mirraman is offline
mirraman is a splendid one to beholdmirraman is a splendid one to beholdmirraman is a splendid one to beholdmirraman is a splendid one to beholdmirraman is a splendid one to beholdmirraman is a splendid one to beholdmirraman is a splendid one to behold
mirraman's Avatar
mirraman's Tacoma Gallery
Okay, so I'm going to be adding some lift blocks and would like some advice on which ones to use.
Please don't tell me about how I shouldn't use blocks!! I've heard it all already. It is just temporary until I can afford some Dakars.
Also, I am aware that i will need extended brake lines and longer shocks as well as taller bump stops.
With that, here are the options I'm looking at:
Currently if have a 3-leaf AAL giving ~1.5" of lift. I want to add at least another 1.5" to that. I have found some similarly priced lift blocks. One set is 2" billet aluminum and the other is 1.5" cast steel. The shocks I will be using are rated for 3-4" of lift so they should work fine with either setup.
If you are curious why I want so much lift in the rear, it is because I just got a set of Maxtrac spindles and I absolutely HATE bro-lean.
Please let me know any insights you may have and also any reason one type might be better/worse than the other. Thank you much!
Old 01-03-2013, 03:18 PM   #3
mirraman's Avatar
Old 01-03-2013, 03:28 PM   #4
RiverBoyTRD has a spectacular aura aboutRiverBoyTRD has a spectacular aura about
RiverBoyTRD's Avatar
RiverBoyTRD's Tacoma Gallery
As to aluminum or steel, these trucks don't weigh enough to make a difference. The question is how much BRO lean you have and how much lift you need to compensate.....without knowing I would say the 2" a little rake is better than a lean
Old 01-03-2013, 03:32 PM   #5
ppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shedppham444 is one of the sharper tools in the shed
ppham444's Avatar
ppham444's Tacoma Gallery
If you use aluminum blocks, you should add at least an additional inch since aluminum will flatten out over time due to it's soft characteristics. Here's what mine looks like.
Old 01-03-2013, 03:56 PM   #6
mirraman's Avatar
Actually I was thinking maybe I should get another frame mounted below mine and just keep the suspension stock:
Old 01-03-2013, 08:09 PM   #7
Painted mismatched but similar color.....seems legit
Old 01-03-2013, 08:16 PM   #8
.45%er
the.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shedthe.sight.picture is one of the sharper tools in the shed
the.sight.picture's Avatar
Army:
the.sight.picture's Tacoma Gallery
belongs in the WTF thread
Old 01-03-2013, 08:23 PM   #9
Khaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shedKhaos is one of the sharper tools in the shed
Khaos's Avatar
Khaos's Tacoma Gallery
There was a Caddilac on "dubs" on Craigslist awhile back that had modified Escalade frame welded onto it so they could clear the really cool 30" wheels with rubber band tires.
Old 01-03-2013, 08:44 PM   #10
.45%er
Army:
I thought "DUBS" meant 20s?
and Duece Dueces were 22s?
so 30s would be "trays" if i know my gansta speech
Old 01-04-2013, 12:27 AM   #11
Bookin is on a distinguished road
Bookin's Avatar
Bookin's Tacoma Gallery
http://toyteclifts.com/index.php?pag...mart&Itemid=72
2 inch lift blocks Socalrunner 2nd Gen Tacoma Marketplace 8 02-19-2013 03:39 PM
1.5" lift blocks mirraman 2nd Gen Tacoma Marketplace 6 01-03-2013 10:23 AM
1 in lift blocks nschmittsd Suspension 2 12-04-2012 07:05 PM
Lift Blocks vs ? RockLobster1106 Suspension 0 07-11-2011 12:28 PM
making my own lift blocks gsanderson Suspension 9 12-06-2009 06:17 PM
