Billstein 5100, Rear TSB, My Experience
Old 02-15-2013, 02:51 PM   #61
m32 m32 is offline
m32 has a spectacular aura aboutm32 has a spectacular aura aboutm32 has a spectacular aura about
m32's Avatar
m32's Tacoma Gallery
Originally Posted by la0d0g View Post
Careful, that link is for 2nd gens. From your profile I think you have a 1st gen so you wouldn't want to order those.
The vibes are usually driveline vibrations so it wouldn't matter 2 v. 4wd
Gotcha... btw, I did pick up a 2013 Tacoma two weeks ago.
Edwin
Old 02-15-2013, 02:53 PM   #62
Its 4 o’clock somewhere
la0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shedla0d0g is one of the sharper tools in the shed
la0d0g's Avatar
la0d0g's Tacoma Gallery
Edwin
Well shit boom. Nice rig!
Old 02-15-2013, 03:09 PM   #63
pattersondp is on a distinguished road
Air Force: Cable Dawg
pattersondp's Tacoma Gallery
ummm whats a TSB?? and how much are they
Old 02-15-2013, 03:16 PM   #64
la0d0g's Avatar
lolz, page 2
http://www.tacomaworld.com/forum/2nd...ml#post6441878
Old 02-15-2013, 07:09 PM   #65
Des Des is offline
Des is on a distinguished road
Des's Avatar
Des's Tacoma Gallery
This is mine with 5100's all around and TSB, front 5100's set at 0.85". Tires are stock size 245/75/16 Michelins primary goal is MPG average 19-21. I use mine for a truck so frequently have 500-800 lbs in the bed and any more lift than 0.85 with TSB looks like nose is up too high. Also a little rake with empty bed help MPG.
Old 02-15-2013, 10:36 PM   #66
Originally Posted by DK2006Yota View Post
I'll do you a deal and sell you 10 TSBs for 1000 bucks
nice stuck my boot in my mouth on that one. so i checked and i have 3 leafs if i go to the dealer and they fix this issue is the back gonna be higher than the front
Old 02-16-2013, 08:01 AM   #67
mbrogz3000 has a spectacular aura aboutmbrogz3000 has a spectacular aura about
mbrogz3000's Tacoma Gallery
Does anyone know what is the advantage, if any, of using the front eibach springs (1.6" lift) w/ 5100s set at 0" vs. using the stock springs w/ 5100s set at 1.75" ? I think some of the stuff I came across says that as you increase the preload on the the 5100s, the ride comfort decreases which is subjective, but its really hard to keep track with all the different methods of lifting as there is a lot of misinformation out there! Using the preload on 5100s is basically the same as using a spacer block lift inline with the spring, right?
If there is no real functional advantage aside from have pretty gray springs visible, it makes sense just to preload and save the money on the springs.
Old 02-16-2013, 08:54 AM   #68
Hunker Down You Hairy Dawg!
TacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shedTacoDawgfan is one of the sharper tools in the shed
TacoDawgfan's Avatar
TacoDawgfan's Tacoma Gallery
I'm not sure myself but I think it's mostly for a smoother ride with the eibachs. Mine is set at 1.75 with the factory coils and still rides good imo. It may be just slightly stiffer than stock. I was worried about that when I put them on but was worried for nothing. Ride is close to the same with less body roll. Hell my wife complained about how rough it rode before the 5100's and she even says she can't tell a difference now. Aside from getting in the truck anyway.
But you do have the off road which the coils will ride rougher from my understanding.
Old 02-16-2013, 09:10 AM   #69
Tripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shedTripps2012 is one of the sharper tools in the shed
Tripps2012's Avatar
Tripps2012's Tacoma Gallery
Thanks! Btw, can you guys chime in if you have vibration from installing the 5100s and also note if you are 2wd or 4wd? My research is suggesting the vibration is mainly related to the 4wds?
Edwin
No vibs here at all and the ride is much improved over stock I'm very pleased with mine. I think the potential for vibs comes in when you raise the rear as you change the pinion angle.
Old 04-08-2013, 03:30 PM   #70
SR556 is on a distinguished road
Air Force:
SR556's Tacoma Gallery
Sorry, new to Toyota Tacoma. What does "TSB" mean? Thanks
Old 04-08-2013, 03:37 PM   #71
m32 m32 is offline
m32's Avatar
Toyota Service Bulletin
Old 04-08-2013, 03:41 PM   #72
Air Force:
Thanks!
Old 04-08-2013, 03:57 PM   #73
tsup74 is a splendid one to beholdtsup74 is a splendid one to beholdtsup74 is a splendid one to beholdtsup74 is a splendid one to beholdtsup74 is a splendid one to beholdtsup74 is a splendid one to beholdtsup74 is a splendid one to behold
tsup74's Avatar
tsup74's Tacoma Gallery
Nice write up. Looking good
Old 04-08-2013, 03:58 PM   #74
tsup74's Avatar
Technical service bulletin
Old 05-16-2013, 07:18 PM   #75
4me2ply is on a distinguished road
4me2ply's Avatar
4me2ply's Tacoma Gallery
Thanks to this thread I have started down the path to tsb and billies. Today I got my tsb done and tomorrow my bilsteins should be here. I'll post before and after shots. I really like the way the op truck turned out!
Old 05-17-2013, 01:21 PM   #76
double_b [OP] double_b is offline
double_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the sheddouble_b is one of the sharper tools in the shed
double_b's Tacoma Gallery
I know it's too late but you could have waited and put the Billies on first then had the TSB done because they do a front end alignment as part of the TSB...that way you get the alignment for free.
Old 05-17-2013, 08:03 PM   #77
4me2ply's Avatar
check off another taco sitting a little bit higher
Old 05-17-2013, 08:08 PM   #78
asuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shedasuchemist is one of the sharper tools in the shed
asuchemist's Avatar
asuchemist's Tacoma Gallery
Nice post. I have a 2011 TRD sport. Do I need to get the tsb done?
Old 05-17-2013, 08:10 PM   #79
4me2ply's Avatar
If you haul much with your truck and/or want the rear to sit up a little higher I would say get it while you can. It's free.
Old 05-17-2013, 08:29 PM   #80
4me2ply's Avatar
I thought about that but the guys at my dealership were already kind of hesitant to do the tsb. Also, I don't see on my paper work of the tsb install where it says anything about an alignment. I don't think they did one. I'm taking my truck first thing in the morning for an alignment
Getting Rear end TSB done..Question about Billstein 5100's justPLANElane 2nd Gen. Tacomas 10 08-26-2012 01:04 PM
Billstein 5100's, TSB leafs, Eibach springs $400 SMKYTXN 2nd Gen Tacoma Marketplace 39 01-27-2012 01:30 PM
5100 Billstein in rear magnum922 2nd Gen. Tacomas 1 01-17-2012 12:02 PM
Billstein 5100's Rear Part # kws129 2nd Gen. Tacomas 4 01-02-2012 05:44 PM
Billstein 5100's @ 1.75" Rear Spring TSB and 265/70/R17 Tires NC15TRD Suspension 20 01-30-2011 03:49 PM
