Billstein 5100, Rear TSB, My Experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by double_b, Jan 18, 2013.
  1. Feb 15, 2013 at 1:51 PM
    #61
    m32
    m32 Well-Known Member
    Edwin
    2013 DCSB TRD
    Gotcha... btw, I did pick up a 2013 Tacoma two weeks ago.
    Edwin
  2. Feb 15, 2013 at 1:53 PM
    #62
    la0d0g
    running for the hills
    For crawling not hauling
    Well shit boom. Nice rig!
  3. Feb 15, 2013 at 2:09 PM
    #63
    pattersondp
    pattersondp Member
    New Braunfels, TX
    ummm whats a TSB?? and how much are they
  4. Feb 15, 2013 at 2:16 PM
    #64
    la0d0g
  5. Feb 15, 2013 at 6:09 PM
    #65
    Des
    Des Well-Known Member
    KY
    16 DC OR SB Tacoma Super White
    This is mine with 5100's all around and TSB, front 5100's set at 0.85". Tires are stock size 245/75/16 Michelins primary goal is MPG average 19-21. I use mine for a truck so frequently have 500-800 lbs in the bed and any more lift than 0.85 with TSB looks like nose is up too high. Also a little rake with empty bed help MPG.
  6. Feb 16, 2013 at 7:01 AM
    #66
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Does anyone know what is the advantage, if any, of using the front eibach springs (1.6" lift) w/ 5100s set at 0" vs. using the stock springs w/ 5100s set at 1.75" ? I think some of the stuff I came across says that as you increase the preload on the the 5100s, the ride comfort decreases which is subjective, but its really hard to keep track with all the different methods of lifting as there is a lot of misinformation out there! Using the preload on 5100s is basically the same as using a spacer block lift inline with the spring, right?
    If there is no real functional advantage aside from have pretty gray springs visible, it makes sense just to preload and save the money on the springs.
  7. Feb 16, 2013 at 7:54 AM
    #67
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I'm not sure myself but I think it's mostly for a smoother ride with the eibachs. Mine is set at 1.75 with the factory coils and still rides good imo. It may be just slightly stiffer than stock. I was worried about that when I put them on but was worried for nothing. Ride is close to the same with less body roll. Hell my wife complained about how rough it rode before the 5100's :rolleyes: and she even says she can't tell a difference now. Aside from getting in the truck anyway. :devil:
    But you do have the off road which the coils will ride rougher from my understanding.
  8. Feb 16, 2013 at 8:10 AM
    #68
    Tripps2012
    Tripps2012 2014 TRD OR
    NC
    2014 TRD OR
    No vibs here at all and the ride is much improved over stock I'm very pleased with mine. I think the potential for vibs comes in when you raise the rear as you change the pinion angle.
  9. Apr 8, 2013 at 2:30 PM
    #69
    SR556
    SR556 New Member
    TRD Tacoma Sport
    Sorry, new to Toyota Tacoma. What does "TSB" mean? Thanks
  10. Apr 8, 2013 at 2:37 PM
    #70
    m32
    Edwin
    2013 DCSB TRD
    Toyota Service Bulletin
  11. Apr 8, 2013 at 2:41 PM
    #71
    SR556
    SR556 New Member
    TRD Tacoma Sport
    Thanks!
  12. Apr 8, 2013 at 2:57 PM
    #72
    tsup74
    tsup74 Well-Known Member
    Alberta
    2013 Tacoma Double Cab
    Extang Solid Fold, pop and lock
    Nice write up. Looking good
  13. Apr 8, 2013 at 2:58 PM
    #73
    tsup74
    Alberta
    Technical service bulletin
  14. May 16, 2013 at 6:18 PM
    #74
    4me2ply
    4me2ply Member
    Mississippi
    2011 Tacoma TRD Sport 4wd
    TSB rear leaf springs. Bilstein 5100 adjustable ride height front shocks set on 1.75
    Thanks to this thread I have started down the path to tsb and billies. Today I got my tsb done and tomorrow my bilsteins should be here. I'll post before and after shots. I really like the way the op truck turned out!:D
  15. May 17, 2013 at 12:21 PM
    #75
    double_b
    double_b [OP] Well-Known Member
    Red Lion, PA
    '14 DCab Tacoma TRD Off Road
    I know it's too late but you could have waited and put the Billies on first then had the TSB done because they do a front end alignment as part of the TSB...that way you get the alignment for free.
  16. May 17, 2013 at 7:03 PM
    #76
    4me2ply
    4me2ply Member
    Mississippi
    check off another taco sitting a little bit higher
    D0B64E93-696B-46C1-8F09-6DC8417313EB-324_7a72aeaa50e7ba8fce661a1641d96f556a980b2f.jpg
  17. May 17, 2013 at 7:08 PM
    #77
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Nice post. I have a 2011 TRD sport. Do I need to get the tsb done?
  18. May 17, 2013 at 7:10 PM
    #78
    4me2ply
    4me2ply Member
    Mississippi
    If you haul much with your truck and/or want the rear to sit up a little higher I would say get it while you can. It's free.
  19. May 17, 2013 at 7:29 PM
    #79
    4me2ply
    4me2ply Member
    Mississippi
    I thought about that but the guys at my dealership were already kind of hesitant to do the tsb. Also, I don't see on my paper work of the tsb install where it says anything about an alignment. I don't think they did one. I'm taking my truck first thing in the morning for an alignment
  20. May 26, 2015 at 7:38 AM
    #80
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    is that with just front 5100 and stock rear end?
