6 Spd Tranny Noise w/ Clutch Pedal Out
Old 02-01-2013, 09:45 AM   #1
moondeath [OP] moondeath is offline
Plenty of slaves for my robot colony?
moondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shedmoondeath is one of the sharper tools in the shed
moondeath's Avatar
moondeath's Tacoma Gallery
]Im curious if other people here with the 6 speed have the whirring noise from the tranny while the clutch pedal is up and goes away while pushed down. It is not the same sound that other people have experienced with the squeaky/chirp noise. This noise has been going on since I bought the truck new. May be completely normal, just want to see if others have the same noise or not.
Old 02-01-2013, 10:22 AM   #2
2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed2004TacomaSR5 is one of the sharper tools in the shed
2004TacomaSR5's Avatar
2004TacomaSR5's Tacoma Gallery
Really don't think that is normal, not sure what would cause that. Have you taken it to the dealership and asked them?
Old 02-01-2013, 11:54 AM   #3
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Interestingly enough, the throw-out bearing can make noise either pushed in, or when released. However I know that there has been an issue with the TOB and input shaft housing, and I am sure someone here has the link to the thread that discusses it, as well as the fix.
Old 02-01-2013, 12:16 PM   #4
moondeath's Avatar
I've read quite a few of the topics on here about that issue that your speaking of. It seems that those problems had different noises, more like squeak and chirp sounds. Mine has been doing this whirring whining noise since the day I bought it off the lot. Just thought it was normal. Has about 40k miles now. I'm not saying it isn't a problem with the TOB, it may or may not be. I'm curious if this is a common operating noise with other trucks or if its isolated to mine.
And no I haven't had it to the dealer for this yet. I wanted to feel around and see if others do this or not. I'm starting to feel like a dealership troll for having it in there to get all the TSBs done.
Old 02-01-2013, 12:28 PM   #5
Breaking DB Stereotypes
RadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shedRadTaco914 is one of the sharper tools in the shed
RadTaco914's Avatar
RadTaco914's Tacoma Gallery
Well mine is an 08' and it had 92k when I bought it from a dealer and mine does the exact same thing as yours. I noticed mine in the drive through one morning. There is defiantly a TOB issue. However, with mine being way over mileage I am just babying mine till I can upgrade it...I would take yours to the dealer just to see what they say..maybe you can squeeze a new clutch outta them
Old 02-01-2013, 12:39 PM   #6
I feel so Devo
tinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shedtinker_troy is one of the sharper tools in the shed
tinker_troy's Avatar
tinker_troy's Tacoma Gallery
Mine only does it when it's really cold out. Been like that since I got it.
I think you should take it in and let them have a listen.
And don't feel like a troll! You are an informed consumer, nothing wrong with that. If the dealership doesn't like it tell them to complain to toyota, it's not your problem.
Old 02-01-2013, 12:45 PM   #7
roadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shedroadking1 is one of the sharper tools in the shed
roadking1's Tacoma Gallery
my 2009 v6 6-speed was making more of a chirping sound.Throw out bearing was replaced under warranty.The Luk bearings are the problem.
Old 02-01-2013, 01:06 PM   #8
moondeath's Avatar
Mine definitely sounds louder when its cold, but does it all the time. I guess Ill have to take it in again.
Old 02-01-2013, 11:08 PM   #9
ASE Master Tech
Does it sound like a growling noise, similar to a wheel bearing? If so, you still COULD be looking at a TOB. Remember when your clutch is pressed in, ALL of the force of the pressure plate is being pressed against the bearing.
Old 02-01-2013, 11:18 PM   #10
Lipson is on a distinguished road
Lipson's Tacoma Gallery
Mine's made this noise since I bought my truck. I thought it was a problem so I got the dealership to replace the TOB under warranty. A month after replacement the whirring noise came back, more so when it's cold in the morning. I don't think it's an issue, many people with the manual transmission have this.
Old 02-02-2013, 09:40 AM   #11
rustbus is on a distinguished road
rustbus's Tacoma Gallery
i just took my 2012 in with the same issue, they claim normal operation. pronounced when colder, goes away warmed, but always there.
for me, best i can recall, i first noticed it after 5000km and the first use of 4wd. thats what made it stand out. now at 17k kms and about the same really.
Old 02-02-2013, 02:44 PM   #12
maineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shedmaineah is one of the sharper tools in the shed
Law Enforcement:
maineah's Tacoma Gallery
They all do it it's normal neutral gear rattle there is a lot of stuff turning in neutral. As soon as you push the clutch in every thing stops turning.
Old 02-02-2013, 04:59 PM   #13
moondeath's Avatar
Definitely not a growling noise, literally just a whirring noise.
Sounds like this is a pretty common sound, which makes me feel better.
Old 02-02-2013, 05:09 PM   #14
ASE Master Tech
In neutral the input shaft is the only thing turning when the clutch is released.
Old 02-02-2013, 05:30 PM   #15
Aerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant futureAerial Tacoma has a brilliant future
Coast Guard: Flight Mechanic
Aerial Tacoma's Tacoma Gallery
X2 but just when it's cold
Old 02-02-2013, 05:50 PM   #16
djo991 is on a distinguished road
djo991's Tacoma Gallery
same thing here , on october 2012 my TOB were replaced , with new transmission fork , the cylinder .. 1200$ job ... after the job the truck as no more sound .. 2 month later .. it started again .. they offer 1 year job warranty .. this summer i go to the dealership and ask them to do the job again but with this bearing , http://www.urdusa.com/p1260519023/Th...duct_info.html
should fix the problem
Old 02-02-2013, 06:16 PM   #17
drinking whats on sale
92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed
92dlxman's Avatar
92dlxman's Tacoma Gallery
i/ve never driven anything that didnt make noise in neutral with clutch out. harder to notice while driving. if these trucks had a neutral option for t-case, you could row through the gears and really hear a racket. i chalk it up to unloaded chatter.
check your fluid level to be sure, and drive the hell out of it
Old 02-02-2013, 11:17 PM   #18
joes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shed
joes06tacoma's Tacoma Gallery
Bought mine with 40K on it and the noise that you describe. In the 25K since, the throwout bearing was replaced due to chirping. The whirring noise in neutral has remained the same. The regional rep who approved the clutch work told me it is normal for the six speed to make audible noise in neutral.
Old 02-02-2013, 11:46 PM   #19
iroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shed
iroh's Avatar
iroh's Tacoma Gallery
+ the countershaft's gears for 1st and 2nd.
My truck has a little gear noise from the box when spinning in neutral as well. Push the clutch, it goes away. I have the TSB fork and TOB fwiw.
I've yet to find a manual gearbox that doesn't make that low grrrrrrsh sound in neutral. Even my Fit with its highly-praised incredibly reliable 5 speed did it when I picked it up from the dealer with 7 miles on its odometer. Actually, that one was louder than the Tacoma's. I bet it was built like my old noisy d-series tranny with the 3/4 shift hub on the countershaft and spun those freewheeling gears good and fast. Didn't help that Honda's idea of gear lube was friction-modified 5w20 either.
Old 02-03-2013, 05:23 AM   #20
Law Enforcement:
Nope you got 2 counter shafts turning also. Diesel cars/trucks use a dual mass flywheel because the gear rattle is very noticeable with out it due to the high compression. I replaced the DMF in my TDI with a single mass when it when south and if you think the Tacoma is noisy in neutral the VW sounded like a concrete mixer.
Clutch Pedal Squeak/Creak Noise Recall Expands – TSB Highland Logan Technical Chat 10 02-18-2015 12:31 AM
Clutch pedal making a annoying noise?? pl87pll Technical Chat 16 08-03-2011 12:00 PM
Clutch noise when depressing the pedal Yoytoda Technical Chat 7 10-21-2010 09:27 PM
Clutch Pedal Return Spring Noise Second Childhood Technical Chat 1 03-05-2010 09:07 PM
6 SPD Man tranny poll alx_alx_69 2nd Gen. Tacomas 14 12-20-2009 04:56 PM
