super duty carrier mod or stock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bh867, Feb 19, 2013.
  1. Feb 19, 2013 at 12:42 AM
    bh867
    bh867 [OP] Well-Known Member
    idaho/utah
    tacoma
    arb bumper winches- xrc 8 front xrc 10 rear 2 lightforce 140's 40" led light bar Custom CBI built bed 4.88' and arb's front and rear tc long travel
    I've looked around and have seen that it's been done. I did the wookie mod and don't like it, I've had a lot of vibration that i haven't been able to balance out so I'm either going to go back to stock, which sucks for a couple reasons one being it's spendy for a bearing that's not very strong. I have a couple of questions tho. does anyone know which year of super duty bearing guys have used? is it worth the hassle? i plan on being in moab in a few weeks and don't wanna stuck with what i have, it's way too annoying. I'll either order a stock replacement or try the super duty setup, just wanted a lil feedback if theres any. thanks
  2. Feb 23, 2013 at 2:31 PM
    bh867
    idaho/utah
    tacoma
    Nevermind put in a chev 1 ton
  3. Feb 23, 2013 at 4:43 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Nice install, did it improve your vibration issue??
  4. Feb 23, 2013 at 4:46 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Wow nice looks solid
  5. Feb 23, 2013 at 6:44 PM
    bh867
    idaho/utah
    tacoma
    Yes no vibes whatsoever, smooth as can be
    Alexely999 and Running Board Man like this.
  6. Feb 23, 2013 at 6:45 PM
    bh867
    idaho/utah
    tacoma
    Thanks, it's a lil bit ghetto, I used some scrap metal I had layin around. It's ugly but solid.
    Alexely999 likes this.
  7. Feb 23, 2013 at 7:06 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I heard a couple of dudes had issues with the "wookie" mod. I am the originator of that mod, and have about 25K on it without issue. I wonder if some drivelines are out of balance and the solid bearing amplifies it or something?
    (pics of what I did for those who don't know wtf we're talking about)
  8. Feb 24, 2013 at 5:15 PM
    bh867
    idaho/utah
    tacoma
    I'm not sure what the problem was, I had the driveline rebalanced when I installed the wookie and it helped but didn't cure it completely.
  9. Jul 2, 2013 at 5:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm bumping this with a question. The wookie strength carrier looks to drop the carrier quite a bit assuming the same mounting bolts are used. Is that the case? If so, anyone find a heavy duty (preferably servicable) carrier that bolts into the stock location?
  10. Jul 2, 2013 at 5:48 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    you could probably email wheeler's and ask them what bolts are used for the OME carrier bearing drop
  11. Jul 2, 2013 at 5:51 AM
    Pugga
    Massachusetts
    No, that's the problem, I don't want or need my carrier bearing dropped that far. My carrier bearing is in the stock location now, I just need to replace it. Since the stock bearing assembly allows for too much play, I would like to use a stronger bearing. I really like the Wookie strength bearing setup but I don't need mine dropped over an inch. I'm looking for a heavy duty bearing that will keep it at stock height and bolt into the stock location.
  12. Jul 2, 2013 at 6:42 AM
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Yep, I'm pretty sure that's the issue with the wookie- it drops the carrier too far. I searched and searched a while back and couldn't find a heavy duty one that will go back in the stock location. I'm replacing mine tomorrow with stock because I have to leave town and don't have much time. But the next time, I plan to just cut everything out and do something like the OP did.
  13. Jul 2, 2013 at 6:45 AM
    Pugga
    Massachusetts
    Thanks! I will admit, I really like his solution. Simple, yet effective. I might end up doing the same, I might just grab the Dorman bearing off Rock Auto. For $40, how bad can it be :notsure:
    Right now, I've got the stock carrier but I injected silicone all around the bearing itself to help stiffen it up. It worked for a while but it's getting sloppy again...
  14. Jul 2, 2013 at 8:29 AM
    Toy Yoda
    Garrett
    06 DCLB
    no i know im jsut saying you could get the specs on the bolts from them, thread length/diameter etc
  15. Jul 2, 2013 at 8:39 AM
    Pugga
    Massachusetts
    I actually have an OME CB drop rolling around in my tool box :laugh: I just don't need the drop, I need stock height.
  16. Jul 2, 2013 at 11:39 AM
    nimrod712
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Yeah, the Dorman is the one I ordered. We'll see how it lasts. If it makes 15-20k I'll be satisfied, and then I'll just re-work the whole mount.
  17. Mar 7, 2018 at 6:36 AM
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I ended up getting a Tom Wood's one piece after I fubar'd that one. It worked great. http://www.4xshaft.com/
  18. Mar 7, 2018 at 9:44 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    The spicer oem Cartier bearing is only 70$
    Mine is destroyed at 200k almost
  19. Mar 7, 2018 at 10:31 AM
    anthony250f
    Anthony
    San Diego, CA
    The spicer and the Toyota are the EXACT same bearing
