digital air command system
Old 02-24-2013, 04:42 AM   #1
trd sport [OP] trd sport is offline
trd sport is on a distinguished road
trd sport's Tacoma Gallery
Smile digital air command system
I am installing Firestone digital air command system on my truck today and it calls for an ignition hot lead under the dash for the digital reciever part in the cab that displays the psi. I need some help finding an ignition hot lead that comes on only when the ignition is on and a good ground under the dash. Any help will be appreciated.
Old 02-24-2013, 06:58 AM   #2
Benjamin Newman
Btnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shedBtnewman is one of the sharper tools in the shed
Btnewman's Avatar
Btnewman's Tacoma Gallery
How much power will this be pulling?
Old 02-24-2013, 07:10 AM   #3
Benjamin Newman
Btnewman's Avatar
Check out your local auto parts store and pick up an "add a fuse"
Then all you have to do is pick a fuse slot that is ignition controlled such as the aux power fuse or radio. Then plug in the add a fuse and pull power there.
Keep in mind that the compressor itself needs to be powered through a relay.
Old 02-24-2013, 02:24 PM   #4
I am aware of the compressor is wired through the relay and straight to the battery, the control pad does not use much amperage just to control the psi that is relayed to the pressure switch. I am considering the the add a fuse but also considering just splicing into the cig lighter.
Old 02-24-2013, 03:10 PM   #5
Benjamin Newman
Btnewman's Avatar
Copy. Either way should work out nicely! Does the digital readout give you a constant airpressure reading? Like, maybe I can possibly put up just the readout and sender and be able to moniter my air system?
Old 02-24-2013, 03:34 PM   #6
Yes the digital readout constantly moniters the air pressure andwill not go below 5 psi. Really works very well
Command start stopped working? sippinoniceteaz 2nd Gen. Tacomas 3 12-04-2012 09:41 PM
Viper 5901 command center Blaise22 2nd Gen. Tacomas 5 04-29-2012 11:12 AM
turn the remote beep off on the unlock command Rgpracer 1st Gen. Tacomas 7 05-11-2011 09:03 AM
dakota digital air gauge dragginjess Buy / Sell / Trade 0 04-16-2010 09:23 PM
FS-Volant Cold Air Intake System and Volant Ram Air Scoop Joe B Buy / Sell / Trade 3 12-04-2008 05:34 AM
