Help with rotors
Old 02-24-2013, 01:24 PM   #1
fl10 [OP] fl10 is offline
fl10 is on a distinguished road
fl10's Tacoma Gallery
Help with rotors
I am finally getting around to installing the EBC slotted rotors and green pads, well I thought I was. After beating on the rotor till my face turned blue I just put it back together. I'll give it a stab next weekend.
Here's the question, on the face of the rotor there are two threaded holes of which I assume are to be used for assisting in breaking these things free. Does anybody know what size and thread type screws I need to buy? Also what material, I don't want anything that might snap off in there.
Old 02-24-2013, 01:39 PM   #3
S.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shedS.B. is one of the sharper tools in the shed
S.B.'s Avatar
S.B.'s Tacoma Gallery
I wana say 8mm
Old 02-24-2013, 01:44 PM   #5
the logical one
fixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shedfixer5000 is one of the sharper tools in the shed
fixer5000's Tacoma Gallery
use some grill paint on the inside of the new rotors hat surface...next time itll come right off
Old 02-24-2013, 02:30 PM   #6
Very Nice !
packfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud ofpackfan88 has much to be proud of
packfan88's Avatar
packfan88's Tacoma Gallery
i just replaced my rotors on thursday night. From the time I stopped the truck til the time I pulled away loaded back up it took me an hour and 15 mins. But i had just replaced them last year so the bolts were easy to come out and I only did rotors not pads. two bolts each and a brake line holder bolt. Piece of cake.
I used ebc oem last time....same this time cause i wasnt sure my problem. i had vibrations when braking from like 40mph to like 15mph then it would stop. So i replaced them first incase it wasnt even the problem. Which it was.
i have green stuff 7000 pads
Grill paint? I just put some anti seize i had from other stuff on there.
Old 02-24-2013, 02:54 PM   #7
Pasti-Dip Free Since 1983
Pugga's Avatar
Pugga's Tacoma Gallery
Interesting... hadn't thought about that. I just caked some neverseize behind the new rotor. My new rotors don't have the jacking holes.
Old 02-24-2013, 03:16 PM   #8
08TacoTrD is just really nice08TacoTrD is just really nice08TacoTrD is just really nice08TacoTrD is just really nice08TacoTrD is just really nice
08TacoTrD's Tacoma Gallery
A little bit of anti-seize and they'll pop off the next time. I even put a dab or two on the front where the rim meets the rotor to keep the rim from seizing to the rotor.
Old 02-24-2013, 03:46 PM   #9
miniceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shedminiceptor86 is one of the sharper tools in the shed
miniceptor86's Avatar
Army: Cook, 589th Combat Engineers, Ahn Khe, RVN
miniceptor86's Tacoma Gallery
A plus for anti-seize here. Doesn't take much, likes to magically appear on fingers and hands and just as magically resist leaving fingers and hands.
Old 02-24-2013, 09:54 PM   #10
Kylie's dad
WilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shedWilsonTheDog is one of the sharper tools in the shed
WilsonTheDog's Avatar
WilsonTheDog's Tacoma Gallery
Good to know. I'm doing mine for the first time in a couple weeks and I assumed a BMFH (Big Mother Fing Hammer) would do the trick but possibly not.
Old 02-25-2013, 04:25 AM   #11
Bmfh only if you aren't reusing the rotors
Old 02-25-2013, 05:28 AM   #12
the logical one
id have to agree with that and thats why i use paint lol
Old 02-25-2013, 05:19 PM   #13
Thanks much for all the replies. This is the first rotor change but I will definetly try either the paint or the anti-seize for the future. Florida's salty air probably has something to do with it.
Old 02-25-2013, 09:44 PM   #14
Kylie's dad
Correct, I am not and neither is the OP.
Old 02-28-2013, 04:09 AM   #15
Texoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shedTexoma is one of the sharper tools in the shed
Texoma's Avatar
Navy: Machinist Mate NEC 4283
Texoma's Tacoma Gallery
Originally Posted by S.B. View Post
I wana say 8mm
Originally Posted by Texoma View Post
Sounds close, maybe 8x1.25. I know that they use those bolts on the truck, cuz that's how I got the originals.
Checked the threads yesterday, and the bolts needed are going to be 5/16x18 , should be universal for all rotor and drum applications.
Old 03-01-2013, 04:30 AM   #16
Good info. Thanks for taking the time to verify it.
Old 03-03-2013, 11:26 AM   #17
Update
Holy cow what a difference. No more brake noise! No more shimmy in steering wheel when braking.
Also, my brake pedal used to go down an unnatural distance (like half way) before braking occured, now the pedal goes a very short distance before they start to work. Brakes feel like the wife's 4Runner now. Night and day difference from before.
As far as the pedal distance maybe the new rotors are wider or maybe the pad are just thicker but they engage perfectly now.
I think I am more excited about the new brakes then I was when the lift went in lol.
BTW the screws popped the old rotors off with ease. The bolt size ended up being M8-1.25 x 30
As a perk the drilled/slotted rotors look bad ass sitting behind the rims. Ok, maybe not bad ass but pretty cool atleast.
Now let's see how long they last.
Old 03-03-2013, 01:37 PM   #18
Rotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud ofRotorpilot has much to be proud of
Rotorpilot's Avatar
Rotorpilot's Tacoma Gallery
how much did the new rotors & pads set you back?
Old 03-04-2013, 05:00 AM   #19
I ordered online from autoanything.
EBC Green stuff brake pads $79.63
EBC Sport rotors $232.07
No Tax and free shipping.
Old 03-04-2013, 05:28 AM   #20
gpeet is on a distinguished road
gpeet's Tacoma Gallery
8x1.25
Rotors Chef lamb 2nd Gen. Tacomas 7 11-19-2012 09:06 PM
Warped Rotors MiamiLaker New Members 2 05-16-2012 03:03 AM
rotors jr124gamboa 2nd Gen. Tacomas 4 05-23-2011 12:52 PM
Brembo blank rotors vs. OEM rotors dragsterhund Technical Chat 1 03-15-2011 05:39 AM
Brake rotors Justin723 1st Gen. Tacomas 6 11-27-2009 09:24 AM
