Missing part on OEM roof rack?
Old 03-02-2013, 02:16 PM   #1
Tuckerhump [OP] Tuckerhump is offline
cheese'd out of my mind
Tuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shedTuckerhump is one of the sharper tools in the shed
Tuckerhump's Avatar
Tuckerhump's Tacoma Gallery
I just recently installed an OEM roof rack on my truck but during installation I noticed that there was nothing to screw the pivot torx bolt into on the passenger side. The driver's side had basically a threaded piece of metal that it screwed into but there was nothing on the passenger side. Did anyone else have this problem?
Passenger side, looking down into where the pivot bolt should screw into.. The black that you can see is the top of the roof.
bottom of Driver side
Pivot bolt on driver side
Old 03-02-2013, 02:42 PM   #2
Cain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant futureCain has a brilliant future
Cain's Avatar
Cain's Tacoma Gallery
If I'm reading you correctly?
If your talking cross bars, then 1 side screws on and the other snap locks in place, so you can open and close them?
They should also be staggered, my passenger side is screwed and my drivers side is snapped in
Old 03-02-2013, 03:01 PM   #3
Tuckerhump's Avatar
Yea the issue is I cant screw in one side. Basically the nut that you screw the pivot bolt into is missing. I can snap the other end into place its just not sturdy enough without being able to have the pivot bolt tightened into something. If that makes sense
Old 03-07-2013, 11:17 AM   #4
Cain's Avatar
Any updates?
Old 03-08-2013, 06:32 AM   #5
Tuckerhump's Avatar
Ive been talking with TRDparts4u and it seems that it was shipped without a square nut and o-ring in the rack itself. So I have that coming in the mail and hopefully that will resolve the issue.
Old 03-11-2013, 09:23 AM   #6
Tuckerhump's Avatar
Here are the missing pieces. Put them in the rack and it was good to go. Real happy with the customer service from TRDparts4u. I would definately recommend them to others
Old 03-11-2013, 01:52 PM   #7
Senor Taco
Mademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shed
Mademan925's Avatar
Mademan925's Tacoma Gallery
I had the same issue. I found my square nut loose in the big box.
Old 05-20-2014, 12:14 PM   #8
imDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shedimDARRIN is one of the sharper tools in the shed
imDARRIN's Tacoma Gallery
Is there a specific part number for the square nut and O-ring? I got all the way through the install processes and just about to put the RH crossmember on with the pivot bolt when i realized it was spinning around and around into nothing..
FS (Atlanta) OEM DC Roof Rack & Baja Rack combo Molon Labe 2nd Gen Tacoma Marketplace 7 10-02-2014 11:56 AM
How does OEM roof rack attach to roof? Turdburglar 2nd Gen. Tacomas 27 07-11-2014 01:36 PM
OEM Roof Rack - Rubber Strips For Roof? stewartx 2nd Gen. Tacomas 2 11-07-2012 02:20 PM
OEM Roof Rack and Rubber Roof Strips matts11 2nd Gen Tacoma Marketplace 22 02-07-2012 07:27 PM
Installing the Toyota OEM Toolbox: I think I am missing a part macjedi 2nd Gen. Tacomas 1 11-08-2010 05:13 PM
