Lift Alignment Specs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 11, 2009.
  1. Mar 30, 2010 at 7:53 PM
    #41
    waller24
    waller24 Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    i have a 1.5 in lift from a small coil spacer i got from Fatboys garage
    yeah stock uca's.
  2. Feb 4, 2011 at 1:33 PM
    #42
    Blue76
    Blue76 Well-Known Member
    Georgia
    08 Prerunner Double Cab
    Dealer installed Leather, Truck Cover USA roll up cover, Pop n Lock, Bilstein 5100's on 4 corners set at 1.75, Rear Spring TSB. USA Spec iPhone adapter, 265/75/16 Mickey Thompson ATZs.
    ok... I am resurrecting an old thread here....
    I had the TSB done on my 08 a while back. The dealer installed 5100s set at 1.75 at the same time. The did a wheel alignment in the process.
    It drives like crap. I have been dealing with it for months and to be honest have gotten used to it being a little quirky on the highway. It wanders a little...
    Today I took my truck to the local shop down the road from work... I took it for a tire rotation but noticed they have installed a front end machine.
    I wrote down some of the specs from this thread and asked him to try and set mine up like the preferred numbers I read here.
    I just picked it up and here is what I got...
    Toe 0
    Caster left 1.8
    Caster Right 1.0
    Camber 0
    The caster worries me a little... I would think you would want the numbers to be closer left to right. I would think 1.8 casteron both sides would have been better.
    I have only driven it on the two lane for a couple of miles. I will hit the interstate this evening and see how it does.
  3. Nov 10, 2016 at 3:23 PM
    #43
    mreen428
    mreen428 Well-Known Member
    Shmatty
    Queens, NY
    11 DCSB TRD Spt
    Chris I got my truck lifted today with billies at .85 and eibach. Had LR UCA installed too.
    Caster is left 3.8 and right 4.0
    Camber is left .9 and right 1.0
    Toe is left .05 and right 0
    Is this terrible?
    Mr.PowerTrays likes this.
  4. Jan 14, 2017 at 10:40 AM
    #44
    Mr.PowerTrays
    Mr.PowerTrays Well-Known Member Vendor
    Maverick
    Colorado
    2011 dcsb trd or
    i like your style! i finally found someone who would do what i asked..
    mreen428[QUOTED] likes this.
  5. Jan 14, 2017 at 2:19 PM
    #45
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Did you read your own article? Castor and Camber affect road crown.
    Castor has a greater affect on road crown, plus I like even tire wear so I request equal camber of both sides close to zero as possible, with .2 to .4* greater castor on the passenger side to corrrect road crown. I ask for the most castor available, which I usual don't get as much as I'd like. I also like toe being closer to zero.
    There are massive books out there about steering geometry. A buddy of mine designs race cars and reminds me of how little I know. I just stick to the basics.
    Edit: This thread is hella old o_O
  6. Jan 28, 2017 at 5:08 AM
    #46
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    regardless of what castor and toe are set for, cornering is primarily effected by camber, and camber should be maintained at somewhere between -1.5 to -2 degrees to ensure proper wear of tires and to ensure the largest possible contact patch. When you corner, the outside tire should return to just about straight up while the inside tire runs more camber, probably closing on 3 * for a few seconds. This is normal and means that camber is set properly, when its improper the outside tire will be positively cambered and the inside of that contact patch will suffer greatly, hamstringing cornering grip. Castor would ideally be 4.5-5.5 degrees, and toe somewhere between 0 and .2* out, depending on personal preference. .2 would be if you like your truck to have a very lively feel and like diving into corners, as toe enhances turn in response (not grip, however)
    Jeff108 and toyo522 like this.
  7. Jan 20, 2018 at 2:21 PM
    #47
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    So I just installed OME 90000s, 60091s, Dakar leafs, light racing UCAs, and 886 coils. These are my current numbers. What would be good settings for my setup. Also I'm on 265/70/17s but plan on going to 285/70/17s. Thank you.
  8. Jan 20, 2018 at 4:34 PM
    #48
    stevotivo12
    Stephen
    depends. If you mostly go in straight lines and dont like to hammer it through corners then I'd say:
    Camber: 0
    Toe: .125 (in)
    Caster: 3.5-3.8
    But if you like to take corners fast you'd want something more like:
    Camber: -1.0
    Toe:0
    Caster: 3.2
  9. Jan 20, 2018 at 6:40 PM
    #49
    jca
    jca Well-Known Member
    My specs:
    Camber: 0.9 deg L, 0.9 deg R
    Caster: 4.2 deg L 4.3 deg R
    Toe 0.09 deg L, 0.05 deg R
    Drives amazing and I don't rub in any direction at full lock.
  10. Jan 20, 2018 at 6:53 PM
    #50
    nazlax10
    David
    Woodstock, GA
    Thank you both so much! I ended up with these settings.
    Camber: 0
    Toe: .125 (in)
    Caster: 3.0
    Any idea how to increase caster more without affecting camber?
  11. Nov 21, 2018 at 9:13 AM
    #51
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Denver
    Off-road Tenthouse
    an empty wallet
    Vibration may be due to the driveline angle. Look into the carrier bearing drop
  12. Jul 31, 2019 at 2:17 PM
    #52
    5280Dude
    5280Dude Member
    2012 DCSB TRD TX Pro
    5100 Bilstein Kit with Toytec Boss rear and 2" AAL Tuff Country UCA
    I just had my truck aligned yesterday after installing aftermarket UCA's over the weekend. They set Toe at 0, Caster at 0, and Camber at 2.5 and I have to say the truck drives worse than before the alignment. ALso, my tires are rubbing badly on mud flaps.
    I installed the Bilstein 5100's with Eibach 620 springs about 4 weeks ago. In the rear, added 2" leaf and BOSS struts.
  13. Jul 31, 2019 at 2:26 PM
    #53
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Ideal settings
    Toes and camber to OEM
    Castor 3.5 or higher for lifted
    Especially with oversized tyres.
    Not my opinion, comes from people that do this for a living. If you can get to 3 that is ok but better is 3.5 or higher.
    It puts the wheel back where it needs to be in the well. Also helps with stability.
  14. Jul 31, 2019 at 2:32 PM
    #54
    5280Dude
    5280Dude Member
    I figured Caster at 0 would put the tires back to center. Guess I should read up a bit more on alignments.
    I have 265/75/16
  15. Jul 31, 2019 at 2:40 PM
    #55
    Muddinfun
    Muddinfun Well-Known Member
    Caster is like the neck of the bicycle. When you adjust the lower control arm cams to move the lower ball joint forward, that increases caster and has the added effect of moving the tire away from the rear of the wheelwell where it commonly rubs.
  16. Jul 31, 2019 at 3:00 PM
    #56
    5280Dude
    5280Dude Member
    So I should actually be asking for at least a 3 degree, if not more, to keep the tires off the mud flaps like Gixerkiller had said.
    So how the hell are all these trucks with lifts getting by with Caster at 2.5? Apparently this is the magic number.
  17. Jul 31, 2019 at 3:03 PM
    #57
    Gixerkiller
    Dennis
    Taylor, TX
    You still have mud plates???:eek:
  18. Jul 31, 2019 at 3:07 PM
    #58
    Gixerkiller
    Dennis
    Taylor, TX
    If I remember, that is as far as I could get with the OEM UCA’s. It liked to dance on less than properly maintained roads...it is not uncommon to have one side at a higher number than the other. I think my right side is 3.7 and the left is at 3.2. I do have a right drift, but I did not realign after fitting larger tyres... at some point I will.
  19. Aug 2, 2019 at 10:04 AM
    #59
    5280Dude
    5280Dude Member
    Front mud flaps are coming off this weekend!
  20. Aug 2, 2019 at 10:06 AM
    #60
    5280Dude
    5280Dude Member
    I'm planning to take the truck back for alignment and see if they'll adjust as much as possible.
