Idler Pulley Replacement. How to:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TAKoma907, Mar 8, 2013.
  1. Mar 8, 2013 at 4:22 PM
    TAKoma907
    TAKoma907 [OP] Well-Known Member
    Charles
    Alaska
    06 Tacoma
    2.5" Lift, Bilstein shocks, 10" Sub, CCFL Halo Headlights, K and N Air Intake, MagnaFlow Exhaust
    Hey I have a new Idler Pulley that I want to put on my truck. I searched on here for a how to and didnt see a writeup. Maybe I am blind, but I didnt find anything. I don't have a lot of time to waste as I am going to break some company policies by working on my truck in the shop so I was hoping to read a write up first so I don't run into any surprises. Any help is good help, if not I will just wing it. Thanks!
  2. Mar 8, 2013 at 4:48 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
    Anyone? ...Bueller? ...Bueller?
  3. Mar 8, 2013 at 5:12 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
    I guess I'm winging it
  4. Mar 8, 2013 at 5:57 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Good luck! It's not hard. I changed my lower idler today and it was fairly easy. If the V6 is anything like the 4 cyl then wrenches/sockets needed is all 14mm.
  5. Mar 8, 2013 at 10:05 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
  6. Mar 9, 2013 at 5:50 AM
    Brandon###
    Brandon### Well-Known Member
    Step 1 remove belt
    Step 2 remove old idler pulley
    Step 3 install new idler pulley
    Step 4 install belt
    It's usually that easy. Good luck
  7. Mar 9, 2013 at 3:23 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
  8. Mar 9, 2013 at 3:25 PM
    TAKoma907
    Charles
    Alaska
    06 Tacoma
    Not sure why I need to remove my belt. I can't work on my truck if my pants keep falling down. Send better instructions
  9. Mar 9, 2013 at 8:13 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Why do you want to replace the idler pulley?
    I notice my truck makes a squeaking noise when I first start my truck. I'm guessing it's the belt though. Almost 60K miles on it.
  10. Mar 10, 2013 at 6:12 AM
    iroh
    michigander
    tonneau
    LMAO
    Mine sounded like a roots supercharger. Bearing was shot.
    OP's was even older than mine so it was probably time.
  11. Mar 10, 2013 at 10:43 PM
    Syncros
    Syncros Well-Known Member
    I replaced all 3 idlers and the complete tensioner assembly yesterday. I had plenty of tension but some internal part of the arm (a bushing I suppose) was worn out allowing it to misalign the belt.
    First I starting by removing the following:
    Battery
    Engine cover
    Skid Plate
    Serpentine belt
    Alternator and wiring harness brackets
    Next I removed the four AC compressor bolts and moved it away from the tensioner assembly. The lower bolts are difficult but if you are patient and use a 12 point socket and fine tooth ratchet, no problem.
    Removed the tensioner assembly via the 5 mounting bolts, Replaced with a Gates unit along with the 3 idler pulleys (I recommend these) and a new Gatorback belt.
    Took me 2.5 hours start to finish, the FSM helped with bolt locations and the torque specs are listed in it.
    lo2hi, tacoman45 and tcBob like this.
  12. Mar 11, 2013 at 12:20 PM
    ncsilver06
    ncsilver06 Member
    Cary, NC
    06 Silver SR5 4WD SB
    Lighted paint-matched running boards, ARE hard tonneau cover, dual chrome exhaust, CIPA 36400 Auto Dimming Rearview Mirror, EGR in-channel rain guards, 4x4 illuminated light switch (rcbs204)
    My truck was doing this too and a new belt fixed it. Cheaper and easier to change the belt out first before messing with idler pullies.
  13. Sep 23, 2020 at 9:02 PM
    ice820c
    ice820c Member
    N.C.
    06 Tacoma SR5 Sport
    Flow-master 40 series Duals. K&N Air Filter.
    Sir,
    It’s been nearly 8 years since you posted this and tonight I started this job. I am no pro, but I got everything off to the 5 bolts holding the tensioner assembly to the block. I could not get them off. Neither wrench I used could get a good enough angle nor could I loosen it by hand. I tried for a while and failed. So I took the new pulley off my new Gates assembly and put it on the factory assembly. I will reassemble everything tomorrow and hopefully come out successful.
  14. Sep 23, 2020 at 9:07 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    just an FYI that likely won’t work for Belt clearance reasons. You CAN order a replacement bearing for the factory tensioner OR febest makes a pulley that is compatible with the oem tensioner.
    Torspd, Chris(NJ) and ice820c[QUOTED] like this.
  15. Sep 24, 2020 at 7:27 AM
    Syncros
    It's been a long time. Not sure how I got through it, I remember the AC compressor bolts being the difficult part.
  16. Oct 6, 2020 at 4:37 PM
    ice820c
    ice820c Member
    N.C.
    06 Tacoma SR5 Sport
    Well the Gates pulley worked in Place of the old one. No rubbing or ill effects after two weeks.
    I’m glad I had this thread to go by and I thank you all for contributing and replying!
    EdgemanVA likes this.
  17. May 23, 2021 at 6:44 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I think my lower idler no 1 is bad. I can't get a good enough grip on the bolt because of the oil cooler. Can I simply unmount the cooler and move it temporarily to replace the pulley or does it need to be more extensive?
  18. May 23, 2021 at 10:05 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    @b3itz - are you attempting removal from the bottom? On OEM setups, there is no need to remove anything but the belt and lower brackets that prevent the approach from the bottom.
  19. May 23, 2021 at 11:42 AM
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Cool so I popped off my skid plate and I see I can get there from under.
    What lower brackets?
  20. May 23, 2021 at 12:09 PM
    Chuy
    Lakeside, CA
    Silver Taco
    @b3itz - They are the mounting brackets for the skid plate. You may only need to remove the driver side one, or not - for me, removing it made it easier to rotate my ratchet.
    Edit: actually, for using my pry bar on that bolt.
