2008 Tacoma timing problem
Old 03-26-2013, 06:07 PM   #1
tw1952 [OP] tw1952 is offline
tw1952 is on a distinguished road
tw1952's Tacoma Gallery
My truck trys to start and then dies similar to a timing belt slip or break. I undrrstand that I have a timing chain. Does thos happen and what is the fix.
Tw1952
Old 03-26-2013, 06:18 PM   #2
Manic Mechanic
Hugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shedHugh Morron is one of the sharper tools in the shed
Hugh Morron's Avatar
Hugh Morron's Tacoma Gallery
Check for code first. That will generally lead you in the right direction.
Old 03-26-2013, 06:23 PM   #3
I am on the side of Mauna Kea and without diagnostic equipment. Any ideas?
Old 03-26-2013, 06:48 PM   #4
Jimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shed
Jimmyh's Avatar
Navy: MT1 (SS) retired
Jimmyh's Tacoma Gallery
Worn timing chains have been known to jump teeth. Usually only in very high mileage engines.
A problem with the VVT system... It could also be lots of things other than the timing.
Old 03-26-2013, 07:15 PM   #5
Thank you. I suspect a jump in the chain
Same noise as a belt..132000 miles on my 08,all on The Big Island of Hawsii
Old 03-26-2013, 07:21 PM   #6
FPS-a-holic
Fractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shedFractured is one of the sharper tools in the shed
Fractured's Avatar
Fractured's Tacoma Gallery
The truck would run terrible on a jumped chain tooth, if even at all.
If its a noise- not a driveability issue, it could be a chain guide/ water pump etc.
Old 03-26-2013, 07:24 PM   #7
Banned
Kirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shedKirk1589 is one of the sharper tools in the shed
Kirk1589's Tacoma Gallery
May be electrical with VVTI I highly doubt the chain jumped it would start sounding like marbles in a glass jar on cold starts. It just won't randomly do this. Anyways how the F do you rack up a 132k on a island honestly
2008 Tacoma timing problem tw1952 2nd Gen. Tacomas 0 03-26-2013 05:56 PM
Timing chain problem Valve problem ticking noise from engine maza mike 1st Gen. Tacomas 0 03-24-2013 06:57 PM
2008 Tacoma Wheel Stock Ornament problem JustinF1 2nd Gen. Tacomas 12 08-10-2012 07:27 PM
Toyota Tacoma 2008 4x4 shift problem ritetoyota Toyota Trucks & SUVs 11 03-22-2011 03:44 PM
2008 toyota tacoma-4x4 shift problem ritetoyota Toyota Trucks & SUVs 1 03-14-2011 09:16 PM
