Front Lift - Spacer or 5100s
Old 03-28-2013, 10:00 AM   #1
Swank [OP] Swank is online now
Certified Mall Crawling Instructor
Swank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shedSwank is one of the sharper tools in the shed
Firefighter:
Swank's Tacoma Gallery
Just looking for some quick information regarding the lift.
Right now, I have a 3" spacer lift in the front which makes the back sit lower than the front, approx 1".
I'm looking to level it out, in the rear I have 3 leafs on each side, so if I were to buy a 1" AAL would that level it out?
Also, if I were to order a set of Blistein 1500s to replace my spacer lift, would I be better off with the 1500 lift instead of the spacer? Or should I just leave it how it is?
Thank for any information, thanks!
Old 03-28-2013, 10:02 AM   #2
Red
Large's Tacoma Gallery
If you replace the spacer lift with the 5100s and set them to 2.5 you might get rid of your bro lean.
Old 03-28-2013, 10:05 AM   #3
Firefighter:
The only problem with getting rid of the spacer, is that it is 3" and the 5100 will only go to 2.5"
I was researching around and 285/70/16 tires need a 3" lift to clear them with spacers, am i correct?
Only reason i'm asking is because i'll be buying a new set of tires closer to graduation.
Old 03-28-2013, 10:07 AM   #5
Red
More people run 285s with 2.5" of lift than anything here I am willing to bet. I am also willing to be not many people have 3" of front lift, I ran 285s on 2" of front lift and running 255/85 on 2-1/4" of front lift right now.
Old 03-28-2013, 10:08 AM   #6
Firefighter:
Originally Posted by Wildlandtaco View Post
Your gunna love the ride with 5100 compared to the spacer lift
That's what i'm hearing, I'm just worried about being able to clear 285/70 tires with only 2.5" lift.
Old 03-28-2013, 10:09 AM   #7
Firefighter:
Did you have to trim anything to make them fit?
Old 03-28-2013, 10:12 AM   #8
Nothin
krimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shedkrimson is one of the sharper tools in the shed
Gender: Trans
krimson's Tacoma Gallery
You can clear 285s with 2.5" of lift on the front. It will require trimming but it will clear it... As for the rear, im guessing you have the standard 3 leaf pack that comes with our trucks. So you will need the 2" AAL so the truck wont sit high in the front.
Old 03-28-2013, 10:13 AM   #9
shit happens then you die
jobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shedjobrien is one of the sharper tools in the shed
jobrien's Avatar
EMS:
jobrien's Tacoma Gallery
Haha
Old 03-28-2013, 10:16 AM   #10
Senor Taco
Mademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shedMademan925 is one of the sharper tools in the shed
Mademan925's Avatar
Mademan925's Tacoma Gallery
Im very happy with my 5100s. Goodluck clearing 285s
Old 03-28-2013, 10:16 AM   #11
Red
Of course I had to trim, removed mud flaps, rubbed the cab mount, and front bumper until I got an aftermarket plate bumper.
Old 03-28-2013, 10:20 AM   #12
Firefighter:
If i were to lose the 3" front spacer, replace it with the 1500s set to 2.5" to level it out with the stock height in the back, would 265/70 look alright?
Alright meaning not looking small.
Old 03-28-2013, 10:20 AM   #13
Firefighter:
Old 03-28-2013, 10:22 AM   #14
Nothin
Gender: Trans
Or you could put the 1500s on the 1.75 setting and it will be about level with the rear and it will look good with 265s...
Old 03-28-2013, 10:25 AM   #15
Firefighter:
Hmm, I kind of like the look of the 3" lift though, that'd be my only problem
Old 03-28-2013, 10:28 AM   #16
rjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shedrjsimz is one of the sharper tools in the shed
Navy: Airframer
rjsimz's Tacoma Gallery
Thought you were selling your truck?
Old 03-28-2013, 10:28 AM   #17
Nothin
Gender: Trans
If you are concered with what 265s look with 2.5" of lift or 3" here's A thread with people who are running 265s with 2.5" of lift
http://www.tacomaworld.com/forum/1st...inch-lift.html
Old 03-28-2013, 10:29 AM   #18
Firefighter:
Had a change of heart, can't let her go. haha
Old 03-28-2013, 10:33 AM   #19
Firefighter:
Appreciate it, I think I might stick with the spacer in the front, and an AAL in the rear to make it level with the front, then go with 285s with wheel spacers and a little bit of fender trimming. Wouldn't have to do much seeing as I don't offroad.
Old 03-28-2013, 10:42 AM   #20
penguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shedpenguins_cc is one of the sharper tools in the shed
penguins_cc's Avatar
penguins_cc's Tacoma Gallery
Send a message via Skype™ to penguins_cc
I think so. A 275/70 is also an option, although there is a lot less options. The size is just right for most people without trimming.
You have a DCSB so a 265/70 would look alright - some of the more aggressive tires look great IMHO. 285s will be additional headache and cost. You might get away with little trimming and cutting but it will still bring other issues such as gas mileage, higher cost of tires and fitment of spare tire.
Install Ez Lift 3" FRONT LIFT STRUT SPACER KIT? TEX357 Suspension 44 11-22-2013 01:47 PM
Front Spacer Lift on a 5-Lug goufcustom 5 Lug 4 02-24-2012 01:31 PM
Top plate spacer lift on 5100s? gacandido2010 Suspension 13 11-21-2011 06:19 PM
which to get..Spacer lift or 5100s iRepLONGBEACH 2nd Gen. Tacomas 30 06-04-2011 05:49 PM
Spacer/AAL lift with 5100s inlinejohn Suspension 4 04-18-2010 03:18 PM
