URD TCAI and BAMF light bar
Discussion in '2nd Gen. Tacomas (2005-2015)' started by claymore, Mar 31, 2013.
  1. Mar 31, 2013 at 5:30 PM
    claymore
    claymore [OP] Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
    I have a 2012 with Grillcraft insert and BAMF light bar. I have the light bar attachments on the side. I have been kicking around getting a URD TCAI and MAF calibrator. Has anybody else done this? Will it fit? Anybody got pics? I know I could keep the light bar in the middle, but not sure about the others.
    Here is my current set up.
  2. Mar 31, 2013 at 5:33 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I don't think you'll be able to squeeze anything else between that radiator and grill... I'd say the URD TCAI is out of the question unless you want to lose a few of those lights.
  3. Mar 31, 2013 at 5:39 PM
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    Why not relocate the single row LED to the lower slot in the bumper put the double stack as low as possible and see if you can put the rounds on the outboard side of the mount? That might give you enough room but no way to really know until you have it in hand
  4. Mar 31, 2013 at 5:47 PM
    armyoffoo
    armyoffoo Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    I asked J Lee if the URD TCAI would fit when he started up the last group buy, was told it would not fit.
  5. Mar 31, 2013 at 5:57 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I read your post about it. I thought about trying the 21s light bar above it, but the more pics I look at, I dont think I can fit the bar at all with the TCAI. How do you like it? I have been on the fence about it for a while.
  6. Mar 31, 2013 at 5:59 PM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    I have also considered this idea. I like the light in the lower slot. Like this:
    http://www.tacomaworld.com/forum/lighting/251334-light-bar-install-lower-grill-opening.html
  7. Apr 8, 2013 at 11:50 PM
    Beachrunner
    Beachrunner Member
    Kevin
    Nj
    2010 Grey Sr5 4x4
    Work in progress
    does your truck have the tranny cooler.. I'm in the middle of getting ready to hook up the same set up didn't see yours before I ordered.. I got 2 14.5" bars and I'm gonna through 2 5" spots with glow next to them. I'm just wondering about space
  8. Apr 9, 2013 at 3:30 AM
    claymore
    Clay
    ABQ New Mexico
    2012 Offroad
    Yes, I have a trans cooler. You have room for 2 14.5 light bars, but not the URD. I am in the same boat.
  9. Apr 10, 2013 at 11:46 PM
    Beachrunner
    Beachrunner Member
    Kevin
    Nj
    2010 Grey Sr5 4x4
    Work in progress
    Day 2 playing with the lights...Gotta paint the chrome and install the mesh grill..
  10. Apr 10, 2013 at 11:52 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No. No way can you do that without getting ride of most of the lights...and I mean almost all of them.
    Here is my dads
