Lift install driving me nuts
Old 04-15-2013, 07:18 PM   #1
97lt1ta [OP] 97lt1ta is offline
97lt1ta is on a distinguished road
97lt1ta's Avatar
97lt1ta's Tacoma Gallery
I'm installing a pro comp 3 inch lift in my tacoma I got the driver side coil over in which was a pain. But now I'm stuck on the passenger side. The bottom of the shock is crooked about a half inch and won't line up. I've taken the spring off 4 times now to line it up but same thing every time. Any ideas please and thanks in advance
Old 04-15-2013, 07:56 PM   #2
hakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shedhakabo is one of the sharper tools in the shed
hakabo's Tacoma Gallery
do you mean bent or twisted? mine was a little turned but i just put a screwdriver through the slot and turned it where i needed (I was using billies). similar i guess to turning the screws on a christmas tree stand for lack of a better example.
Old 04-15-2013, 07:56 PM   #3
Calmer than you are
jmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shedjmg256 is one of the sharper tools in the shed
jmg256's Avatar
jmg256's Tacoma Gallery
Stick a drift/socket extension/screwdriver/ect in the eye and twist it to where it lines up where ya need it. Do this with it top of the coilover mounted to truck to make it easier to get leverage and keep the entire assembly from twisting
Old 04-15-2013, 08:02 PM   #4
97lt1ta's Avatar
Ok just tried and broke my screw driver and bent my extension didn't budge lol I can try getting a longer pole and get more leverage I just don't want to break the top studs
Old 04-15-2013, 08:04 PM   #5
Whyareyoureadingthis?
VirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shedVirginiaBound is one of the sharper tools in the shed
VirginiaBound's Avatar
Name: Sam I am, green eggs and ham
VirginiaBound's Tacoma Gallery
Take a bottle jack and wedge it between the top of your wheel well and your upper control arm. This will push the arm down and take the pressure off your shock bottom.
When I first installed mine I fought for hours, then CMACK told me this trick and I got them in a few minutes later.
They'll bolt in with ease.
Old 04-15-2013, 08:08 PM   #7
97lt1ta's Avatar
Ill give that a shot thanks man
Also they are pro comp e6000 shocks
Old 04-15-2013, 08:09 PM   #8
Calmer than you are
jmg256's Avatar
This only makes vertical space to slip the now taller shock assembly in, does nothing if the eye is clocked wrong...
You can achieve the same effect by prying the lca down with big pry bar...neither will help the op.
Old 04-15-2013, 08:15 PM   #9
97lt1ta's Avatar
Here is a snap shot
Old 04-15-2013, 08:27 PM   #10
Calmer than you are
jmg256's Avatar
Weird...mine were off about that much when I did mine, rotated just fine. Helped another member do his, same story. I run 5100's, he has the Iron Man shocks...both of these use a "floating" spring seat, not sure if that might make a difference?
Old 04-15-2013, 08:38 PM   #11
97lt1ta's Avatar
What did you use to twist it ?
Old 04-15-2013, 08:46 PM   #12
Calmer than you are
jmg256's Avatar
1/2" ratchet extension...like 8" long...I say 8 because I can't remember if it was a 6 or 10.
Old 04-15-2013, 09:45 PM   #13
drinking whats on sale
92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed
92dlxman's Avatar
92dlxman's Tacoma Gallery
crap, without a floating (free to turn) spring seat, it will be difficult to turn that. short of removing the coil and trying again, I think it will take a lot of force.
Old 04-15-2013, 10:13 PM   #15
92dlxman's Avatar
Originally Posted by jmg256 View Post
^^^I think you're correct^^^
yes, I find that with re-iterating others' posts, and using vague words so as to lack accountability, I usually am.
my bad
DOOR CHIME DRIVING ME NUTS!! HELP ME BEFORE I SNAP Muskwa 2nd Gen. Tacomas 3 05-15-2012 01:59 AM
Tires choices/opinions are driving me nuts! Jholder70 Wheels & Tires 32 03-12-2012 10:15 PM
Help me stop driving my wife nuts... pcledrew 2nd Gen. Tacomas 9 08-01-2011 06:17 PM
ABS Light is Driving me nuts. Oh_Six_Taco_4x4 2nd Gen. Tacomas 11 12-09-2009 12:31 AM
OMG these sliders are driving me nuts! LonghornTaco 2nd Gen. Tacomas 15 12-14-2008 09:53 PM
