2006 tacoma rear axle leaking seal
Old 04-16-2013, 07:22 PM   #1
bradleyswine is on a distinguished road
Army: infantry, a armor, scout
bradleyswine's Tacoma Gallery
I was wondering if somebody knew what the part numbers were for the rear axle.
I have a double cab, 4x4, automatic, v6, positraction, 6 bolt hubs.
The drive shaft seal is leaking on the axle. Since there is a leak I may also change the axle seals and gaskets.
A nice schematic with part numbers would be great.
Old 04-16-2013, 08:42 PM   #2
white08gt is just really nicewhite08gt is just really nicewhite08gt is just really nicewhite08gt is just really nice
Air Force: recip engine mechanic
white08gt's Tacoma Gallery
are you talking about the pinion seal? after replacing my pinion seal the rearend went out soon after. keep an eye on it, to get the seal you had to buy a kit with a new bearing and crush sleeve. I ended up having to replace whole chunk from the junkyard. dealer wanted $1800. still cost be $400 with exchange plus gasket and rearend fluid. are you lifted, if you are and didn't use axle shims to keep driveshaft in alignment it could just be worn and a new seal will fix it. do not use impact wrench to remove nut.
Old 04-16-2013, 09:08 PM   #3
Go home if you don't like guns liquor and whores.
maxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shedmaxamillion2345 is one of the sharper tools in the shed
maxamillion2345's Avatar
maxamillion2345's Tacoma Gallery
What indeed. You can order the seal individually, you'd be hard pressed to remove that nut without an impact as well. Most people count the number of threads and return it back to that position. You'll probably want a new nut though.
Also, check for play in the pinion. Don't bother replacing the axle seals. Just the pinion seal.
Old 04-16-2013, 09:18 PM   #4
Oh and did you mess up the pinion bearings preload putting it back together? Could that be why it failed?
Old 04-19-2013, 06:32 AM   #5
Factory original axle seals and bearings. finally wore out.
Old 04-19-2013, 06:35 AM   #6
I am the original owner and the seals are original equipment.
Old 04-19-2013, 08:40 PM   #7
Jimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shed
Jimmyh's Avatar
Navy: MT1 (SS) retired
Jimmyh's Tacoma Gallery
I think he was commenting about the poster below.
Leaking rear axle - inner or outer seal?? kingston73 1st Gen. Tacomas 29 08-15-2012 08:37 PM
rear axle seal leaking "07 sport" dennisemile 2nd Gen. Tacomas 2 09-16-2011 07:50 PM
Rear axle seal leaking sweetwater 2nd Gen. Tacomas 0 06-25-2011 10:33 AM
leaking rear axle seal question chandlerpaing14 Technical Chat 1 05-26-2011 02:58 AM
Axle Seal Leaking T@co_Pr3runn3r 2nd Gen. Tacomas 13 04-05-2011 10:35 AM
