Wheel bearing and outer seal question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nelz1, Apr 17, 2013.
  1. Apr 17, 2013 at 8:17 AM
    Nelz1
    Nelz1 [OP] Well-Known Member
    Boston
    07 Tacoma DC TRD - 20 Tacoma DC off road
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    I went overboard on torquing the axle wheel nut after doing a front bearing and I am wondering if I can back it out and retorque it to the right value or is it set now?
    Is torquing the nut with the truck on the ground incorrect, does the wheel need to be free of weight?
    Is the bearing outer seal needed ? it looks like uneffective?
    Thanks so much:confused:
  2. Apr 17, 2013 at 8:43 AM
    Wearingthin
    Wearingthin New Member
    Pensacola
    01 XJ 4x4
    4.5" RE lift, IRO Tie Rod, RE HD trackbar and bracket, OME shocks, 305/70/16 MTR kevlars, AA SYE
    I'm not a toyota guy, and actually have unit bearings on my vehicle, but it's not uncommon when replacing spindle bearings to over torque the spindle nut, then back off, spin hub a bit, and over torque again, doing this a few times to seat the grease. Then finally torque to spec.
