Tacoma Camburg Uniball UCA Dust, Mud, Water Covers
Old 04-19-2013, 08:04 AM   #1
Milowilli [OP] Milowilli is offline
Milowilli
Milowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shedMilowilli is one of the sharper tools in the shed
Milowilli's Tacoma Gallery
Due to the design of the open Uniball on the UCAs on the market, they are prone to early failure when used in extreme conditions..4 to 6 months on trucks used in the South American rain forest..mud, dirt, sand and Water. The dry lube washes off very quickly and eventually causes the Uniball to squeak and rattle.
I have designed Covers that keep the elements out of the top of the Uniball and will be sending them to South America for evaluation.
Low profile Camburg bolts used as the Chaos and other models use a taller bolt which makes it hard to cover.
Test fit of Ring with cover before welding
Rings, Uniball and removable plastic snap in covers.
Machined dummy Uniball to act as heat sink to prevent housing distortion during welding.
Covers welded on and Arms to be painted...more pics to follow.
Old 04-19-2013, 08:06 AM   #2
Red
Large's Tacoma Gallery
Awww yeah Love ingenuity like this
Old 04-19-2013, 08:08 AM   #3
ColtsTRD's Avatar
ColtsTRD's Tacoma Gallery
Nice work!!
Old 04-19-2013, 08:09 AM   #4
mk7 mk7 is offline
mk7 is on a distinguished road
mk7's Tacoma Gallery
Nice.
Old 04-19-2013, 08:10 AM   #5
Long time lurker, first time poster.
Nirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shedNirvana is one of the sharper tools in the shed
Nirvana's Avatar
Coast Guard: Snipe
Nirvana's Tacoma Gallery
Awesome idea, looks sharp.
Old 04-19-2013, 08:14 AM   #6
Banned
SoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shedSoCaltaco65 is one of the sharper tools in the shed
SoCaltaco65's Tacoma Gallery
Although this is a great idea for the top acting like a pool, what do you do about the bottom of the Uni-ball that is actually exposed to more dirt and debris? On another note, not all Uni-balls make noise from dirt, debris, water and so on.
Old 04-19-2013, 08:24 AM   #7
Milowilli
From what I noticed the top of the Uniball is the problem because of what you said..pooling of mud, Water dirt. The Bottom is hard to cover and requires a complete redesign of the cup and a rubber boot like what the Austrailians did.A cover on the top in my opinion will extend the life of the Uniball for sure. I have seen failures on Chaos and Camburg Uniballs..who makes a tough failure proof one?
Monster Rides sealed Uniball UCA..$1400.00 USD delivered to USA from Australia.
Old 04-19-2013, 08:27 AM   #8
Banned
indeed, was aware of them, knew they were very pricey, I have been playing around with a boot for the bottom of the UCA uniball transition and was wondering if you were going down the same path.
Old 04-19-2013, 08:49 AM   #9
Milowilli
I looked at the Arm carefully and due to the design of the cup it's impossible to cover the lower. The cup will have to be redesigned. The guys will lube the bottom and remove the cap to put in penetrating dry lube and that should work better than having no cover. The top will always be clean and have penetrating Dry lube.. We have a sticky highly abrasive orange/ red clay that gets into everything and the trucks are in it for hundreds of miles at a time..for work not weekend warriors so the parts have to last. Here are some examples of our conditions.
This Mud is serious crap..eats uniballs for lunch!!!
Lol
Old 04-19-2013, 09:03 AM   #11
Banned
indeed, lots of iron in that mud, have spent some time in So. America, im working on a wrap around design that cover the holy assembly.
Old 04-19-2013, 01:47 PM   #12
Milowilli
Let me know what you come up with!!
Old 04-19-2013, 02:32 PM   #13
Blygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shedBlygy is one of the sharper tools in the shed
Blygy's Avatar
Blygy's Tacoma Gallery
These look like awesome ideas guys.. Just the reason i need to get Uni-balls instead of ball joints once I upgrade my suspension..
Old 04-19-2013, 03:44 PM   #14
PMK PMK is offline
PMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shedPMK is one of the sharper tools in the shed
PMK's Avatar
PMK's Tacoma Gallery
This may sound stupid or oversimplified, but, why not just use spherical bearings with grease ports and add a grease zerk to the arm.
You could probably offer them a squirt of grease by positioning the wheel spokes in a position to have easy access.
Waterproof marine grease should last a while, prevent corrosion, and purge out any contamination the does slip by the grease layer.
Just asking, I was toying with accomplishing the greaseable mod but have not bought upper arms yet. For my needs I plan to buy ball joint Camburgs for simplicity.
PK
Old 04-19-2013, 03:58 PM   #15
Banned
Easier, goes on wet and drys.
Old 04-20-2013, 07:49 AM   #16
Milowilli
PK
Nobody makes a Uniball with grease fittings
Old 04-20-2013, 07:50 AM   #17
Milowilli
Lube dosnt stay on in our conditions..after a few mud holes all lube is gone.
Old 08-12-2013, 11:21 AM   #18
Maibatsu Monstrosity
Jaime is a glorious beacon of lightJaime is a glorious beacon of lightJaime is a glorious beacon of lightJaime is a glorious beacon of lightJaime is a glorious beacon of lightJaime is a glorious beacon of light
Jaime's Tacoma Gallery
FYI Camburg now offers uni ball covers: http://www.tacomaworld.com/forum/dea...ml#post7284478
Edit: Ball joint only for now, Uni ball in the works
Old 08-12-2013, 11:50 AM   #19
Badger of Death
DoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shedDoorDing is one of the sharper tools in the shed
DoorDing's Avatar
DoorDing's Tacoma Gallery
PK
I know you're aware of this, but for anyone else, Miles has another thread with a ball joint solution that might do the trick.
Camburg 1" uca uniball Turbokanji 2nd Gen Tacoma Marketplace 10 03-15-2012 05:26 PM
FS: SAW 2.5 w/ Camburg 1" Uniball UCA brigham 2nd Gen Tacoma Marketplace 32 08-26-2011 04:37 PM
Camburg Uniball UCA, Fresno, $420 bolson 2nd Gen Tacoma Marketplace 1 07-30-2011 07:51 PM
Camburg Uniball UCA's just installed fishinsteeg234 Suspension 3 05-16-2010 05:29 PM
Problems with Camburg uniball UCA's? fishinsteeg234 Suspension 10 04-10-2010 09:34 PM
