2008 Taco Stuck In Park...
Old 04-22-2013, 05:45 PM   #1
mojoe [OP] mojoe is offline
mojoe is on a distinguished road
mojoe's Tacoma Gallery
Edit to ADD: I Goofed on the title... it's a 2006.
So I've had this issue before that was resolved by following a thread here earlier. It was in fact the STOP 10A fuse that blew. Fast forward to today and I have no clue what the deal is.
Solutions I've tried so far
Checked all the fuses, multiple times including:
10A IG1
7.5 A ACC
10A STOP
10A IG1 No.2
I've tried pressing the button next to the shifter with zero results.
I don't have an owner's manual, but will get one very soon, so I do not have anything else to go on besides reading problems people had in the past. At the moment I'm stuck at work trying to find a switch somewhere by the pedal....
Additional note. I do have an aftermarket tow package.
Old 04-22-2013, 05:50 PM   #2
Leoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shedLeoffensive is one of the sharper tools in the shed
Leoffensive's Avatar
Leoffensive's Tacoma Gallery
interesting.
so that one 10a fuse is ok?
weird that override button wont work
Old 04-22-2013, 05:51 PM   #3
call the toyota dealer and see if they can suggest something over the phone
Old 04-22-2013, 06:09 PM   #4
Jimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shedJimmyh is one of the sharper tools in the shed
Jimmyh's Avatar
Navy: MT1 (SS) retired
Jimmyh's Tacoma Gallery
If the button isn't working it seems that the shifter linkage is frozen or binding.
Old 04-22-2013, 06:15 PM   #5
Sounds expensive....
Originally Posted by Beavis0076 View Post
Brake lights working?
Yes all lights are operational.
Old 04-22-2013, 06:24 PM   #6
Hm... I was thinking brake light switch. Did u try rocking the truck back and forth a little.. Then try the button again? I think u have to put your key in the slot??
I have not tried rocking the truck yet. As far as the button pressing, I always have the key in the slot and the truck is turned on and running when I attempt the button push.
Edit: Tried the rocking....nothing :-(
I found this thread, but there was no solution posted :-(
http://www.tacomaworld.com/forum/2nd...r-shifter.html
Old 04-22-2013, 06:50 PM   #7
no, i meant the slot for the key near the button.. but I just ran out to my truck and the taco only has the button.. make sure you lifted the cap off the button.. other than that.. might be a tow job..
yeah the tab is lifted and the button is exposed.
Side Note... If I push really hard it goes into gear BUT there is a very loud thud.
Old 04-22-2013, 06:57 PM   #8
169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed169.254.255.201 is one of the sharper tools in the shed
169.254.255.201's Avatar
169.254.255.201's Tacoma Gallery
What were you doing in a park?? Pretty sure those are only for walkers. .
Had to.
Do you hear anything underneath when you try to shift? Well have someone else shift.
Old 04-22-2013, 08:25 PM   #9
Thank you guys so much for the input. I applied brute force to get the Tacoma in Drive and noticed a thud coming from the shifter area. I was able to drive the truck the whole way home without a problem.
So my line of thinking right now is that there is something blocking the shifter from making the transition from park. Evidence so far supports that; No blown fuses, No slippage in transmission and I hear a faint click in the shifter area when brake is applied - so that must mean something is disengaging.
So I followed the awesome tutorial here: Center Console Removal
Here is a pic from the shifter area. Note: The flash made it look disgusting...sorry. But it does look like some rubbing is occurring when the shifter is being engaged.
Any further suggestions would be greatly appreciated.
Old 04-22-2013, 08:30 PM   #10
t_e t_e is offline
t_e is a name known to allt_e is a name known to allt_e is a name known to allt_e is a name known to allt_e is a name known to allt_e is a name known to all
t_e's Tacoma Gallery
Run over anything? check the linkage to the tranny? When my 06 wouldnt shift out of park it was the brake switch but pressing the button got me out of park.
Old 04-22-2013, 10:40 PM   #11
Everything right now points to Shift Interlock Solenoid. I'm currently trying to find whats involved with it's replacement.
Old 04-23-2013, 12:06 PM   #12
maykevin5 is on a distinguished road
maykevin5's Avatar
maykevin5's Tacoma Gallery
sounds like the solenoid wasn't working and then you finished it off with a bang.
Old 04-23-2013, 03:53 PM   #13
So I've been calling around and shops want $300+ for the shift interlock solenoid part :-( The guy did say if the override doesn't work then there's another culprit. Of all the places I called everybody seemed surprised it was a "possible" solenoid because they never EVER had to replace one.
I have a brake light switch on order for pickup tomorrow...
Old 04-24-2013, 02:14 AM   #14
Jimmyh's Avatar
When you pressed the brake and heard the click, the click was the solenoid unlocking the shifter. IMO that takes the solenoid and the brake switch out of it.
Old 04-24-2013, 07:15 AM   #15
maykevin5's Avatar
get one out of a junk yard $10, i'm sure the 2nd gens are all the same.
Old 04-25-2013, 02:04 PM   #16
Woke up this morning and it was working fine. I'm gonna make a trip to the junkyard soon and get myself a different shifter unit.
My truck is stuck in ''park'' gasgu Technical Chat 10 02-05-2015 10:13 AM
Truck stuck in park sportzman0 2nd Gen. Tacomas 14 07-27-2013 10:11 PM
Does your 2008 Taco door lock when you leave Park? JWWPHOTO 2nd Gen. Tacomas 6 05-30-2009 01:19 PM
2008 V6 stuck in "Park" Newtacomaowner 2nd Gen. Tacomas 8 04-26-2009 10:34 AM
Stuck In Park,,, WTF? Tacomojo Technical Chat 7 07-08-2008 07:44 PM
