Oil Filter Poll!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMan1911, Apr 22, 2013.
Oil Filter Poll!!
  1. Fram Ultra
    6.7%
  2. Mobil 1
    10.2%
  3. Toyota OEM
    79.4%
  4. Bosch
    3.7%
  1. Apr 22, 2013 at 7:42 PM
    TacoMan1911
    TacoMan1911 [OP] Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    Which one should I use on my next oil change?
  2. Apr 22, 2013 at 7:43 PM
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
  3. Apr 22, 2013 at 7:44 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    Tsinajinii likes this.
  4. Apr 22, 2013 at 7:45 PM
    FATPUBUS
    FATPUBUS Well-Known Member
    Moulton, Texas
    13 Tx Edition
    K&N. used em for five years on the 4Runner!
  5. Apr 22, 2013 at 7:51 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
  6. Apr 22, 2013 at 8:12 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
  7. Apr 22, 2013 at 8:12 PM
    05Aztacoma
    05Aztacoma Well-Known Member
    05 Tacoma 4x4
  8. Apr 22, 2013 at 8:16 PM
    TacoMan1911
    LA
    Is it ok to use mobil 1 full synthetic with the oem filter? Or is it only designed for conventional oil?
  9. Apr 22, 2013 at 8:17 PM
    05Aztacoma
    05 Tacoma 4x4
    I use oem filter with Mobil 1. You can use any oil you like.
  10. Apr 22, 2013 at 8:22 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Go with a WIX/ NAPA gold. I use a wix 51515, it fits a bunch of vehicles, but ll of fords 351 V8. It about 2.5x bigger than the stock filter. Also pretty cheap at about $6 ea.
  11. Apr 22, 2013 at 8:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    You can use any oil you would like to use with the OEM filter.
    The filter doesn't care.
  12. Apr 22, 2013 at 9:44 PM
    S.B.
    Sean
    San Diego
    15 Taco
  13. Apr 22, 2013 at 9:45 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
  14. Apr 22, 2013 at 9:45 PM
    JB64
    JB64 Member
    Jim
    Kansas City area
    2010 V6 SR5 DCSB 4WD
    I use OEM.
  15. Apr 22, 2013 at 9:50 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    It's possible the Wix filter and the OEM filter might have similar filter media area, despite the Wix's larger size.
  16. Apr 22, 2013 at 9:55 PM
    GoPreds
    GoPreds Active Member
    K&N but you can't go wrong with the OEM
  17. Apr 22, 2013 at 10:08 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Chris only looked at the filters that are specified and recommended for our engines.
    The larger can may or may not fit within the shield of either the 4.0 or 2.7 on the 2nd Gen.
    Now, on this filter, I would suspect that the element is indeed larger. It's generally filters that are the same diameter, but taller can, that tend to use the same element.
    But there are issues beyond the O-ring diameter and thread. The bypass pressure rating is different on different filters.
    Larger isn't better if it kicks into bypass every morning when the initial surge hits it.
  18. Apr 23, 2013 at 3:13 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I use the wix/NAPA gold, 51348 and buy them by the case...they fit the taco, sil's 4runner, and wife's wrangler sahara. Now I just need five gallons of mobil one for the spring oil changes.
    Howard
  19. Apr 23, 2013 at 3:30 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    people can tear open filters and stare at them all they
    want on a bench, but what matters is filtering small metal bits
    from oil under pressure
    until someone posts up real world pressure and particle filtration
    tests instead of just cut them open, stare and them and spew commentary,
    I'll stick with OEM...as it is a guarantee toyota would have zero issues
    should engine damage occur due to particulates not filtered
  20. Apr 23, 2013 at 3:34 AM
    andjenliang
    andjenliang Well-Known Member
    Andew
    LBC/OC/LAX
    10 DCSB PreRunner V6 TRD Off Road
    Stock
    i buy oem when it is on sale for about 4 dollars or those ebay sales for a box of 10 w/ gaskets for 40 shipped. It maybe cheaper for the 4 cylinder engine
