3" Toytec lift and don't rub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MagneticTaco, May 4, 2013.
  1. May 4, 2013 at 5:32 PM
    MagneticTaco
    MagneticTaco [OP] Well-Known Member
    Kiel
    Louisiana
    2013 DCSB Magnetic
    3" toytech lift, front spacers, AAL in the rear, 285/75r16 goodyear duratrac, blacked out emblems and taillights, pained grill
    Hey all, just installed my 3" Toytec lift, spacers in the front and AAL in the rear. Put on 285/75r16 goodyear duratracs. The only thing I had to remove so no rubbing would happen is the little flaps in front of the front tires. Anyone else have this done?
  2. May 4, 2013 at 5:34 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Probably due to the backspacing of your wheels
    Have you flexed it yet ?
  3. May 4, 2013 at 5:41 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    I haven't really no. I am fine with removing them, was actually thinking of removing all of the flaps. Just plasti dipped the back bumper as well. Looks good with no chrome. Ill post a pic when I put it back on tomorrow after it cures
  4. May 5, 2013 at 10:37 AM
    SVLeonard85
    SVLeonard85 Member
    Steve
    Bellevue, WA
    13 Tacoma Dbl Cab Sport
    I did too. I put 285/75/17 on my stock trd sport wheels. I had to remove the front little flaps. I took my mudflaps off the front as well.
  5. May 5, 2013 at 10:40 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Does your tire rub the upper control arm at full turn?
  6. May 5, 2013 at 10:42 AM
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
    This
    im wanting to upgrade to 285/70/17s but im afraid ill have to get spacers or different wheels for it work
  7. May 5, 2013 at 2:50 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    It does not touch the UCA at full turn. It's really close though like 1/4 of an inch away. This is from what I can see the widest tire you can get without getting wheel spacers. Truck rides a little stiffer but is well worth it for the way it looks. Duratracs are pretty quiet as well. A little hum to them but not noticeable unless you listen for it.
  8. May 5, 2013 at 2:54 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    try full turn in reverse. My 255/75/17 on stock wheels will rub the uca doing that.
  9. May 5, 2013 at 2:56 PM
    bzzr2
    bzzr2 Well-Known Member
    wait til you get off road and compress the suspension all the way up, you might hear some funny noises...!
  10. May 5, 2013 at 2:58 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    I'll try that. I have done full turns both ways back and forward and don't seem to rub. How wide are your wheels. Mine are 16x8.
  11. May 5, 2013 at 2:59 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Hope that wouldn't damage anything bumping the UCA
  12. May 5, 2013 at 3:02 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I don't know how wide they're. They're the stock trd sport wheels.
  13. May 5, 2013 at 3:58 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Since the UCA is attached and moves with the wheel I don't think it would rub unless I get crazy compression on the front end like if I jumped it or something.
  14. May 5, 2013 at 4:08 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Assuming OP is running the TRD FJ wheels in his avatar pic, those have about 5" b.s. I believe, as opposed to the 5.5" b.s. of stock Tacoma wheels. This should be just enough b.s. to keep the tire off of the UCA. Someone correct me if I am wrong.
  15. May 5, 2013 at 4:14 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Huh?
    The UCA is attached closer to the top of the shock tower (don't know what the location is called) and the spindal. It only moves up and down. The most realized movement comes from the distal portion. It doesn't move when you turn the wheel.
  16. May 5, 2013 at 4:16 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    You are correct. I have the TRD FJ wheels and have about 1/4 inch of clearance from my uca. Just enough backspace to make it work
  17. May 5, 2013 at 4:16 PM
    OZ-T
    Peter North
    British Columbia
    wut
  18. May 8, 2013 at 1:29 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    trying out this signature thing
  19. May 8, 2013 at 1:49 PM
    whitetacoma89
    whitetacoma89 Well-Known Member
    Anaheim
    11 Prerunner
    nice truck. love the simple 3'' lift. Ive been reading around the site a lot and was planning to jump on this toytec kit. Was this similar to what you got? Thanks
  20. May 8, 2013 at 4:35 PM
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    That is exactly what I got except for the shocks. My truck came with the 5100's so I just got the front spacers and the AAL for the rear. Was 300 shipped so that price you have there is a good deal. 3" is the perfect lift amount
