2006 Prerunner access cab AT has Quirks Help
Old 05-20-2013, 09:56 AM   #1
newbieinct [OP] newbieinct is offline
newbieinct is on a distinguished road
newbieinct's Tacoma Gallery
I recently purchased our first Taco. Love it. I mean really love it. Bought from dealer and purchased Tacoma extended warranty (based on my horrible luck in general)
heres the scoop, 2006 Prerunner, 6cyl, AT 80k . Shifts hard when cold especially if you let off on the gas but seems to smooth out mostly but not completely.
different issue ...... this thing has what I call slingshot effect.While sitting at redlight or stopsign w/ foot on brake it will sometimes "jump". First couple of times I actuallty thought I got tapped by another vehicle from behind. It will also do this as you start to accelerate once it spun the rear wheels on wet pavement. Is this a computer thing because of drive by wire?
I am not bashing here. We love this vehicle and probaly see us eventually having 2 tacos (obviously keeping this one) . I also know all vehicles have quirks and identical parts that possibly fail. I just want an idea before I go to the dealership and start blind. Thanks in advance.
Old 05-20-2013, 10:01 AM   #2
resident Apple Pie Monster
Justus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shed
Justus's Avatar
Justus's Tacoma Gallery
u have axle wrap, and or ur a/c is cycling it sounds like and causes the lung forward. Its common with leaf springs (the axle wrap).
as far as hard shifts...............do u know if the trans has been flushed or drained/filled?
I will never take any techs/service writers word about "they dont need servicing/flushing for the entire life of the truck"
u can also try an disconnect the negative battery terminal for 15 minutes.....the transmission is "supposed" to be adaptive and "learn" driving habits.
its a pita sometimes.
EDIT.............. u say it shifts when u let OFF the gas, sorry I misread that.
these trucks have automatic engine braking that causes the trans to actually shift down a gear instead of cruise when u let off the gas.... Its a learning curve, and I had to get used to it....I was used to an automatic coasting when u let off the gas, or if ur getting up to speed, and its in 3rd or 4th and u let off the gas a little most cars UPSHIFT yes?
Old 05-20-2013, 11:49 AM   #3
Good stuff this is exactly what i am looking for. Real world experience.
Axle wrap ?. The lunge sometimes happens after vehicle is standing still sometimes minutes standing still like at a red light. This is not leftover "energy" ????? I am kinda thinking the computer is saying "go" and my foot is on the brake.
I think you are right about the downshifting that i need to get used to .
No idea if tranny has ever been flushed. some vehicles are best left alone I take it it should be flushed ?
Old 05-20-2013, 03:09 PM   #4
iroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shediroh is one of the sharper tools in the shed
iroh's Avatar
iroh's Tacoma Gallery
Actually, it's more like the slip joint in the rear driveshaft sticking a little bit. When you stop, the force of the brakes tends to rotate the third downwards, and after you stop and let up on the brake pedal a bit the slip joint will 'unstick' and you feel a jump. I've never had it happen on my manual tranny tacomas so it might be compounded by the auto tranny trying to idle the truck forward at a stop, putting additional tension into the slip joint.
Just as a matter of course I'd check if the axle's u-bolts are properly torqued. If they're loose then the axle will wrap more.
Some people take apart the driveshaft and grease the slip joint, which takes care of the problem for a little while, but it always seems to come back fairly soon.
As for the first part, the hard shifts mean the friction modifiers in the tranny fluid are pretty well used up. Toyota used to say lifetime fill but they've since gotten wiser and recommend a flush every 60k iirc.
Old 05-21-2013, 11:27 AM   #5
Justin Calhoun is just really niceJustin Calhoun is just really niceJustin Calhoun is just really niceJustin Calhoun is just really nice
Justin Calhoun's Tacoma Gallery
I had the same thing with my Tacoma. Have your fluid level checked in your tranny. It turned out mine was 2 quarts low and that's what was causing the "slingshot" you're talking about.
Old 05-21-2013, 09:19 PM   #6
sketchykillroy is on a distinguished road
Air Force: Low Observable Acft Maint.
sketchykillroy's Tacoma Gallery
I also just got an 06 and I had no idea about the automatic engine braking. This explains a lot! I thought I had some brake caliper issues or something! Will definately take some getting used too.
Differences between 2006 Prerunner access cab, and 2009+ Prerunner access cab KaosTsoc 2nd Gen. Tacomas 3 05-09-2012 09:55 AM
2006 Prerunner Access Cab TRD SoCal samsterman99 2nd Gen Tacoma Marketplace 4 04-15-2012 11:20 PM
F/S 2006 Tacoma PreRunner SR5 Access Cab TXRoper 2nd Gen Tacoma Marketplace 0 07-05-2011 08:22 PM
2006 Tacoma Prerunner Base Access Cab Anthony Buy / Sell / Trade 6 04-01-2011 05:30 PM
F/S 2006 Black Tacoma PreRunner TRD-Offroad access cab $11,000 mikecain Buy / Sell / Trade 2 03-13-2009 10:08 PM
