"Official" Firestone RideRite + Lift Thread
Old 05-30-2013, 09:30 PM   #21
Imageoguy is on a distinguished road
Imageoguy's Tacoma Gallery
I just came back from a mineral exploration job on forestry roads. Logged about 1000 miles with my DCLB with dakars and airbag carrying my ATV and about 400 lbs of rocks and gear on dirt roads (probably overloaded by 300 lbs). I did weld my own airbag spacer (see pick, a pair of 1 1/4 inch square tubing just below bag) to compensate for the height of the Dakars. I added 45 PSI, the ride was stiff but good when hitting washboard and ruts at 50-60 mph. Not too bouncy in washed-out trails either and flex seemed good. Small changes in PSI makes a big difference in how the Taco handles the load, it takes a few tries to get it perfect.
As a side note, my truck deck has now handled over 2000 miles of rough dirt roads with an ATV or snowmobile on top. It's great not having to worry about a trailer in the back, especially when entering really tight roads.
Old 05-31-2013, 09:51 AM   #22
j0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shedj0sh is one of the sharper tools in the shed
j0sh's Avatar
j0sh's Tacoma Gallery
Originally Posted by littleblue81 View Post
Alright, I ordered a set of the Daystar cradles and will try to install on Sat. They are vented so water, ice, mud shouldn't be an issue. Rocks are a different story but the likelihood of one landing in there seems pretty slim.
I'll report back afterwards. The Amazon reviews are promising as are the photo shown there.
I ordered a set as well. I really like the idea and after seeing my bags when my truck was on the lift for new tires, I would really like to have something different.
Old 05-31-2013, 12:40 PM   #23
Utard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shedUtard is one of the sharper tools in the shed
Utard's Avatar
Utard's Tacoma Gallery
The more I think about it I am really liking the looks of that thing.
For both of you that bought them please report back on the fit and how you like them.
I really like the bags for towing and whatnot. But always worry about ripping them offroad.
Old 06-01-2013, 10:27 PM   #24
littleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shedlittleblue81 is one of the sharper tools in the shed
littleblue81's Tacoma Gallery
Got the Daystar Airbag Cradles installed today. So far they are AWESOME. Removed the spacers completely, the cradles do rise up a bit.
They only slight problem so far is that the cradle is not 100% centered so the bags are just touching the lip of the cradle. The material of the cradle is very smooth but I'm still worried about wear. I might try adding a strip of inner tube or figure another way to move the cradle a bit, not sure how I will do that though as the bottom of the cradle is vented (not ideal for drilling).
At rest, no load, 5psi.
Testing droop - 5psi
Loaded boat - 0 psi
Loaded boat 25 psi
Loaded boat - 25 psi
Before
After
Old 06-01-2013, 10:31 PM   #25
I should also add that the rear suspension is MUCH smoother now that it's not bottoming itself out.
Old 06-01-2013, 10:52 PM   #26
Utard's Avatar
Nice looks great.
What do you mean not bottoming out? Do you not keep the minimum 5 psi in them?
Maybe the bracket that it is bolted to make the hole oval so you can get some side to side movement to center it under the bag?
So I can't even remember how the bag mounted on the bottom. Was there a stud on the bottom of the bag you had to cut?
Old 06-01-2013, 11:00 PM   #27
Originally Posted by Utard View Post
Nice looks great.
It bottomed out with the 2" spacer that was on previously. The spacer was too much and it didn't allow the suspension to compress.
I don't think I can. The hole is countersunk to make the bolt that holds it in flush.
Bolt goes to the bottom of the bag, in the center. You can see the mounting hole in the picture of the bag suspended.
Old 06-02-2013, 10:08 AM   #28
Utard's Avatar
URL=http://s7.photobucket.com/user/Triton_38/media/2013%20Tacoma/IMG_1282_zps36148229.jpg.html]
Thats right the hole in the bottom of the bag does not go through into the bag.
No I was talking about the bottom original metal bracket that is on the axle/spring. Make that hole bigger (not anything on the new puck) or oval so you can move the puck around a little. Then use one of those washers that are huge in diameter but with a regular hole in the middle.
I guess I still don't understand the bottoming out? If you keep the minimum 5 psi that they recommend in them it would be impossible to bottom it out unless the bags pop. And its bad to run 0 psi just for that reason. It will damage the bag itself.
I think as soon as I get new shocks/springs for the front I will be getting some of these.
Old 06-02-2013, 10:30 AM   #29
Ahh, I see what you mean. That might actually work, I'll have to take a look.
Re: bottoming out. If you look at the original pic with the spacer and the truck at rest, look at the bag. It's already compressed and there is not much room for it to compress any more when the wheel travels up. That is what I mean by "bottoming out", there is just not any more room for the suspension to give.
I could have removed the spacer and that would have eliminated that problem but then the bag would have been stretched more than it should have with the truck at rest because of the lift and I would have then lost 2 inches of droop.
Because the bag is designed for stock suspension travel range, and even then some say it limits some articulation, it's not possible to get 100% travel when you increase your travel in any way, in my case travel increasing by 1.5 inches.
Hope that makes sense.
Old 06-02-2013, 02:46 PM   #30
Shaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shedShaggs is one of the sharper tools in the shed
Shaggs's Avatar
Shaggs's Tacoma Gallery
I'm thinking the Daystar with Firestone would be a nice combo for my rig, especially tugging the Centurion
Old 06-05-2013, 09:32 PM   #31
skygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shedskygear is one of the sharper tools in the shed
skygear's Avatar
skygear's Tacoma Gallery
Just a thought here though, there ARE larger or taller versions of our bags. So you could build your own kit for the most part. Or once you get the appropriate height measured, email or call firestone and ask them for the proper mounting hardware for our trucks, then just a larger bag tossed instead of the smaller one.
What was the cost of the Daystar cup?
Old 06-05-2013, 09:44 PM   #32
skygear's Avatar
I wanted to keep the kit I had, but after the EXPO's installed, there was no hope for them in my application. Went from stock to ~4" - now I have my full Icon shocks and coil overs.
My back end is still a little negative rake due to the weight in the bed. I wanted to add the bags to the equasion for towing too. Then sold them after I got frustrated with the idea of spacers.
Next thing I want is the Hydro Bumps - So if I get them, it's going to kill the airbag idea for sure since the mounts and position where BOTH solutions is the same and the stock mounts need to be chopped.
Maybe I could look at a full custom solution for the towing too. have a weld on mount slightly over a few inches and even a larger bag. Then a plate or similar under the bed as the mounting point. You know, similar to the way a dump truck has it's bags mounted in the rear.
Still use the cups too.
Old 06-06-2013, 01:12 AM   #33
Well, I emailed them and they never mentioned using a larger bag. In any case, why have them attached when they can be free floating?
Edit: The cradles are around $80.
Old 06-06-2013, 01:19 AM   #34
skygear's Avatar
Most of the time people DO NOT mention other alternatives. But they DO make the larger bags. Tundra has one version of them already.
Old 06-06-2013, 07:41 AM   #35
Utard's Avatar
Its a clearance thing. I don't see bigger bags working.
Old 06-06-2013, 08:42 AM   #36
Yeah, unless they just didn't think of it, you would think they would prefer me to buy something from them as opposed to recommending something from another company.
Old 06-07-2013, 01:06 AM   #37
skygear's Avatar
Let me clarify, by Larger, I meant LONGER
Also, on the company aspect. You cant buy direct from most companys. Thats why there are retailers. From a liability standpoint, they probably CANT recommend anything else for legal reasons.
Old 06-07-2013, 08:15 AM   #38
j0sh's Avatar
going to try to get my cradles put on this weekend. Work has been crazy with all the storms we have had here...
Old 06-07-2013, 12:05 PM   #39
Nice. Should be very simple.
I'm probably going to be working on mine, either elongating the mounting hole or drilling a new one if there is enough space.
You might want to line everything up and see the bag is centered in the cradle before tightening everything up. I'm guessing it will be off center a touch like mine are.
Old 06-20-2013, 08:41 PM   #40
indashipad is on a distinguished road
indashipad's Tacoma Gallery
I like the pics on this thread. I tackled this problem like many others, free-floating the bag. I didn't want the bags to effect the ride or travel. I, more or less, want them out of the way when I'm not carrying a load. I placed a valve in the air line, removed the valve core temporarily, and evacuated the air from the bags.
The Official " HEY AMERICA , STOP BITCHING ABOUT YOUR LOW GAS PRICES " thread OZ-T Canada 701 10-02-2014 02:37 PM
the official: "ugliest sh*t ive ever seen on a taco" thread Marioso Off-Topic Discussion 342 06-13-2013 01:05 PM
Firestone RideRite problem...... Mr.Gadget 2nd Gen. Tacomas 5 12-10-2012 09:46 PM
The Official 49ers VS. Schmucks from NY aka "Pansy Giants" Trash Talk Thread 98tacoma27 Sports, Hobbies & Interests 168 01-23-2012 11:26 AM
283's Official "Guess the Song and Win Random Crap from My House" Thread 283 Entertainment 114 05-13-2010 07:51 AM
