"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Jun 21, 2013 at 5:45 AM
    #41
    indashipad
    indashipad Member
    Cody
    md
    '09 Tacoma
    indashipad
    I haven't had problem without the cups.
  2. Jun 21, 2013 at 10:25 AM
    #42
    jrubicon
    jrubicon Well-Known Member
    Jason
    Newark, CA, Earth
    2023 SR5
    full_f4b2509253e8210fb434da383ba02fc8c8b1d99c.jpg[​IMG]
    so im debating if i really need the air bags. This is my truck, fully loaded with extra fuel tanks. its low but not sagging that much.
    Do you recommend air bags? is it not sagging as much since its still new?
  3. Jun 21, 2013 at 10:37 AM
    #43
    littleblue81
    littleblue81 [OP] Well-Known Member
    It's definitely sagging. But only you can make the call. If it drives fine and the amount of sagging isn't bothering you than you probably don't need them.
  4. Jun 22, 2013 at 8:28 AM
    #44
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    You would be surprised how much more stable they make the truck.
    If it ever drives boaty then maybe they could be good for you.
  5. Jun 25, 2013 at 1:40 PM
    #45
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    I'm getting close to pulling the trigger on the Ride-Rites, probably from here...
    http://toyteclifts.3dcartstores.com/Tacoma-05-Rear-Air-Bags_p_302.html
    unless someone has a better source to buy from.
    I've struggled choosing, still struggling, between Dakars vs. Ride-Rites. I have an OME 3" lift, more like 2.5", 885's and an aal, but sag big time when I pull my boat and/or load any significant amount of weight in the bed.
    With the Dakars I worry that I'll still sag a little, more-so worried about being in this same position a few years down the road, especially if we upgrade to a bigger boat. Is this concern legit?
    Anyways, if I pull the trigger on the Ride-Rites should I add the spacer option listed on Toytec?
  6. Jun 25, 2013 at 2:01 PM
    #46
    littleblue81
    I would get the airbags. You can set the psi for whatever load you want and never worry about sag in any state, loaded or unloaded.
    I would not recommend the spacers. I really like the cradles. Just had the truck out this past weekend fooling around in the dirt and did some mild off roading, they are great.
  7. Jun 25, 2013 at 2:26 PM
    #47
    phatso
    Eastern Washington
    2017 Cement Pro
    Edit: Nevermind I just re-read your post from page 2 and looked at the pics more closely.
    Did you ever get the cradle to line up properly?
  8. Jun 25, 2013 at 2:34 PM
    #48
    littleblue81
    Just when flexing. But doesn't take that much flex to float off the cradle.
  9. Jun 25, 2013 at 2:34 PM
    #49
    littleblue81
    Not perfectly but good enough. I ran out of time to really line it up on the day I was working on it, but I think it's fine the way it is now.
  10. Jun 25, 2013 at 2:39 PM
    #50
    Tao Zero
    Tao Zero Well-Known Member
    Thanks OP for all the usefull information! I need bags to level my truck out when towing TT. I thought I would be unable to run the bags with a new leaf pack and
    figured I would have to deal with the sag until I lifted truck (still not sure it would sag or not). But with the bags I will be able to level any load. I love the idea of the cradles too, being able to float the bags!
  11. Jun 25, 2013 at 2:44 PM
    #51
    littleblue81
    No problem! I know how you feel, I was scratching my head for the longest time trying to figure out the best solution for lift + good ride + towing/eliminating sag.
    Update us with how you like it when you're done. Haven't found much of anything on the cradles being used with Taco's.
  12. Jun 25, 2013 at 2:45 PM
    #52
    phatso
    Eastern Washington
    2017 Cement Pro
    Yes, thanks OP.
    I worry about slush and ice build up in the winter. Anyone here use the cradles and can speak about how they do in winter conditions?
    I'm imagining water/slush building up around the cradle and bags, then freezing, then possibly tearing/puncturing the bags when I drive around.
  13. Jul 2, 2013 at 12:08 PM
    #53
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    I ordered up the RideRites and Daystars and it was 360 something altogether. They gave me almost 40% off. Cradles were 60 instead of 100, and RideRites was 270ish instead of 400+
    Can't wait to get them. My truck will be much happier.
  14. Jul 2, 2013 at 1:03 PM
    #54
    Tao Zero
    I am ready to pull the trigger too. Where did you purchase from? That's a good price.
  15. Jul 2, 2013 at 1:56 PM
    #55
    Shaggs
    NorCal
    AutoAnything.com
  16. Jul 13, 2013 at 9:38 PM
    #56
    Tao Zero
    Installed the Ride Rites today. Everything went smooth, except I forgot to put on the heat shield. Don't think they are completely necessary, there is a good distance between the exhaust and the bag. I do recommend to remove your spare when installing, lots of room. I was able to actually sit under the truck. Towing trailer next week, should help a bit. Now I'm set up good for towing. Air bags, brake controller and ScanGauge to monitor tranny temp.
  17. Jul 13, 2013 at 10:23 PM
    #57
    Shaggs
    NorCal
    These are going on this week... got everything, but gotta hit up the lake tomorrow or it would be going in
  18. Jul 14, 2013 at 6:36 PM
    #58
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
  19. Jul 22, 2013 at 6:29 AM
    #59
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    Have you noticed any additional noise coming from the rear suspension after installing the Daystar Cradles? Seems like each bump would result in the bag coming out of the cradle then reseating with a bang when the metal bottom of the bag hit the Daystar cradle. They are made from polyurethane, but are they soft?
  20. Jul 22, 2013 at 2:47 PM
    #60
    littleblue81
    They are not soft and I have not noticed any other noises.
