05 ATF change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hadoken, Feb 23, 2009.
  1. Feb 23, 2009 at 6:58 AM
    Hadoken
    Hadoken [OP] Active Member
    My 05 Prerunner is coming up on 60k miles and I am going to change the transmission fluid. I know the standard length is 100k miles, but I do not know if the previous owner towed with it so I would feel better changing it now.
    I have the pages from the service manual that show the process of draining and adding the transmission fluid, but I was wondering about the filter.
    Does Toyota just drain the fluid and add it back in, or do they drop the pan, replace the filter and gasket and do a total change?
    Has anyone had it done at the dealership, and how much did they charge for the service?
  2. Feb 23, 2009 at 7:23 AM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Funny I am in the same situation. I just called my dealer on Friday to ask them the same thing. I have an 05 Prerunner as well. First off they quoted me (in MI) $130 to flush the system and $65 to drop the pan and replace the filter. The service guy told me (and I am sure others can confirm this) that when you drop the pan you don't get all the fluid out you just get what is in the pan. When you flush the system they get all the old fluid out and new fluid in. I haven't decided what I am going to do yet, maybe this thread will help me decide.
  3. Feb 23, 2009 at 10:02 AM
    sonjay
    sonjay Well-Known Member
    A flush would be the best, as it will change all the fluid. I think I read on this site somewhere that Toyota just cleans the filter and re-installs, I'm sure someone will know a more definitive answer though?
    I like the football pic harshest! I could never understand why they called it football here, you hardly every touch the ball with your feet??? Wouldn't handball make more sence? haha
  4. Feb 24, 2009 at 9:24 AM
    Hadoken
  5. Feb 25, 2009 at 9:27 AM
    sliverworm
    sliverworm Well-Known Member
    Austin, Texas
    06 PreRunner TRD Offroad
    I am looking to do the fluid change also, anybody know where there is a How-to? I have access to the service manuals online but they are pretty confusing to navigate..
  6. Feb 25, 2009 at 10:26 AM
    sonjay
    The best would be to take it to a transmission shop to have a proper flush. Otherwise I guess you could pull the drain plug and pull the pan off... There will be no way to change all the fluid though.
  7. Feb 25, 2009 at 12:45 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Are you guys talking about the "sealed" tranny that uses the new WS fluid?
    If so, there is a write-up over on BITOG about changing it.
    Also, Redline is now making a syn fluid that is compatible.
  8. Feb 25, 2009 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Do you have a link????
  9. Feb 25, 2009 at 3:34 PM
    hate2work
    Washington State
    06 standard cab
