Wire in Back up lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Gadget, Jun 6, 2013.
  1. Jun 6, 2013 at 12:10 PM
    Mr.Gadget
    Mr.Gadget [OP] Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Been looking to add some LED back up lights like I used on my ATV.
    Is there a wire in the Trailer tow package to get to or just plug in?
    My old truck had a back up light power going to the trailer plug, I was able to add back up lights to my trailer and some around the hitch.
    Or will I need to pull the rear light and find it there.
    The LED lights I'm using don't take much to run them and I feel sure it will not be a problem.
    Just wonder the best place to find the wire or hook it up. May add a few inside the bed, hooked to tail lights, they are just 3 leds and in the tape strip about 1/2" wide, 1/8" tall and 3-4" long.
    Hard to tell from the pic, but this is what they look like on my ATV.
    White on the bottom of the bucket rack and green on the bar.
    I can run them a few hrs if needed and it does nothing to the atv battery.
    I already tried one white in the bed hooked to an ATV battery and it is enough, but would use two, one each side.
  2. Jun 6, 2013 at 12:14 PM
    medic2230
    Murph
    Bama! Roll Tide
    You could use a wiring harness from a fog light kit to wire them and be able to turn them on and off that way. Just an idea.
  3. Jun 6, 2013 at 12:16 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    CBI bed rack and sliders, Backwoods Adventure Mods front and rear bumpers, etc. And some stickers.
    Mmmm, meat!
    I don't think the stock trailer plugs on Tacomas have a reverse light, the standard 7-pin does not include that. It does have a fog light wire and plate light, but nothing that would turn on for reverse.
    I don't have my manual here at work, but the standard Haynes manual has diagrams and would tell you which color wire is for the reverse lights.
  4. Jun 6, 2013 at 12:29 PM
    Mr.Gadget
    NC
    My old truck had them on the same plug, I just have not been around my big trailer to plug it up and see if it works....
  5. Jun 6, 2013 at 12:33 PM
    TenBeers
    Rich
    Bentonville, AR
    Yeah, not sure why a trailer would need fog lights, so maybe they wired reverse into that pin. That would probably be a better use for it anyway.
  6. Jun 6, 2013 at 12:50 PM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    I did just what you are talking about.
    I have a 2008, with factory tow package with round 7-pin connector.
    I found the correct wire (I think grey), and connected in an LED added backup light.
    Works fine.
    Good luck.
  7. Jun 6, 2013 at 12:53 PM
    Mr.Gadget
    NC
    The other thinb that was cool on my Dodge it had a hot wire, it was big and had a breaker for it.
    Was used to charge and get power to the Brake battery on the trailer or run spot lights on the trailer.
    I also at that time riged a spot light to a trailer plug and could plug it up and use for loading, or anything. Also had a small inverter wired to it, just plug up and run it.
    Need to see if we have a hot wire like it did.
    That would be good for load lights on the ATV trailer.
  8. Jun 6, 2013 at 12:54 PM
    Mr.Gadget
    NC
    Do you know if it has a hot that is on all the time?
  9. Jun 7, 2013 at 6:21 AM
    skippermike
    San Diego
    As I recall, there is a hot lead intended for trailer battery charging. I recall there is one wire larger than the others - probably it.
    Do a search for trailer harness wiring diagram to check.
  10. Jun 7, 2013 at 6:56 AM
    Mr.Gadget
    NC
    OK, found this, it has the diagram I had on the old truck.
    They are the same plugs as I towed the trailer with both and all have the same pins.
    Now to see if the Battery (red) and center (purple) are hooked up.
    Also I'm not talking about a big battery for a winch or high power, but I know people use it that way. You just want to unplug it as if the battery gets lower it can try to draw from the truck and blow the fuse.
    What I'm talking about is the 12v, ATV looking battery(little smaller) that is used for the brake away box. That was how I had the big trailer, could run small lights off it and they worked with out the truck hooked up, but hooked up they could run and charge from the truck battery.....
    http://www.hopkinstowingsolutions.com/doc/trailer_wiring_codes.pdf
  11. Jun 7, 2013 at 8:02 AM
    ExtremeCustoms505
    ExtremeCustoms505 Well-Known Member
    Albuquerque WS
    2010 Tacoma 4d 4x4
    3" Revtek spacer kit in front w/ aal and 1" block in rear. No TSB aal installed yet. Spider Trax spacers.
    If you have the 7pin rv plug at the back of your truck there is a reverse wire tab hooked up, and there is also a hot 12v tab thats hot when the key is on.
    Hope this helps, grab a test light and you should have no problems.
  12. Jun 7, 2013 at 12:20 PM
    Mr.Gadget
    NC
    s
    Cool, I was going to run the test light but we have been getting killed with rain... 3" yesterday some the days before and 3-5" today. I can not see the truck in the drive now it is raining so hard......
  13. Jun 7, 2013 at 12:38 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Have a look at the cover for your 7 pin socket strangely enough it says "back up lamp" it will be the center pin and should be connected to a yellow wire.
  14. Jun 7, 2013 at 1:04 PM
    Mr.Gadget
    NC
    correct but I have had other trucks with the same plug, some they use all, others they do not.
    Friend tried one of the plug in back up lights and it did not work on his with the tow package.
    And the dealer said they did not wire for that.
    Just never got around to checking with a volt meter, and it has been raining a bunch.
    So it sounded like some makers use them and others not...
    I will find out soon as I plan to play with it this weekend.
  15. Jun 7, 2013 at 3:31 PM
    Infra
    Infra Well-Known Member
    Jason
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    There is a wire in the stock towing harness that becomes hot for backup lights when tranny is put into reverse. That's how I wired my blitzpro 6lz LED lights in as back up lights
  16. Jun 8, 2013 at 4:39 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well I can tell you for sure a 2011 does and I guessing all the factory setups do.
  17. Jun 8, 2013 at 5:13 AM
    peiscooter
    peiscooter Well-Known Member
    Prince Edward Island
    2021 TRD Sport
    The center pin will get power only if you turn the headlights on. I had an issue with my boat trailer, with surge brakes. Normally in most vehicles when you engage reverse there is power through the reverse lights pin which engages the brake lockout solenoid. Not so on my Tacoma. It only works with the headlights on. Strange, but true.
  18. Jun 8, 2013 at 7:31 AM
    ExtremeCustoms505
    Albuquerque WS
    2010 Tacoma 4d 4x4
    Ok, as for the center pin, it is your reverse power, it will only be activated when transmission is placed into reverse gear, it is normally used for either back up lites on a trailer, or also to dis-engage surge brakes on trailers while backing up. All tacomas with factory tow package will have this on the center pin. Anyone who's plug isn't working this way needs to check the wiring. This is standard wiring on all trucks.
    Google 7way rv plug and it will give you the pin designation for the plug, and tell you which function is on each pin.
  19. Mar 28, 2014 at 9:27 PM
    The403Guy
    The403Guy Well-Known Member
    Calgary, AB
    14 DCLB TRD SPORT
