Help needed with rim offset and backspace
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bgb9, Jun 11, 2013.
  1. Jun 11, 2013 at 6:00 PM
    bgb9
    bgb9 [OP] Member
    Brandon
    Brooksville, FL
    11 PreRunner SR5
    Grillcraft grill, smittybuilt step bars, pioneer 2400bt headunit, Roll&Lock bed cover and weathertech floor mats.
    I have been looking at all the forums on tacoma world for offset and backspacing on rims. I wanted to make sure I'm getting the right rims. I'm getting the fuel throttle 17x9 rim. I wanted to fit Hankook dyna pro atm 265/70/r17 on them. I have a 2011 Tacoma Sr5 prerunner. I would like to have the wheels stick out about 1/2" to an 1" out of the fender to give it more of an aggressive stance. Would I be better off going 265/65/r17 to avoid any rubbing. Thank you for your help.
  2. Jun 11, 2013 at 6:45 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    what are the specs on the new wheel?
  3. Jun 11, 2013 at 6:59 PM
    SpruceTaco
    SpruceTaco トヨタ
    Clearwater, FL
    2012 Spruce Mica TRD Sport
    Tinted windows 5%, sill protectors, TRD stubby antenna, weathertech in channel rain guards, wheathertech floor mats, BHLM, Truxedo low pro qt, DTRL deleted, anytime backup camera, bed storage locks, fog lights on anytime, tailgate theft deterrent, painted engine cover, relocated horns, l.e.d bed lights, l.e.d engine bay lights, l.e.d lights above cup holders, in glove box, rear cup holder, in console storage & cubby next to steering wheel, Grillcraft grill, 17x8.5 SCS Ray10's, 35x12.50 Nitto Ridge Grapplers, Borla cat back exhaust, map & dome l.e.d's, TEQ badge on grill, Redline tuning hood struts, Maxtrac spindles, SPC Light Racing UCA's, Bilstein 5100's front set at 0 with OME 885's & extended length Bilstein 5100's in the rear, All Pro expedition leaf springs & 2" blocks, extended brake lines front & rear, 1.5" 4crawler drive shaft spacer, Beefed Taco carrier bearing drop, 1.25" spidertrax wheel spacers on rear, Kenwood DNX570 touchscreen with navigation, 30" led light bar in lower bumper opening, 1/4" top plate spacer drivers side, Bullet Proof Fabricating skid plate, Cali Raised ditch lights & Rago f Fabrication brackets, Amp Research power steps, smoked l.e.d 3rd brake light, Wet Okole seat covers, under cab LED'S tied to dome circuit
    I got fuel kranks 17x9 with -12 offset & 4.5 backspace but have 285/70/17 tires.
    Not the best view but this is how they look.
    Hope this helps.
  4. Jun 11, 2013 at 7:26 PM
    bgb9
    bgb9 [OP] Member
    Brandon
    Brooksville, FL
    11 PreRunner SR5
    I haven't ordered the wheels yet. Need to know what offset and backspace to look for so there is no rubbing.
  5. Jun 11, 2013 at 10:46 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    4.5 BS is ideal for our trucks. Wont have any issues. Offset... closest to 0 is best.. but I run -12 and will be soon running -15. Tires will be why you rub. Rubbing is also easily fixed as well. Minor trimming. A cab mount chop to alleviate any remaining problems... and done.
  6. Jun 12, 2013 at 5:53 AM
    bgb9
    bgb9 [OP] Member
    Brandon
    Brooksville, FL
    11 PreRunner SR5
    What does the offset determine how far the wheel sticks out? I see a lot of people running a -12. Will a 0 offset make the wheel stick out more then stock? Whould I be better off running a 265/65/r17 or is it pretty safe that a 70 won't rub? Thanks for your help!
  7. Jun 12, 2013 at 7:41 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
  8. Jun 12, 2013 at 9:29 AM
    Raz4back
    Raz4back Well-Known Member
    Brett
    Benton, Arkansas
    2012 DC TRD Offroad 4x4
    Blacked out badges, Tinted Tail Lights, Fog Light Anytime Mod, Sock Monkey Bedside Decal, Painted Wheels, 20% Tint on Front Windows, 886 Bulb Backup Light Mod, Plasti Dip Rear Bumper (temporary until I get color matched), Color Matched Grill, Front Emblem, Door Handles, Mirrors, Bilstein 5100 all around, front set at 1.75, 1.5 aal, Crossfab light bar with 3 Hella Black Magic 500s, TRS Retrofit with D2S Projectors and Apollo Shrouds, BHLM with color matched Bowls and shrouds, CSJumper LED interior kit, CSJumper LED switchback DTRLs and Side Markers, 17x9 -12 Offset Ballistic Jester Wheels, 255x75x17 Nitto Trail Grapplers
    The offset is determined by backspacing/wheel width. A -12 offset on a 9 inch wheel is a 4.5 backspace
  9. Jun 13, 2013 at 5:27 AM
    bgb9
    bgb9 [OP] Member
    Brandon
    Brooksville, FL
    11 PreRunner SR5
    The two offsets that they offer are +1 and -12. With back spacing of 4.5, 5, 5.5. What one should I go with?
  10. Jun 13, 2013 at 7:14 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    4.5BS and -12 offset. I ran that exact same thing. No issues.
    My new wheels I just had put on yesterday are 4 3/8th BS and -15 offset. No issues there either.
  11. Jun 13, 2013 at 7:26 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    This. The tread will stick out about .5" past the fender with a 265 wide tire, with sidewall buldge, youre looking at .75-1". Either tire should be good with no rubbing and that offset. The 70 high may rub mudflaps and rear fender at full flex, but very little.
    Also, backpacking is 100% directly related to backspacing and rim width...on an x9 rim, -12 BS can only have 4.5 BS
    This may be useful... Factory rims (TRD OR) are 16x7.5 with a +32 offset.
    http://www.rimsntires.com/specs.jsp
  12. Jun 14, 2013 at 2:59 PM
    bgb9
    bgb9 [OP] Member
    Brandon
    Brooksville, FL
    11 PreRunner SR5
    Thanks for the help!
  13. May 16, 2015 at 8:34 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I have 2005 sr5 4x4 all stock other than new frame and 1extra leaf spring..i want these same 17x9 xd crank wheels wondering. What size at2 tires to use. without trimming
  14. Feb 3, 2018 at 4:27 PM
    bancrum
    bancrum Member
    2014 tacoma TRD sport
    3.5” lift with 285/70 R 17, Flowmaster dusk exhaust
    How much trimming did you have to do upfront?
