Blower motor squeek / chirp on low *FIX*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 26, 2009.
  1. Feb 26, 2009 at 4:50 AM
    ballon78
    ballon78 [OP] Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    Took the blower motor out of my 06, disasembled the entire thing, cleaned with electrical cleaner, regreased all plain bearings and motor is better than new. The top bearing is a oil inpregnated brass bearing and it was dry, thats where the chirp comes from. Did lots of research and found some other fixed but, those just masked the noise for a little bit. The motor come all apart fairly easy. I took pics and will post up how to do it tonight. Lots of people have had these replaced under warrentee just to have them start chirping a month down the road. What really needs to be done is just diasemble and grease and its fixed.
    tacotoe, Biscuits, LVNRURL and 6 others like this.
  2. Feb 26, 2009 at 5:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Cant wait to see the pics. I have thought the same thing, but others have said it was an issue of the motor being un ballanced.
    Rockin M likes this.
  3. Feb 26, 2009 at 6:06 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    That's good to hear, or to not hear anymore.....ha ha ha. Sorry, I couldn't resist a bad joke. I've been thinking about taking the damn thing apart to see what it looked like in there, but you beat me to it. I can't wait to see the pictures. BTW what type of oil/grease did you use to lube the bearings?
  4. Feb 26, 2009 at 7:38 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    I used BelraySyn, waterproof wheel bearing grease, its clear high end motorcycle/sled/Watercraft grease, i use it on everything, something thick to stay there longer is what i would recomend and good at low temps. just not something that is dark in color, like cheap wheel bearing grease may be messy
  5. Feb 26, 2009 at 11:01 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    Please post pics..mine is doing this, and I would love to see how its done..drives me insane..
  6. Feb 26, 2009 at 4:38 PM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    here are some, ill post more and how to do it, just dont have time right now!! thanks
  7. Apr 7, 2009 at 6:05 PM
    srcuvm02
    srcuvm02 Member
    Saratoga Springs, NY
    06 Access TRD Off Road 4wd
    YESSSSS!!!!!!
    FINALLY! NO SQUEAK!!! :)
    Only thing to remember if you do this, when taking the motor apart, the magnets seat on the motor with springs. Be careful taking it apart! Mine popped apart, springs went flying...
    Did find one, never found the other! But, had my leatherman and a 'clicky' ball point pen in the truck, worked like a charm! (the pen has seen better days, though):D
    Dj Suisav likes this.
  8. Dec 22, 2009 at 8:54 AM
    14U2NV
    14U2NV Active Member
    Socttsdale
    '12 SR5 4x4
    This is GREAT info! I will have to pull the motor out during this holiday vacation and fix mine. That squealing motor was driving me crazy. :goingcrazy:
  9. Dec 22, 2009 at 9:00 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    mine is squeaking now since it got cold....excellent
  10. Dec 22, 2009 at 9:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Wow, serious design FAIL. That motor should have bearings at each end.
  11. Dec 22, 2009 at 9:34 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Awesome! I was going to take mine apart this weekend to re-balance as indicated in the TN article but I'll do this at the same time.
  12. Dec 22, 2009 at 9:55 AM
    timmaayyy
    timmaayyy Well-Known Member
    Tim
    Raleigh, NC
    '16 TRD Sport DC
    Does anyone have pics or a write up of how to access/remove the motor?
  13. Dec 22, 2009 at 12:28 PM
    mountain lion
    mountain lion Member
    VA
    06 PreRunner
    URD TCAI, MAF Cal, o2 Sim, DT Headers
  14. Dec 22, 2009 at 1:03 PM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
  15. Dec 30, 2009 at 9:22 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    how'd you seperate that coil assembly from the fins?
    I'm stuck on that part.
    PS, and wtf is all that dusting crap? Rust/metal flakes?
  16. Dec 30, 2009 at 9:42 PM
    mountain lion
    VA
    06 PreRunner
    I don't think you need to separate that part...I used CRC Maf sensor/electronic cleaner on the part you have open and the top of the motor housing and the tick hasn't come back in a while...
  17. Dec 30, 2009 at 10:39 PM
    WATacoRider
    TRD Sport 4x4
    Well I hope you're right. I actually want to clean the fin housing too, because the blades on mine are super dirty. I cleaned what I could with q-tips. Only had Mobil 1 wheel bearing grease. Hopefully that's good enough.
    Time to install it back in. Here goes nothing.:eek:
  18. Dec 30, 2009 at 11:09 PM
    WATacoRider
    TRD Sport 4x4
    back. Welp, no more crickets, but now I got a ticking/fluttering sound instead.
    *sigh*
  19. Dec 31, 2009 at 7:40 AM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    Thank you for the report and pics :thumbsup:....I'm on my second fan motor and the problem persists.I'm going to try this fix.
  20. Dec 31, 2009 at 9:36 AM
    ballon78
    Amesbury, MA
    06 CC SR5 TRD
    thats the most important part, the fan fins are just press on...if you use two pry bars/screw drivers the fan fins wil wiggle slide off, they are on there tight. once thats off you need to lube the plain bearing with grease, something that will stick.
