Blank switch removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cstallings, Jun 24, 2013.
  1. Jun 24, 2013 at 4:11 PM
    cstallings
    cstallings [OP] Well-Known Member
    Arkansas
    2013 MGM DCSB TRD Sport 4x4
    SOS Front Bumper, SOS Sliders, SOS skids, ARB Rear Air Locker, OME Lift (885x Coils, Nitro Charger Shocks, Dakar Leafs), LR UCAs, Leer Shell, OKLED 30" light bar, Wet Okle Seat covers, etc, etc
    Any idea how you remove the top switch? The bottom came out by removing fuse tray (for lack of better wording) and pushing on the back of the switch. I can't figure out how to get the top out without dismantling the dash.
    I have a 2013 trd sport.
  2. Jun 24, 2013 at 4:39 PM
    Elmosaurus
    Elmosaurus Well-Known Member
    NorthEast PA
    2016 Tundra Blazing Blue SR5 TRD Crewmax 4x4
    I believe I read somewhere here that you can reach up and pop the rear view mirrow panel out first, then use that hole to reach up and push the upper switches out from behind.
    Someone with more experience will likely be along shortly to confirm or refute that...
  3. Jun 24, 2013 at 4:56 PM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Just pop it out with a putty knife or a butter knife :thumbsup:
  4. Jun 24, 2013 at 5:53 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    5100's and 883 OME Coils TRD Exhaust Deaver 1.5" AAL Rear Differential Breather Extension, 4WD Light, Tailgate Pipe clamp, Fog lights on while High Beams on, Carrier Bearing flip
    ^yep.
  5. Jun 24, 2013 at 5:57 PM
    HombreSteven
    HombreSteven Needs money for mods
    Tampa
    2011 Reg cab 4x4
    K&N air filter, Aries bull bar; not much YET
    Did you actually do this
  6. Jun 24, 2013 at 6:01 PM
    mjm540ii
    Oxford, PA
    ...Yes, why?
    Make sure it is a metric butter knife tho.
    cheezwhiz and DollarTacos like this.
  7. Jun 24, 2013 at 6:04 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    I was able to reach the bed outlet switch and pop it out first and then with that one out I could get the blank out
  8. Jun 24, 2013 at 6:07 PM
    WesD
    WesD New Member
    Wes
    Wilkes, NC
    07 TRD Offroad
    This is along the same lines... I have an 07 trd offroad and I went to pop out the bottom blanks and the 2 on the right have wires going to the back but not connected to anything. Anyone knows what there wires are for?
  9. Jun 24, 2013 at 6:08 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    This or the OP is stuck half hanging out of his truck with his hand stuck in his dash
  10. Jun 24, 2013 at 6:14 PM
    cstallings
    Arkansas
    I just popped it out with a small flat head. I was trying to preserve the cover in case I wanted to put it back, but it didn't do much damage anyway. New switch in...watch out Sasquatch!
  11. Oct 25, 2014 at 3:02 PM
    URMyBudE
    URMyBudE New Member
    10 Tacoma 2WD SR5 5-Lug
    AAL, Winjet Fogs, Imposters
    Just finished this exercise today and used some of the information posted to assist in completing a WinJet fog light kit installation with a backlit switch in the OEM switch position. There was no need to remove the dash panel. All blanks can be removed from the front by first using a small butter or patte (sp?) knife to wedge the bottom of the blank out approximately 2-3 mm, then inserting a flat head (4-5 mm) screwdriver under the center bottom to catch a molded recess in the blank, then prying the bottom edge out with the driver rocking on the flat edge of the butter knife (prevents leaving a detent in the panel below the blank). Use tape around the opening bottom to avoid marring panel surfaces. There are no tabs to release on an unwired blank...just small interference cams on the top and bottom of the blank.
    To see what the backside of a blank (unwired) looks like, pop out the blank just above the fuse access panel by reaching behind the blank and pushing it out.
    Wired blanks are used for models that have options pre-wired in the main harness, but the option was not installed at the factory.
    Hope this helps.
