Alignment, caster camber problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 13Tacoma, Jun 28, 2013.
  1. Jun 29, 2013 at 12:01 PM
    #21
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    When measuring from the centerline of the front hub to the centerline of the rear one side was 1" shorter then the other.
  2. Jun 29, 2013 at 12:02 PM
    #22
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Shorter side to side ?
    ie driver's side measurement versus passenger side measurement
  3. Jun 29, 2013 at 12:04 PM
    #23
    savedone
    Gerald
    Texas
    Correct.
  4. Jun 29, 2013 at 12:14 PM
    #24
    OZ-T
    Peter North
    British Columbia
  5. Jun 29, 2013 at 12:21 PM
    #25
    savedone
    Gerald
    Texas
    Your welcome. :)
  6. Jun 29, 2013 at 3:27 PM
    #26
    BamaToy1997
    Bill
    Navarre, FL
    USUALLY but not always, that can be corrected by loosening the leaf pack u-bolts and verifying the center pins are in the correct position. Sometimes however a more aggressive method needs to be taken. Measure the length of each leaf from center to tip of leaf on left and right. If these numbers are significantly different then the leaf packs may need to be disassembled and repositioned.
  7. Jun 29, 2013 at 6:00 PM
    #27
    savedone
    Gerald
    Texas
    Thanks, but the dealer messed it up and they also fixed it. I am not sure what they did to fix it but it is running straight now.
  8. Jul 1, 2013 at 10:41 AM
    #28
    13Tacoma
    13Tacoma [OP] Well-Known Member
    Colorado
    2013 TRD Off-Road Silver Streak DC
    Fog Light Mod, Debadged Tailgate, Blacked out Front Grill, Removed Front Mud Flaps, 3" Lift, 4" Quantum LED's mounted behind Lower Valence-Courtesy of Kmd Garage Group Buy.
    Thanks for the info and to every one else that left feedback! I will add that since taking it out for the weekend and having it up to hwy speeds with a canoe on my home made rack it wasn't all over the road as suggested. Is that wierd? I will head down to the shop and see what they will do.:)
  9. Jul 1, 2013 at 10:48 AM
    #29
    13Tacoma
    Colorado
    Probably should have thrown this up along with my question but here it is. the printout I was given. Sorry its sideways..
  10. Jul 1, 2013 at 12:30 PM
    #30
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    2013 TRD OR DC 6 spd.
    3" Toytec Ultimate lift, Light Racing UCAs.
    This topic has kinda been beat to death but here are my .02. I installed a 3" lift on my 2013 DC and had the alignment done to factory specs.
    This alignment ended up causing my truck to have a "loose" feeling in the steering wheel and created a ton of bumpsteer problems. After checking on TW to diagnose the problem i realigned my truck with some specs recommended by TW members.
    This setup is MUCH better! The looseness is gone and the bumpsteer is really unnoticeable. The driveability is better and the braking is solid and not squirly. I do have Light Racing UCAs so the 3* caster was possible for me but you probably wont get that without aftermarket UCAs.
  11. Jul 3, 2013 at 7:57 AM
    #31
    13Tacoma
    Colorado
    Where did you go for your alignment? I see your location is Denver.
    Here are my latest numbers after going back to the shop today. Camber is still off and the tech said that he can't get it closer to 0 without the caster going into the Neg. Any truth to that?
  12. Jul 3, 2013 at 1:58 PM
    #32
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    You're probably going to need UCAs to get a good alignment. Might be able to try another shop but I doubt you're going to get the numbers you really want without them. That's why I didn't risk it and just bought them with my lift.
  13. Jul 4, 2013 at 11:17 AM
    #33
    Dano.oh
    Dano.oh Member
    Dan
    Denver
    This^
    I have LR UCAs also and they are normally required to get there numbers exactly, however I have heard of people getting 0 toe and 0 camber with a low 2* caster with stock UCAs but never seen any proof. Many shops just don't know how to align properly or lack the motivation which may be the case for you. My 2nd alignment was done at Coloradoland in Littleton and as you can see they got it right on so I would guess they might be able to get you taken care of or at least improved from where you're at now.
    If you look at the specified numbers for your truck on the alignment sheet you can see where they should be able to get with stock UCAs which are way better than the numbers you have on your alignment sheet so I would have someone else try again. It is certainly possible to get 0 toe, 0 camber, and at least 1 or 2* caster.
    TaqoSalad likes this.
  14. Jul 5, 2013 at 12:55 AM
    #34
    13Tacoma
    Colorado
    Thanks for the Info. I appreciate all the feedback given!
  15. Feb 13, 2014 at 7:35 AM
    #35
    BOOSTEDTRD
    BOOSTEDTRD Active Member
    Aaron
    Overland Park, KS
    '11 TX Access Cab
    3 Hella Rally 4000 on modded Westin light bar, Bilstein 5100s front 1.75" front, Toytec 1/4" spacers, ECGS bushing.
    I'm getting a lot of "bump steer" after 2 1/4" leveling. Stock rear. Bilstien 5100's 1.75, 1/4" top spacer. On the highway steering wheel kind of moves up and down on its own. Drives straight, but the wobble is driving me nuts. Had it aligned 3 times to get to these specs, but doesn't feel any better. Kind of a dead feel on initial turning. Brand new 265/75r16 bfg at 32 psi. 45k miles. Any ideas?
