Rattling rear wheel well liner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUSETACO, Aug 16, 2013.
  1. Aug 16, 2013 at 8:34 AM
    LUSETACO
    LUSETACO [OP] Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I think I have finally narrowed down what is rattling over bumps. When I was waxing the truck today I noticed that the wheel well liner doesn't seem securely fastened to the truck bed. It uses some funky plugs with a metal collar so no way to fasten it down tighter. Anyone else have this issue or a fix or should I just deal with it rattling over every little bump? Here is a pic for reference....
  2. Aug 16, 2013 at 7:14 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Eh? Nobody else has this issue?
  3. Aug 16, 2013 at 7:15 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    Can you remove the plastic clips and install nuts and bolts?
  4. Aug 16, 2013 at 7:22 PM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I'm not sure, had to rush to work so I didn't really look at it too much. There is a good 1/4 inch gap between the liner and the bed so it rattles like a SOB.
  5. Aug 16, 2013 at 10:41 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Mine has had that for a long time. Rattles when I shut the doors. The nut and bolt idea seems like a good one.
  6. Apr 9, 2014 at 5:13 AM
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    I never did bolt them. They are just plastic clips holding them in place. Push them in until they click all the way down.
  7. Apr 9, 2014 at 5:18 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Mine rattled when I shut the rear door. I just pulled them out last week.
  8. Apr 9, 2014 at 5:32 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Don't know since my flares are off right now and 2" are cut off the fender.
  9. Jun 24, 2017 at 5:51 PM
    tsb
    tsb 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
    my 2014 just started rattling.
  10. Jun 25, 2017 at 7:33 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I've had an '06, a '13, and a '14 DC and every one of them made a noise when I closed the rear door. Other than that it caused no other annoyance and I never addressed it. I think that the '06 was far worse than the other two.
  11. Jun 27, 2017 at 9:21 AM
    leosantamana
    leosantamana Member
    06 Tacoma owner here (Just bought it). I had same issues on both sides. Two simple aluminum rivets on each side fixed it right up!
  12. Jun 27, 2017 at 1:24 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    I just got a bunch of sticky-backed foam (the kind they sell at Home Depot as weatherstripped for camper shells), and put it up there. All is silent now.
    Though I never thought about rivets. I should take another look and see if I can pop rivet those stupid things in place.
  13. Jun 28, 2017 at 12:21 AM
    stbear
    stbear Well-Known Member
    SE PA
    2015 DCSB TRD Sport MGM
    I just noticed this the other day. 2015 still under warranty. I'll address it with the dealer.
  14. Nov 28, 2019 at 7:44 AM
    TBob
    TBob New Member
    Yes.. thanks for the help.. Just looked at it, it is the liner.. again probably the plastic quick assembly clips. In Wisconsin with all the salt on the road a AL pop rivet won't last. 2015,, v6 crew cab
  15. Nov 29, 2019 at 12:09 PM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    Pics of it removed?
  16. Oct 28, 2023 at 6:16 PM
    number9
    number9 Member
    Know this is an old thread (couldn't find a newer one), but my son's truck had the same rattle from the factory push pins not being tight enough.
    I made some rubber washers to go between the liner and bed. Replaced the OEM push trees (on the left) with push pins.
    Sorry for the small pic, they came from a push pin kit I got off Amazon. Size is 20mm / 11mm / 8mm
    Rubber washer between liner and bed
    I removed the pins from the sockets to make them go in a little easier. They're a snug fit.
    Pins were a firm push to get to get in, but they're solid, and no more rattle / buzz.
    Cav Blue TRD Pro and stbear like this.
